NSR cam write up page 2
LinkBack (9) Thread Tools
Old May 26th, 2008, 11:36 AM   8 links from elsewhere to this Post. Click to view. #1
MM's resident Juice head
07 STROKER's Avatar
07 Mustang GT
07 STROKER is a splendid one to behold07 STROKER is a splendid one to behold07 STROKER is a splendid one to behold07 STROKER is a splendid one to behold07 STROKER is a splendid one to behold07 STROKER is a splendid one to behold
So now its time to put the cam followers back in....if you havint taken a break yet...do it now! Unfortunantly i couldint take any pics of me using the tool cause I was by myself but i will tell you best I can on how to use it. The tool is fairly easy to operate once you get the hang of it...the trick is to roll the engie into the perfect position to get all 3 followers in...I rolled so that the exhaust valve was getting ready to open...this seemed to be the sweet spot to get all the followers in. The snap into place but sometimes they can be awkward. I will give my number at the end of this for anyone who needs help wit hthat tool. I also have a link to another write up that shows the tool on the cam that i can send you.
Once you get the followers in go ahead and put the cam cover on. TIP there is a bead of silicone on the top and bottom of the head where it meets the timing cover...clean the old stuff off and reapply some new stuff....its worth it to ensure there are no leaks. Once the cover is on re assemble the coil packs and start on the other side...same procedures...heres a tip for the passenger side. Remove the battery. It makes isway easier to remove the cam cover
Remove the battery tray as well, just three bolts hold it in.
Follow the same procedures for both sides and you are all set! The hardest part was having the patience with that Spring tool but in the end its worth doing it that way. This way you know all the followers are in their proper place...It would suck if one spat out of place on start up!
Anyway i am willing to help anyone that tries this install. I am on Mountain time and my number is 1-780-779-8071 my name is Ken. Any questions please call.
The MGW short throw shifter
Its not just a shifter...It's a lifestyle!
Old May 26th, 2008, 01:10 PM   #2
07 Grabber GT's Avatar
2007 GT
07 Grabber GT is on a distinguished road
Nice write-ups ...
Did you consider only removing the cam using the "Ford" way by taking out just a few of the unloaded followers at the 12 O'clock position and then rotating the engine to the 6 O'clock position relieving pressure on the others before undoing the bearing journals? I'm just curious why you chose to remove the cam from loaded springs first then take out all the journals?
It looks like you have two methods ... in the first thread you said you pulled the cam out "loaded" and then pulled the followers ... here it sounds like you did the "Ford" way ... am I reading that right?
Old May 26th, 2008, 01:17 PM   #3
07 STROKER's Avatar
07 Mustang GT
It was quicker...you can do it that way for sure. you just have to do that before you wedge the timing chain...I already had mine wedged and the sproket off.
Old May 26th, 2008, 01:29 PM   #4
One Man Wolf Pack
06RedfireGT's Avatar
2006 Mustang GT
13ish....maybe
Kickass write up man.
ΜΟΛΩΝ ΛΑΒΕ
Old May 26th, 2008, 01:36 PM   #5
07 STROKER's Avatar
07 Mustang GT
thanks...isit getting stuck somewhere?
Old May 26th, 2008, 01:37 PM   #6
07 STROKER's Avatar
07 Mustang GT
nm LOL
Old May 26th, 2008, 04:57 PM   #7
lilmarc1988's Avatar
2001 mustang gt
lilmarc1988 will become famous soon enough
Send a message via AIM to lilmarc1988 Send a message via Yahoo to lilmarc1988
kool
Old May 26th, 2008, 04:58 PM   #8
Admanistrator
v606er's Avatar
v606er has much to be proud ofv606er has much to be proud ofv606er has much to be proud ofv606er has much to be proud ofv606er has much to be proud ofv606er has much to be proud ofv606er has much to be proud ofv606er has much to be proud of
another great write up
MAD Stangs #8
Old May 26th, 2008, 06:42 PM   #9
bkid's Avatar
2006 Mustang GT
14.024
bkid is on a distinguished road
Where do you get the tools?
