2007 GT
why not just replace the bushings.
what added benifit of replaceing the actuall control arms would I get? considering a one piece drive shaft is in my future, maybe i will just go ahead and get an adjustable upper 3rd link but why not just replace the bushing in the stock lower control arms?
Or replace them all with these prothane bushings Front Swaybar Bushings Rear Swaybar Bushings Shifter Bushings (Manual Transmission) Upper Control Arm Bushings Lower Control Arm Bushings Front Control Arm Bushings Last edited by 07stanggt; May 31st, 2008 at 08:40 AM. |
2007 GT
considering my wheel power? at what power what you really want to change the peices themselves?
One Man Wolf Pack
You should change thee whole assembly because at that power level with sticky tires, the control arms themselves will flex. The stockers are just POS stamped pieces. The aftermarket units are much more substantial.
![]() ΜΟΛΩΝ ΛΑΒΕ
2007 GT / CS
Have to decide if you want better control at launch or if you require the articulation factor for improved road manors. If straight up urethane bushings than you loss a bit of the roll features or suspension articulation. But gain straight up traction improvement.
The solution ? they do offer either solid joint type's or combinations of urethane and poly ball combo's that satisfy both traction and articulation. Many different options but do your homework to see what works best for you !
Paxton 2200 SL, BBK Equal Length Shorties, Pypes Off Road X, Corsa Axle Back, Hurst Short Throw, J&M UCA / LCA / Adj Pan Rod, BMR Drop / Relo Brkts, FRPP STB / 4:10's / Diff Support / Hot Rod Cams, SCT Brenspeed Tuned, + other stuff Cammed Crew #2 |
Threads Similar to: why not just replace the bushings.
| Door bushings | Timmano | V6 Mustangs | 7 | January 11th, 2008 10:29 PM |
| Bushings On 88 Vert | ridebmxfbm | 5.0 Mustangs | 1 | November 19th, 2007 03:29 PM |
| bushings | superbeef1000 | 99-04 | 4 | August 12th, 2007 06:27 PM |
| Help with Bushings | Flomaster_Knockoff | General Tech | 0 | May 19th, 2007 01:37 PM |
| How to remove factory door pins and bushings to replace!! | 91GRNGT | 5.0 Mustangs | 8 | October 16th, 2006 09:47 PM |
