LinkBack (1) | Thread Tools |
#1
2005 Mustang GT
10.32@137.70
Bent BMR LCA Relocation Bracket
I was bored and decided to go ride around tonight. I raced a Z28 on a secluded highway. We went from a 50 roll and when I shifted into 3rd at 80 mph I heard a loud pop and the car felt funny. I slowed down and realized the steering wheel wasn't centered anymore, it was about 1/8 of a turn to the right and when I put it straight the car would pull to the left. I knew something was messes up and came straight home.
I found the passenger side LCA relocation bracket had twisted and bent. I could notice that the rear end wasn't centered in the car anymore and the driver side tire was about 1" closer to the front of the wheel well. The passenger side tire was about 1" closer to the rear of the wheel well. I am not sure what exactly happened to cause this and the instructions say to weld them in if your 60' times are below 1.5 sec. but this was at 80 mph. Has anyone else had this happen to them? I have rod ends on the upper and lower control arms so there isn't any flex back there. I also noticed a few things about the computer when shifting above 7000 rpm. I shifted from 2nd to 3rd around 7800 rpm and I got a check engine light and a code for P1270 engine rpm or vehicle speed limiter reached, P1704 trans system problems, and P0460 fuel level input circuit malfunction. Then the fuel gauge went to empty and stayed there for 2 minutes and came back up and operated normally.
326 cubic inches of Turbocharged hell will be running soon Tuned by Wes @ TPS ![]() |
2005 Mustang GT
10.32@137.70
some where around there may have been 7700 or 7900, the factory tach isn't that friendly for seeing rpm increments
2006 Mustang GT
11.45@123.61
![]() ![]() iTrader: 2 reviews
there are a few threads about the BMR control arms being bent under high torque loads.
Hopefully you were at least WAY ahead of the Z28. secluded highway in Houma????
Stock for now.
2002 Supercharged HD F150
'02 Supercharged Harley-Davidson F-150 '05 Mustang GT (Sold) |
2005 Mustang GT
10.32@137.70
car likes the rpm, the motor was balanced and blue printed. I was seeing 17 psi on my autometer boost gauge which is 2 psi off low so car makes 19 psi at that rpm
2006 Mustang GT
12.76@105
With that much power I would definitely weld them in. Mine are welded in and my 60's are only 1.75.
Before I had them welded I would hear a pop on launch every once in a while which is why I had them welded. |
#8 | |
10.0@136 mph 1/4
2006 mustang GT, 10.0 at 136 mph, 1/4 with old build. New build in progress for low 9s. (sold) srt10 coupe (stock) for street, 505 ci, previousy viper gts, before that C5Z06. |
yeah so basically what you're saying is breaking the stock stuff isn't good enough for you. now your going for the basic after market stuff too
![]() heads, cams, and eforce using up all the air around |
#10 | |
2006 Mustang GT
11.45@123.61
Stock for now.
Skirt Chasing Philanderer
Kit Car/Ducati/Explorer
Nike Fast
Welcome to wild world of high HP/TQ cars... It seems like I work on my 91 for three hours for every hour I drive it. Hope you get it squared away soon so you can gt back on the roads giving mustangs a good name.
Might want to consider writing down what is said above, it will help you at some point or another in your life!
#12 | |
2005 Mustang GT
10.32@137.70
just letting the consumers know what isn't working for me....its fun to break anything stock or aftermarket....
hahahaha yeah, it's fun till you spend money on something you already have that could be going to something like say oh those twins, or that auto tranny
2005 Mustang GT
10.32@137.70
that is true, I talked to a guy last night who is doing a twin 61mm setup on a 2001 2V and he was amazed that the brackets bent without me launching the car hard
LinkBack to this Thread: http://www.moddedmustangs.com/forums/2005-2010/74656-bent-bmr-lca-relocation-bracket.html
| Bent BMR LCA Relocation Bracket | This thread | Refback | June 8th, 2008 06:35 AM | |
Threads Similar to: Bent BMR LCA Relocation Bracket
| got my LCA,s ? | Bluehorse | 2005 - 2010 | 15 | May 19th, 2008 08:28 PM |
| steeda uca and lca | njstang | 99-04 | 2 | May 8th, 2008 01:19 PM |
| Wheel hop after UCA/LCA install | jivepepper | 99-04 | 7 | May 5th, 2008 12:32 AM |
| LCA Relocation Bracket | orangemonster | 2005 - 2010 | 14 | April 8th, 2008 12:54 PM |
| lca and pan bar | jat | 2005 - 2010 | 7 | June 15th, 2007 11:50 AM |