Old May 26th, 2008, 06:48 PM   #10
07 STROKER's Avatar
07 Mustang GT
ford....or online i guess...i got lucky and my service manager lent them to me for the weekend
Old May 26th, 2008, 10:09 PM   #11
2007 GT
Man, wish I could find a service manager like that ... you didn't sign up for letting do your next 5 oil changes or something did you
Old May 27th, 2008, 01:44 PM   #12
07 STROKER's Avatar
07 Mustang GT
no he just wants a ride in it
Old May 27th, 2008, 06:36 PM   #13
02StangGToWNEr's Avatar
2006 Mustang GT
02StangGToWNEr is on a distinguished road
Awsome write-up bro, and congrats. I'll look you up if I need help when I do mine.
Old May 27th, 2008, 08:24 PM   #14
bkid's Avatar
2006 Mustang GT
14.024
I was reading the Ford RR and it said to remove only 3 of the followers on each side.
Old May 27th, 2008, 08:26 PM   #15
07 STROKER's Avatar
07 Mustang GT
then do it that way.....this is a write for how I did it...it doesint mean there arent other ways to do it....look at the video at the end of my writeup...my way works too.
Old May 27th, 2008, 08:36 PM   #16
HMUSN's Avatar
48.47@ 12.58
iTrader: 10 reviews
you should have these 2 threads merged and made a sticky.
good write up
Old May 27th, 2008, 08:37 PM   #17
07 STROKER's Avatar
07 Mustang GT
look up buddy
Old May 27th, 2008, 09:04 PM   #18
2007 GT
Once you had the spring compressor in there, and got the follower out ... how hard do you think it would be from there to the take off the spring retainers? Does it look simple or are more crazy tools required? Just curious ...
Old May 27th, 2008, 09:07 PM   #19
2007 GT
07stanggt has much to be proud of07stanggt has much to be proud of07stanggt has much to be proud of07stanggt has much to be proud of07stanggt has much to be proud of07stanggt has much to be proud of07stanggt has much to be proud of07stanggt has much to be proud of
its not a matter of it being hard. its a matter of it being teduis to take out and put in 24 springs and retainers. its hours worth of work in istelf.
Old May 27th, 2008, 09:10 PM   #20
2007 GT
its also an additional 350 or so in parts. depending on what springs you go with and the question becomes if you can gain 40hp without doing it. why exactly are you doing it. there are cars on this site, with stage III vsr cams that i already ran a faster time then. Not bragging at all just saying, is it worth it? first question to ask youself is what is your goal with your car, not how hard, or how much is it going to cost.
LinkBack to this Thread: http://www.moddedmustangs.com/forums/2005-2010/72813-nsr-cam-write-up-page-2-a.html
FRPP Hot Rod Cams installed - Idle is now surging/bouncing - Any ideas? - Page 5 - The Mustang Source - Ford Mustang Forums This thread Refback November 23rd, 2010 02:13 AM
FRPP Hot Rod Cams installed - Idle is now surging/bouncing - Any ideas? - Page 5 - The Mustang Source - Ford Mustang Forums This thread Refback August 8th, 2010 08:32 PM
S197 Sites This thread Refback April 28th, 2010 10:33 PM
Hot Rod cam dyno results - Page 4 - WWW.S197FORUM.COM This thread Refback February 9th, 2010 09:17 PM
Cams & Headers for 4793 - Page 2 - IMBOC This thread Refback March 31st, 2009 09:04 AM
My review of JDM: - Page 2 - WWW.S197FORUM.COM This thread Refback August 13th, 2008 12:33 PM
My review of JDM: - Page 2 - WWW.S197FORUM.COM This thread Refback August 12th, 2008 03:14 PM
FRPP Hot Rod Cams installed - Idle is now surging/bouncing - Any ideas? - Page 5 - The Mustang Source Forums This thread Refback June 8th, 2008 09:17 PM
NSR cam write up page 2 - Page 2 This thread Refback May 27th, 2008 11:04 PM
Threads Similar to: NSR cam write up page 2
NSR cam write up. 07 STROKER 2005 - 2010 39 April 18th, 2010 12:26 PM
Info on NSR cams 07stanggt 2005 - 2010 51 April 7th, 2008 03:26 PM
Video of idle with nsr cams 07stanggt 2005 - 2010 5 March 5th, 2008 04:48 PM
Brenspeed Com NSR Cams ? killermach1 2005 - 2010 15 January 7th, 2008 12:59 AM
