Installing Plenum/Intake/Engine Cover
LinkBack (1) Thread Tools
Old June 14th, 2008, 01:25 PM   #1
Top Down, Crunked Up
MamaStang's Avatar
2005 Mustang GT
Fast Enough for this old broad
MamaStang has a reputation beyond reputeMamaStang has a reputation beyond reputeMamaStang has a reputation beyond reputeMamaStang has a reputation beyond reputeMamaStang has a reputation beyond reputeMamaStang has a reputation beyond reputeMamaStang has a reputation beyond reputeMamaStang has a reputation beyond reputeMamaStang has a reputation beyond reputeMamaStang has a reputation beyond reputeMamaStang has a reputation beyond repute
Guys, I need help please...
Got my plenum cover yesterday. It fits perfectly and looks beautiful. Unfortunately, they didn't send any hardware or instructions.
So we stuck it on there and discovered that the bolts there should work. Took the bolts off but they don't fit through the front part. The back ones we figured it would be okay to just stick the black caps on over the top but the front bolts are too wide to go through the rubber grommets that are on it.
Any suggestions from anyone?
Thanks guys!
Bassani & Topless Vert Crew Member #4
Let Me Help You Shop For The Ladies In Your Lives This Year!
Click Here For Info
Old June 14th, 2008, 01:27 PM   #2
05mustang_TT_charged's Avatar
2005 Mustang GT
10.32@137.70
05mustang_TT_charged is a jewel in the rough05mustang_TT_charged is a jewel in the rough05mustang_TT_charged is a jewel in the rough05mustang_TT_charged is a jewel in the rough
any pictures to see what isn't fitting
350 rwhp and 310 rwtq at 6000 rpms through stock exhaust system
326 cubic inches of Twin Turbocharged hell will be running soon
Tuned by Wes @ TPS
Old June 14th, 2008, 01:28 PM   #3
MamaStang's Avatar
2005 Mustang GT
Uno momento, por favor.
Click Here For Info
Old June 14th, 2008, 01:49 PM   #4
One Man Wolf Pack
06RedfireGT's Avatar
2006 Mustang GT
13ish....maybe
ΜΟΛΩΝ ΛΑΒΕ
Old June 14th, 2008, 01:55 PM   #5
MamaStang's Avatar
2005 Mustang GT
Originally Posted by 06RedfireGT View Post
You're cute when you sit quietly and wait
Click Here For Info
Old June 14th, 2008, 02:00 PM   #6
MamaStang's Avatar
2005 Mustang GT
Pics
K...
Here's the cover pushed down over the top of the 2 bolts in the front where the intake tube connects to the ugly black thingyn (plenum I assume?) that I'm covering up:
Here's what it looks like when I lift it slightly - you can see the bolts...we just stuck them back in but the bottom part of the bolt under the washer is too large to go through the holes on the cover:
Side view:
This is the little black cap thing that is taped to the wire covers - it just slides over the top of the bolt that is holding the back part down so we stuck the plenum cover over the bolt and pushed the cover back on over the top of it:
Surely I don't need different bolts for the front of it???
Click Here For Info
Old June 14th, 2008, 02:48 PM   #7
MamaStang's Avatar
2005 Mustang GT
Bump
Click Here For Info
Old June 14th, 2008, 02:54 PM   #8
2005 Mustang GT
10.32@137.70
You have pretty hands.
I am checking right now and should know in a couple minutes.
Tuned by Wes @ TPS
Old June 14th, 2008, 02:58 PM   #9
2005 Mustang GT
10.32@137.70
Here is what I could find.....
PLENUM COMES WITH 2 STUD/NUT FASTENERS WHICH REPLACE THE 2 UPPER THROTTLE BODY BOLTS. INSTALL THE 2 STUD/NUT FASTENERS FIRST INTO THROTTLE BODY. PLENUM SIMPLY SLIPS OVER THE ENDS OF THE STUDS AND THEN PUSHED OVER THE 2 FUEL RAIL STUDS IN THE BACK. YOU DON'T NEED TO DRILL OR FORCE OR MODIFY AS SOME HAVE TRIED (??) THE PLENUM COVER DOES NOT GO UNDER THE NUTS ON THE STUDS!!! DON'T MAKE IT HARD!
