gear whine???
Old June 3rd, 2008, 12:50 PM   #1
06SuperStang's Avatar
2006 Mustang GT
06SuperStang is on a distinguished road
gear whine???
i just recently had a set of frrp 3.73 gears installed in my 06 GT (auto) and i wanted to know what was causing the gear whine whenever i let off the throttle then about 35mph it stops. i always thought you can hear gear whine when your on the throttle not when your slowing down. can anyone tell me whats causing this? thanks
2006 Mustang GT (Auto),FRPP Hot Rod Cams,Hooker Longtubes w/ Off Road X-Pipe,Stock Mufflers,TCI 3000 Stall,Delete Plates,C&L Racer CAI,Tuned By The Guys From American Muscle,FRPP 3.73's,Coast Line Full Length DriveShaft
Old June 3rd, 2008, 01:00 PM   #2
MM's resident Juice head
07 STROKER's Avatar
07 Mustang GT
07 STROKER is a splendid one to behold07 STROKER is a splendid one to behold07 STROKER is a splendid one to behold07 STROKER is a splendid one to behold07 STROKER is a splendid one to behold07 STROKER is a splendid one to behold
improper backlash???
The MGW short throw shifter
Its not just a shifter...It's a lifestyle!
Old June 3rd, 2008, 01:06 PM   #3
2006 Mustang GT
thats what i was told i just wanted to make sure. is this an easy fix?
Old June 3rd, 2008, 01:08 PM   #4
07 STROKER's Avatar
07 Mustang GT
i wouldint touch gears myself...and i do all my own wrenching...take it to a shop...if you havent broke the gears in too bad they might be able to adjust the backlash.
Old June 3rd, 2008, 01:12 PM   #5
2006 Mustang GT
i only have about 180 miles on them
Old June 3rd, 2008, 01:33 PM   #6
2006 Mustang GT
would it be to much or not enough backlash?
Old June 3rd, 2008, 01:36 PM   #7
07 STROKER's Avatar
07 Mustang GT
I think...not enough....dont quote me though..like i said i dont mess with gears.
Old June 3rd, 2008, 01:42 PM   #8
2006 Mustang GT
ok thanks
Old June 3rd, 2008, 01:44 PM   #9
07 STROKER's Avatar
07 Mustang GT
n osweat
Old June 3rd, 2008, 03:16 PM   #10
May 08 ROTM
2008 Audi S6
Emay has much to be proud ofEmay has much to be proud ofEmay has much to be proud ofEmay has much to be proud ofEmay has much to be proud ofEmay has much to be proud ofEmay has much to be proud ofEmay has much to be proud ofEmay has much to be proud ofEmay has much to be proud of
Super stang, you have gotten the dreaded coast whine. It's not only a backlash issue. The same sort of whine can occur on improper bearing preload. You may want to ask your installer exactly how he went about the preload on them, sometimes that is a difficult conversation because immediately your placing blame on there skills. Wether it's a lack of backlash issue, or a preload issue, you'll get a coast whine.
Your installer is likely to say, "I don't preload the bearing via torque spec, I do it by feel". This is common, but these s197 rear ends are finicky and will make noise in both scenerios. Feel out your installer, spec is 16-26 in lbs.
Old June 3rd, 2008, 05:14 PM   #11
qwik48r's Avatar
alotta shit
no fat girls fast
qwik48r is a jewel in the roughqwik48r is a jewel in the roughqwik48r is a jewel in the rough
Send a message via AIM to qwik48r
dont feel bad man, i've got a bad coast whine too... Motives are coming out veryyyyy soon....
mind your business what i drive... i'm on a fucking mustang forum.
qwik's build
Old June 9th, 2008, 06:10 PM   #12
2006 Mustang GT
got the car back today from the intaller and he told he h made some changes with the backlash issue but it still has a lil coast whine and now it has a slight vibebration when i turn to the right then i stops when the car straightns up. anyone know the cause of this?
Old June 9th, 2008, 06:16 PM   #13
Moderator
I have the same issue on mine, Super. My installer told me it was improper backlash or bearing preload, as Emay said. Fortunately he's a stand up guy, and I don't have to worry about playing games with him to get it right.
Old June 9th, 2008, 06:20 PM   #14
mustangrebuilder will become famous soon enough
yeah emay is right about what could be wrong with it.
but if they are going to fix it, have them check if there is any wear on them.
you may only have 180 miles on them but that could still mess them up bad enough that you cant use them
Old June 9th, 2008, 06:25 PM   #15
2006 Mustang GT
i guess ill have to take it to ford and have them look at it
Old June 9th, 2008, 06:47 PM   #16
alot of ppl dont liek to mess with there own gears but i dont think that they are that hard to do, they do take time, but if somethign is wrong at least you know what you did.
if someone else did it, you have know idea what backlash, pre load, shims etc they used.
Threads Similar to: gear whine???
Weird gear whine Cricket 99-04 7 April 13th, 2008 09:36 PM
3.73's/4.10's - gear whine? Timber 99-04 15 December 11th, 2007 08:59 AM
Gear Whine? DanTheMan 99-04 30 December 10th, 2007 07:32 PM
gear whine? 94v6blkndred V6 Mustangs 5 July 6th, 2007 12:44 PM
Engine whine Tr1gger 5.0 Mustangs 12 April 19th, 2007 09:41 PM
