Gears
Old November 4th, 2006, 08:30 AM   #1
acehogg69's Avatar
06 GT with bolt ons
I sucked
acehogg69 is on a distinguished road
Gears
Has anyone put there own rear end gears in? I have toyed around with them but it's been years ago. My 06 only has 5K on it so would I really need the seal kit? Also what is the shims all about?
Old November 4th, 2006, 08:38 AM   #2
RLY SRS
ChrisJ's Avatar
ChrisJ has much to be proud ofChrisJ has much to be proud ofChrisJ has much to be proud ofChrisJ has much to be proud ofChrisJ has much to be proud ofChrisJ has much to be proud ofChrisJ has much to be proud ofChrisJ has much to be proud of
iTrader: 9 reviews
I would not recommend putting your own gears in...
The shims are to get the angle just right...
Anytime you open up the rear-end of a car I reccomend new bearings and seals...Rather be safe then sorry...And since you are going to be right there why not...
Facebook
Google+
Old November 5th, 2006, 01:38 AM   #3
metu107 is on a distinguished road
Had 4:10's put in my 05. The mechanic said he would more than likely need the bearing which he did. If you use Ford Racing parts they will come with a small variety of shims that will probably do the job. As far as gaskets, they use a cyclicone sealant so don't bother but you should let a tech handle this job.
Old November 5th, 2006, 02:19 AM   #4
FireryDriver is on a distinguished road
yes from all that I've read, installing the gears is just not worth the amount of time and effort required. Much faster and easier to let someone else do it and it's not too expensive for the install.
SLP Loud mouths
SLP x-pipe
4.10 gears
K&N intake
X-Cal II custom tune
Threads Similar to: Gears
3.73 gears or 4.10 gears? I need to get away from the 3.31's 07torchgt 2005 - 2010 91 November 11th, 2007 01:25 AM
T-Loc or Gears? Nick_Rapitis V6 Mustangs 24 May 13th, 2007 05:18 PM
Gears Sh0gun! V6 Mustangs 12 April 3rd, 2007 02:26 PM
gears 4.6gtmarine 99-04 7 April 3rd, 2007 11:23 AM
Gears? gregkelley 5.0 Mustangs 4 March 25th, 2007 05:34 PM