Tuned by Wes @ TPS
Old June 14th, 2008, 03:03 PM   #10
MamaStang's Avatar
2005 Mustang GT
Thank you!
So it sounds like there was hardware that should have come for the front two bolts?
Is that how you're reading it?
Click Here For Info
Old June 14th, 2008, 03:04 PM   #11
2005 Mustang GT
10.32@137.70
yes, there should have been 2 bolts with studs that replaced the top bolts on the throttlrbody.
Tuned by Wes @ TPS
Old June 14th, 2008, 03:05 PM   #12
MamaStang's Avatar
2005 Mustang GT
Guess I'll have to call them Monday. I knew $75 was too cheap...should have shelled out the cash for something else...
Click Here For Info
Old June 14th, 2008, 03:07 PM   #13
2005 Mustang GT
10.32@137.70
If I remember correctly the 2 lower bolts on your throttlebody are studs and can be swapped to the top and the top to the bottom. It might work but I am not sure since I haven't had a stock intake on my car in 2 years.
Tuned by Wes @ TPS
Old June 14th, 2008, 03:08 PM   #14
2005 Mustang GT
10.32@137.70
you can pick up the bolts at any Ford dealer for $5 and make it fit. That is a Factory Ford Plenum so they are installing them on thousands of cars. They would have them over there.
Tuned by Wes @ TPS
Old June 14th, 2008, 03:09 PM   #15
MamaStang's Avatar
2005 Mustang GT
You mean turn them over???
Click Here For Info
Old June 14th, 2008, 03:10 PM   #16
MamaStang's Avatar
2005 Mustang GT
Well it is going in on Wednesday but figured I'd save myself a little cashola AND impress them by doing it myself So if I can't get it to work, no biggie.
Click Here For Info
Old June 14th, 2008, 03:10 PM   #17
2005 Mustang GT
10.32@137.70
I am not sure you would have verify the lower ones are studs. Not turn it over just swap the top and bottom bolts.
Tuned by Wes @ TPS
Old June 14th, 2008, 03:12 PM   #18
MamaStang's Avatar
2005 Mustang GT
The ones in the back seem to be pretty securely attached. The 2 in the very front have a fatter end and a skinnier end with a bold head and washer in the middle. The washer is obviously free turning but the hold head is solidly attached at about the upper 1/3 of the bolt. The fat end is the end that is currently in there.
I'm not sure what you mean by "top and bottom" - the fat end and skinny ends???
Click Here For Info
Old June 14th, 2008, 03:26 PM   #19
2005 Mustang GT
10.32@137.70
The 4 bolts that hold your throttlebody on. They have 2 on top and 2 on bottom of the throttlebody that bolt it to the intake manifold.
Tuned by Wes @ TPS
Old June 14th, 2008, 03:28 PM   #20
tribaltek's Avatar
tribaltek has a spectacular aura abouttribaltek has a spectacular aura about
Damn I want to get one of these!
'06 Whipple'd Mustang GT (Coming Soon)
'02 Supercharged Harley-Davidson F-150 (Sold)
'05 Mustang GT (Sold)
LinkBack to this Thread: http://www.moddedmustangs.com/forums/2005-2010/75813-installing-plenum-intake-engine-cover.html
Installing Plenum/Intake/Engine Cover - Page 2 This thread Refback June 14th, 2008 09:58 PM
Threads Similar to: Installing Plenum/Intake/Engine Cover
Finished installing Plenum, Bad News MyGT 99-04 11 April 29th, 2008 05:55 PM
Installing valve cover breather jam77 5.0 Mustangs 23 December 27th, 2007 05:53 AM
Just Got My New Plenum Cover... Bossman 2005 - 2010 29 September 28th, 2007 06:42 PM
Intake Plenum Mustang Mike 99-04 10 July 28th, 2007 06:28 PM
Plenum cover or strut brace?? dave07GT 2005 - 2010 18 February 14th, 2007 04:32 PM
