C&L Trueflow intake system with "No-Tune" Calibration
Old June 7th, 2008, 08:45 AM   #1
DarkCandy08GT's Avatar
DarkCandy08GT is on a distinguished road
Has anyone used this version. It is said to deliver 17-20 HP with the insert and then can be removed when ready to get a tune.
Old June 7th, 2008, 11:53 AM   #2
Goldcomet's Avatar
2007 Mustang Gt
Goldcomet is on a distinguished road
I'm thinking about this too. 6-700 dollars for a cai and tuner is a little much for me right now. There are a couple of people on this site running no tune Airraids and seem to be happy with them, but I like the way the C&L Street is built. It looks like it'll hold up a really long time and doesn't cost much more than the plastic ones.
Old June 7th, 2008, 12:09 PM   #3
One Man Wolf Pack
06RedfireGT's Avatar
2006 Mustang GT
13ish....maybe
I like the racer over the street because the intake tube is plastic and will not retain heat like the street intake, plus it's cheaper.
ΜΟΛΩΝ ΛΑΒΕ
Old June 7th, 2008, 07:56 PM   #4
MRV
MRV's Avatar
2007 Mustang GT 5M
15.234@91.91*
MRV is on a distinguished road
I've had the C&L street, and now have the Airaid. I was more impressed with the quality of the materials and the fit and finish of the Airaid. Plus, it doesn't have the C&L's metal intake tube, which will hold more heat than the Airaid's plastic tube.
But the racer doesn't offer a "no-tune" option ...no?
Airaid CAI -- FRPP GTAs -- Appearance Items
* 14.13@99.01 when corrected for Bandimere's 5,860-foot elevation!
Old June 7th, 2008, 07:57 PM   #5
TheUNZippee!'s Avatar
I agree with MRV. I too have the Airaid, and it just looks like it belongs. My dyno numbers proved that it gets results as well.
BONER CREW EMPLOYEE - BWAL, CEO
Originally Posted by My Wife
Old June 8th, 2008, 12:26 AM   #6
BLACJAC's Avatar
2006 GT
13.69
BLACJAC is on a distinguished road
hmmmmm!! cai!
yea airaid is the one hahahaahahaha
BORLA STINGERS,FORD RACING GEARS 3:73/,AIRAID CAI ,vast int. & ext. JEWELRY
Old June 8th, 2008, 01:45 AM   #7
2005 Mustang GT
SKRAPR is on a distinguished road
The point of an CAI is to process more air through the motor . . . no? So if the Airaid is adding more air . . . how is it that you do not have to re-tune? I have the C&L Racer. Not knocking the Airaid . . . just wondering how it works.
Skrapr
2005 Mustang GT (5-spd Manual)
FRPP 4.10's
Kooks LT's | Kooks Cat'd X
C&L Racer CAI
Dyno'd | SCT-X3
MGW Shifter | MGW Interior Details
Comp XFI SPR Stage-II's
Old June 8th, 2008, 02:00 AM   #8
gragra73's Avatar
2006
gragra73 will become famous soon enoughgragra73 will become famous soon enough
IMO if money is tight then just get a tuner. You can do more w/ a tuner than you can with a CAI. The power gains w/ just a tuner are impressive.
RIP 06 Mustang GT
New Ride 04 GTO
K&N intake, Dynatech Long Tube Headers, Magnaflow catted X, Flow 40s, MS3 Cam and dynotuned by Texas Speed.
Old June 8th, 2008, 12:20 PM   #9
Goldcomet's Avatar
2007 Mustang Gt
I was thinking about getting a tuner first also. From what I read, both show an approx increase of 16-17HP. I am a little leary of messing with the factory tune though, I only have 3800 miles on my car. I'll probably loosen up after I get more miles on it though I'm tempted to get more out of it after reading everyone else's results.
Old June 8th, 2008, 12:22 PM   #10
Goldcomet's Avatar
2007 Mustang Gt
I'd also like to get a set of 3.73 or 4.10's. I have an automatic so if I do gears I'll probably do 3.73's.
Old June 8th, 2008, 01:50 PM   #11
BLACJAC's Avatar
2006 GT
13.69
Airaid Cai
FOR SKRARP ITS A VOLUME OF AIR VS. SPEED OF THE AIR , this may helpAIRAID Filter Company
Old June 8th, 2008, 02:57 PM   #12
gragra73's Avatar
2006
Then you would want a tuner. If you have gear installed and don't set it to the correct gears, your speed-odometer will be off. A tuner has the option to select the gearing.
RIP 06 Mustang GT
New Ride 04 GTO
Old June 8th, 2008, 03:23 PM   #13
J2L06GT's Avatar
J2L06GT is on a distinguished road
The Throttle Body is what controls the amount of air going thru the engine.
The CAI just remove some of the restriction in the inlet path.
The reason you need a tune with some brands is when you
mount the MAF in a differant diameter tube you change the
velocity of the air going past it for any given throttle position
so the PCM has to be recal'd to keep A/F ratio correct.
Old June 8th, 2008, 03:38 PM   #14
Softcore Porn Enthusiast
oldernewbie's Avatar
Chebby Colorado 5 Banger
Redlines In Neutral
oldernewbie will become famous soon enougholdernewbie will become famous soon enough
Send a message via AIM to oldernewbie
I'm happy with my Airaid w/no tune as yet. I can't document any power gains, but my mileage improved by about 3 mpg on the big hiway.
2005 Colorado LS, Z71 Off Road Package, I5 Vortec, Space Age Plastic Bed-Liner W/Shiny Factory Installed Deep Drop Tool Box, Twin 12 Volt Power Points...In A Whopping 200+ HP Beast.
Old June 9th, 2008, 09:15 AM   #15
MM's resident Juice head
07 STROKER's Avatar
07 Mustang GT
07 STROKER is a splendid one to behold07 STROKER is a splendid one to behold07 STROKER is a splendid one to behold07 STROKER is a splendid one to behold07 STROKER is a splendid one to behold07 STROKER is a splendid one to behold
Ive just ordered my C&L racer and finally tossing my K&N
The MGW short throw shifter
Its not just a shifter...It's a lifestyle!
Old June 11th, 2008, 01:32 PM   #16
02StangGToWNEr's Avatar
2006 Mustang GT
02StangGToWNEr is on a distinguished road
It's about damn time, and it's good to see that you came to your senses.
Threads Similar to: C&L Trueflow intake system with "No-Tune" Calibration
Steeda "Adaptive Performance Calibration" killermach1 2005 - 2010 17 February 29th, 2008 12:41 PM
Fabulous Fords Forever, Knotts Berry Farm 2008 & Cruise "The Mile of Mustangs" WIKDVNM Northwest 0 January 12th, 2008 01:52 AM
Fryrice quoted in MM&FF!...Joe...we need this article back !...."Mods For Dummies" Fryrice The Clubhouse 56 December 22nd, 2007 06:33 PM
