horse power
I have a 05 gt with a c & l cai racer udp's brenspeed 93 tune comp cams nxr no spring cams delete plates tri-ax shifter had dynoed at 310 hp 303 torq can someone tell me if this is close or what hp and torq it should be . thanks
2007 Mustang GT
12.6@110
That shifter must add at least 20hp. lol
That seems within the realm of reason for rwhp. The CAI and tune should be givin 15-25, not sure what the cams add, but about 20rwhp would seem reasonable. Oh, hmm, and those UDPs should be adding 10-15hp or so. 310 may be on the low side I suppose, get an updated tune based on your dyno test and the numbers may come up a few.
![]() Professor Crackers
ive heard the mustang stripes are good for 20hp also
#4 | |
2007 GT
My car with frpp/steeda cai, UDs, 93 brenspeed tune dynoed at 310/318 dynojet dyno, standard cf on a 60% degree day. Subtract about 3% if you want to get it at what sae numbers would show and your looking at 301. Which stage NSR cams you got? I have stage IIs, with delete plates and Long tubes and now im at 352/335 on the same dyno same basic weather. so im pumping a solid 343 sae CF. Im manual. If your manual that seems way low. If your auto it's about spot on with what i have seen other automatics with you car pull. Either way the tq seems low to me. Last edited by 07stanggt; May 14th, 2008 at 07:40 AM. |
2007 GT
if you look at the below link brenspeed tested those cams on an automatic with just a c&l racer and the stage II cams and they got 303/306 so add your ud's which gave me 7, if your an automatic you seem to be about perfect, i guess the tq isnt that low. If your manual your way low. Further evidence that the delete plates do nothing.
2007 MUSTANG GT CAM TEST |
2008 Mustang Gt
Flams are a for sure a 100hp gain!!
JLT Intake, Off-Road X-Pipe, Magnaflow Axleback
MM's resident Juice head
07 Mustang GT
UDP'S will give you 8 hp max on a standard.
![]() The MGW short throw shifter Its not just a shifter...It's a lifestyle! |
thanks guys its a manual
Threads Similar to: horse power
| max horse power | mannymustang | V6 Mustangs | 16 | April 17th, 2008 11:07 AM |
| How Much Horse power do you have? | Nameless122 | V6 Mustangs | 136 | August 24th, 2007 04:21 PM |
| Estimated Horse Power Numbers? | Darrellx14 | 5.0 Mustangs | 5 | August 23rd, 2007 12:29 PM |
| Horse Power | FTHOODV6STANG | V6 Mustangs | 25 | October 15th, 2006 12:26 AM |
| Stock horse power info please | trebel14 | 5.0 Mustangs | 3 | July 25th, 2006 01:18 AM |
