FRPP cam specs 133 LSA???
Old May 28th, 2008, 12:49 AM   #1
AtHomeTech's Avatar
2006 Mustand GT
AtHomeTech is on a distinguished road
I found these specs on another site. 133 LSA seems VERY high. Can anyone verify this?
Intake Lobe: Production Ford Racing Cams
IVO BTDC 15 49 deg.
IVC ABDC 53 51 deg.
Total duration 248 280 deg.
Duration @0.006 262 deg.
Duration @0.050 200 deg.
Exhaust Lobe: Production Ford Racing Cams
EVO BBDC 80 97 deg.
EVC ATDC 19 19 deg.
Total duration 279 296 deg.
Duration @0.006 281 deg.
Duration @0.050 216 deg.
Overlap 34 68 deg.
Lobe separation angle 133 deg.
Valve Lift: 11mm 12mm
Please note that VCT cams have strange events from what you normally see, because of the VCT capability.
If stiffer than production springs are used the VCT phaser will make a ticking noise and eventually fail.
Stock springs have been used with this cam up to 7000 rpm.
Peak power with the stock intake, FR cams and CNC heads is 6500 rpm.
The opening and closing numbers listed are for the cams in the fully advanced position. They can be retarded up to about 55 degrees from these values by the VCT.
The Ford Racing cams will not show any power improvement over production if they are installed in the fully advanced position and the VCT is locked out because the intake closing point would be essentially the same as a fully advanced production cam.
1) 3v at 12 degree retard is about where the production cam events happen near the power peak rpm.
2) 3v at 17 degree retard is about where the production cam events happen if VCT is locked out and cam is installed 1 sprocket tooth retarded.
3) hot rod at 17 degree retard is where the "hot rod cam" events happen if VCT is locked out and the cam is installed 1 sprocket tooth retarded.
-Ken
2006 GT AirRaid CAI, Borla axle back, FRPP CAMS, Custom tune with HPTuners. 13.6 @ 103
2000 C5 Corvette BBK Shorties, LG G5X3 CAM, Borla cat back, HPTuners tuned running 12.1 @ 117mph
Old May 28th, 2008, 01:17 AM   #2
silverstang's Avatar
2007 Mustang GT
silverstang is a jewel in the roughsilverstang is a jewel in the roughsilverstang is a jewel in the roughsilverstang is a jewel in the rough
pm 07stangGT i think he has exact specs on those cams................me and him have been workin' on cams for a while now, lol
Bassani Crew Member #3
Old May 28th, 2008, 08:56 AM   #3
2007 GT
07stanggt has much to be proud of07stanggt has much to be proud of07stanggt has much to be proud of07stanggt has much to be proud of07stanggt has much to be proud of07stanggt has much to be proud of07stanggt has much to be proud of07stanggt has much to be proud of
I have the rest of those specs just not the LSA. and i agree that lsa seems unreasonable.
Old May 28th, 2008, 12:23 PM   #4
tribaltek's Avatar
tribaltek has a spectacular aura abouttribaltek has a spectacular aura about
Where did you get this info?
Also, I'm stupid when it comes to LSA. Why is it a bad thing?
'06 Whipple'd Mustang GT (Coming Soon)
'02 Supercharged Harley-Davidson F-150 (Sold)
'05 Mustang GT (Sold)
Old May 28th, 2008, 12:29 PM   #5
2007 GT
lobe serperation angle. normally your talking about a LSA of 106 to 116. So 133 degrees of seperation in the angle of the lobes would be very wide. thats all. Im not saying its bad or not. just seems like a high number. especially considering the idle on those cars. more narrow the seperation the rougher for the idle, there are other factors though before it starts another cam debate.
Old May 28th, 2008, 12:31 PM   #6
tribaltek's Avatar
Interesting...
Well, I still don't think I'm going to install them myself, but I should be able to have them in by next week. I'll keep everyone posted!
Old May 28th, 2008, 12:36 PM   #7
2007 GT
actually now that i look at those number more closely i think they are way off. That looks like a mix of the stock specs and the hot rod cams. yea thats what it is. a 12mm lift on the hot rods, stock is 11, the advertised duration is 280 and 296, dont know what it is @.50.
Old May 28th, 2008, 12:37 PM   #8
AtHomeTech's Avatar
2006 Mustand GT
I am going to try and have it profiled today. 133 LSA is WAY wider than anything I have heard of. Maybe its a typo and supposed to me 113. I'll let you all know.
Old May 28th, 2008, 12:40 PM   #9
2007 GT
113 would seem right. consider the lope on those things with the other specs.
Old May 28th, 2008, 06:19 PM   #10
AtHomeTech's Avatar
2006 Mustand GT
Well, it was going to be $150 to profile the cams locally and honestly I dont want to know that bad. I'll get the real specs some other way or try the shop in vancouver.
Old May 28th, 2008, 06:51 PM   #11
07_427R is on a distinguished road
I was reading about the new LS9 Vette engine yesterday and saw them talking about the cam and its LSA of 122 degrees. That really stuck out, so 133 is really way out there. 113 seems seems more within a normal range.
Threads Similar to: FRPP cam specs 133 LSA???
289 cam vs 351 cam Kenn Classic Mustangs 11 May 5th, 2008 01:20 PM
specs Killer_Bee V6 Mustangs 8 October 5th, 2007 01:32 PM
E cam or F cam horsepower and 1/4 mile time questions GreyGhost 5.0 Mustangs 1 August 21st, 2006 06:25 PM
T5 specs 99mustang232 General Tech 0 December 6th, 2005 05:11 PM
