Gear Swap Please HELP!!!!
LinkBack (1) Thread Tools
Old May 3rd, 2008, 11:51 PM   1 links from elsewhere to this Post. Click to view. #1
pqtiii is on a distinguished road
Angry
I have been fighting this gear swap for two days now. I'm working on my 07 GT. I'm trying to get the pinion gear to the crush sleeve. I'm only able to suck the pinion shaft within 1/8 inch of play. I tried using a 600ftlb impact with no luck, broke two screw drivers(as stops), and finally called the Ford Racing Tech line. They told my to wire wheel the splines. I did it third times with no luck. I even put the pinion gear in the press to see if the yoke would go all the way down. It did fine, but no hand tools can get it to suck in.
What's left for me to try? Any one run into this??
Please help, it's driving me nuts...
Thanks
pqt
Old May 4th, 2008, 01:02 AM   #2
GOTTORQ's Avatar
2008 Mustang GT/CS BLK
13.7@ 103mph
GOTTORQ is on a distinguished road
Send a message via AIM to GOTTORQ
your playing with fire, should have let someone else do it..you may end up with gear whine..i honestly have never attempted to change gears in a rear end nor i ever will, best of luck to you, i hope everything turns out alright
Stage 2 Mutha Thumprs,FRPP 4.10s, Pypes O/R X pipe, Violator axleback, JLT CAI, GT500 spoiler, 18x9/18x10 (255/285) H&R lowering springs
Nitrous is like a hot girl with an STD... you wanna hit
it, but your afraid of the consequences
Old May 4th, 2008, 02:10 AM   #3
May 08 ROTM
2008 Audi S6
Emay has much to be proud ofEmay has much to be proud ofEmay has much to be proud ofEmay has much to be proud ofEmay has much to be proud ofEmay has much to be proud ofEmay has much to be proud ofEmay has much to be proud ofEmay has much to be proud ofEmay has much to be proud of
Generally the 600ft lb impact will do the work, mine was sort of easy.
A few years back on my monte I used a little heat on the outside of the housing to soften things up, that's a hack though. I definately don't recommend it..
Old May 4th, 2008, 02:19 AM   #4
MMs Ford Racing Nut Swinger
1FUN4RD's Avatar
2007 MUSTANG GT
1FUN4RD is a splendid one to behold1FUN4RD is a splendid one to behold1FUN4RD is a splendid one to behold1FUN4RD is a splendid one to behold1FUN4RD is a splendid one to behold1FUN4RD is a splendid one to behold1FUN4RD is a splendid one to behold
Are you sure you have the right crush bearing??
www.1fun4rd.blogspot.com
Old May 4th, 2008, 03:38 AM   #5
05mustang_kb_charged's Avatar
2005 Mustang GT
10.32@137.70
05mustang_kb_charged is a jewel in the rough05mustang_kb_charged is a jewel in the rough05mustang_kb_charged is a jewel in the rough05mustang_kb_charged is a jewel in the rough
impact wrench, a regular rachet or breaker bar makes it real hard
If you use a breaker bar try using a pipe wrench to hold the pinion flange but it takes alot to get it to start to crush. I also had to put the crush sleeve in a vise to get it to start compressing then installed it and sucked it down with a breaker bar
326 cubic inches of Turbocharged hell will be running soon
Tuned by Wes @ TPS
Old May 4th, 2008, 03:41 AM   #6
silverstang's Avatar
2007 Mustang GT
silverstang is a jewel in the roughsilverstang is a jewel in the roughsilverstang is a jewel in the roughsilverstang is a jewel in the rough
what you need to do is "un-crush" the old crush sleeve with a hammer, and re-use it. makes life SOOOO much easier.
Bassani Crew Member #3
Old May 4th, 2008, 03:45 AM   #7
2005 Mustang GT
10.32@137.70
?????? Explain how and why you would want to do that, the crush sleeve is a 1 time use item
Tuned by Wes @ TPS
Old May 4th, 2008, 10:40 AM   #8
2006greyGT's Avatar
2006 Satin Silver GT
11.08@125.22
2006greyGT has a spectacular aura about2006greyGT has a spectacular aura about
Send a message via Yahoo to 2006greyGT
isn't that like making something undead? Do it right or deal with the results...
[IMG]
2.6l KENNE BELL 298 Stroker, Ported heads
Pro Motion Built 3650/McLeod RST/ MGW Short Throw
Long tube/O/R X /Borla Touring
8 rib/65 lb injectors/GT500 twin fuel
ET Drag Slicks/3.73 gear
Detroit Truetrac /CDC AGR Spoiler
Old May 4th, 2008, 11:45 AM   #9
I can't even get the yoke to the crush sleeve. There is still about an 1/8 in play. When I take the pinion nut off after impacting it forever, I can still see an 1/8 in of the grooves inside in yoke. So I'm not even close to the c-sleeve.
I thought about heat, but I think the dust guard on the yoke is plastic. I thought about sanding/grinding the pinion splines. I guess I'll have to take the rear out of the car and put a pipe on it.
Is it really this hard to get it on?? My friend just did his TransAm and he used an impact and it went on fine.
Thanks
pqt
LinkBack to this Thread: http://www.moddedmustangs.com/forums/2005-2010/69327-gear-swap-please-help.html
Gear Swap Please HELP!!!! This thread Refback May 5th, 2008 05:13 AM
Threads Similar to: Gear Swap Please HELP!!!!
Gear Swap and Tuner MSCLCAR 2005 - 2010 6 April 23rd, 2008 12:49 AM
91 Gear Swap Help 91cobra5.0 5.0 Mustangs 36 January 12th, 2008 06:55 PM
Spedo gear swap aj28 V6 Mustangs 2 July 31st, 2007 02:04 AM
3.73 gear swap droppedbass87 96-98 15 May 19th, 2007 12:08 PM
need help with gear swap to 3.73's roscoe 5.0 Mustangs 7 April 22nd, 2007 09:20 PM
