Wire Diagram Needed
i need a wire diagram for the 05-06 mustang. what id like to know is where and what color, can i pick up the electric wire for the trunk. id like to put in a momentary switch in the glove compartment to open the trunk. i figure if i use the switched side of the brake pedal circuit thru a n.o. switch and connect it to the trunk circuit, itd be somewhat easy to have a in car switch only activated when the brake and button are pushed.
comments are certainly appreciated. don |
According to Alarm Installations that I have Read. It is:
TRUNK RELEASE WHITE/PURPLE (-) @ SJB, BLACK 52 Pin Plug, Pin 13, See NOTE *1 NOTE *1 The SJB (Smart Junction Box) is located in the PASSENGER KICK PANEL. I hope This Helps! |
here's a set of instructions on how to put in a trunk switch.
http://www.cherod.com/mustang/HowTo/TrunkRelease.htm Be patient, it takes a while for all the pictures to come up. |
#5 | |
So from what that link and instructions say, Everything is there except the actual button to activate it? Connect your switch to the white/pink wire and that is it. Why did Ford leave that out then if they connected everything else. If it is that easy, I will do it this weekend. Someone let me know if it is that easy
05 Mustang GT |
Threads Similar to: Wire Diagram Needed
| exhaust diagram needed | dgt_mustang | V6 Mustangs | 6 | March 10th, 2011 09:56 PM |
| Engine Diagram needed ASAP | Brenda | 5.0 Mustangs | 4 | October 8th, 2007 02:09 AM |
| 98 spark plug wire diagram | shadow98gt | 96-98 | 3 | June 5th, 2007 10:07 PM |
| Installing Zex window switch ! Tach wire help NEEDED | calpat1985 | 99-04 | 0 | May 8th, 2007 07:59 PM |
| Fuse panel diagram and Mach 460 Wire Map | B0mb3r645 | Audio/Video | 1 | August 27th, 2006 01:38 AM |
