Tomorrows projects
Old June 14th, 2008, 10:33 PM   #1
tribaltek's Avatar
tribaltek has a spectacular aura abouttribaltek has a spectacular aura about
Tomorrows projects
Well, today I fixed my water leak, which was huge, and then I painted my GMS Radiator Support, because it was blue!!! Yikes! I used flat black engine enamel to paint it. Came out great.
Tomorrow I'm going to try to get the following accomplished -
1) Install drilled rotors and new pads
2) Paint calipers
3) Remove stock sway bar and stock radiator support
4) Install GMS radiator support
5) Install Prothane motor mounts (I guarantee I wont have time for this, but I'll try)
Wish me luck!
'06 Whipple'd Mustang GT (Coming Soon)
'02 Supercharged Harley-Davidson F-150 (Sold)
'05 Mustang GT (Sold)
Old June 14th, 2008, 10:50 PM   #2
One Man Wolf Pack
06RedfireGT's Avatar
2006 Mustang GT
13ish....maybe
Hey man you should do a write up for that stuff
ΜΟΛΩΝ ΛΑΒΕ
Old June 14th, 2008, 11:03 PM   #3
tribaltek's Avatar
I spoil you all with a few pictures of my leak, now you want write-ups?
I'll see what I can do
Old June 14th, 2008, 11:14 PM   #4
One Man Wolf Pack
2006 Mustang GT
13ish....maybe
Sweet.
ΜΟΛΩΝ ΛΑΒΕ
Old June 14th, 2008, 11:24 PM   #5
tribaltek's Avatar
OK, I finished the write-ups
Rotors - Rotorpros Cross-Drilled/Gas Slotted rotors install (w/pics) - The Mustang Source Forums
Radiator Support - BMR Swaybar Delete Kit Install - The Mustang Source Forums
Prothane Mounts - Prothane Bullet Motor Mount install (w/pics and vids) - The Mustang Source Forums
Man, that was tough!!!
Old June 15th, 2008, 01:49 AM   #6
May 08 ROTM
2008 Audi S6
Emay has much to be proud ofEmay has much to be proud ofEmay has much to be proud ofEmay has much to be proud ofEmay has much to be proud ofEmay has much to be proud ofEmay has much to be proud ofEmay has much to be proud ofEmay has much to be proud ofEmay has much to be proud of
Tribal, I been doing these without pulling the motor support bracket, the motor can be raised enough to get the oem mount out from under the bracket no problem. The prothanes go in easier since they are shorter in height.
FLICKR Unique Imagery
Old June 15th, 2008, 02:43 AM   #7
mustang fanatic's Avatar
Dont Tread On Me
mustang fanatic will become famous soon enoughmustang fanatic will become famous soon enough
Send a message via AIM to mustang fanatic Send a message via Yahoo to mustang fanatic
How are the prothanes on driving? Are they alot louder? I heard they create alot louder cabin noise!
2007 Mustang GT - Pretty much stock. Pypes pypebomb a/b, Tri-ax shifter.
Old June 15th, 2008, 03:42 AM   #8
scramblr's Avatar
2006 Mustang GT
scramblr is on a distinguished road
Dremel is your friend for the stock mounts. I couldn't get my engine high enough, so I just cut the studs off and they slipped right out. Put the Prothanes in at the same time...and that was with headers already installed. I then swapped the standard size Prothanes for the lowered ones and that was even easier.
11.67 - 1.64 60' @ 119mph
Livernois 298ci Stroker, Saleen S/C, GT500 FPs, SD 60# inj, GT500 T/B, Thump Tensioner, BGG 8 Rib, Kooks, Gords HE, 4.10, TrueTrac, Spec 3+, Pro 5.0
Old June 15th, 2008, 08:35 AM   #9
May 08 ROTM
2008 Audi S6
There is a lot more feedback in the cabin with them. It's not only an audible change, theres an input in feeling as well from the change in rigitity.
Old June 15th, 2008, 08:42 AM   #10
tribaltek's Avatar
Thanks emay. That would save me some time, for sure!
My cams are already bouncing the car around at idle, so I'm sure with these mounts my car is going to visably shake.
Old June 15th, 2008, 11:27 AM   #11
06VistaGT's Avatar
2006 Mustang GT
06VistaGT will become famous soon enough
good luck on getting all that done. Should all turn out pretty sweet.
Dyno vid: http://youtu.be/TkxUrW-mpBw
Old June 15th, 2008, 02:09 PM   #12
tribaltek's Avatar
Well, because of the storms that came through, I've only got my front rotors and pads on at the moment. Going back out to do the rears shortly. I think I'm going to have to defer a lot of this until tomorrow as we've got some wicked weather right now.
Old June 15th, 2008, 06:59 PM   #13
tribaltek's Avatar
OK, so out of everything I wanted to do... I only got #1 done. UGH!!! But they look nice
Old June 15th, 2008, 11:57 PM   #14
ROUSH STAGE II's Avatar
2005 Turbonetics Baby!!!
ROUSH STAGE II is just really niceROUSH STAGE II is just really niceROUSH STAGE II is just really niceROUSH STAGE II is just really nice
The GMS radiator support/sway bar delete should only take about 20-30 minutes if that makes you feel any better.
Turbonetics baby!!!
11.23@122 mph...
Old June 16th, 2008, 08:00 AM   #15
tribaltek's Avatar
Well, I'm taking the car in for 4.10's this morning, so probably won't get to the radiator support, but I'm sure I'll be happy with just having the 4.10's today
Old June 16th, 2008, 08:04 AM   #16
mustangrebuilder will become famous soon enough
^ yeah you should be, but why not just do them your self??? just wondering
Old June 16th, 2008, 08:27 AM   #17
tribaltek's Avatar
The gears? Dude... before I got this car I didn't even change my own oil. I've already done a lot on the car that I didn't think I'd do myself, but I'm not even going to attempt to do my own gears. I'm leaving that one to the pros.
Old June 16th, 2008, 08:44 AM   #18
May 08 ROTM
2008 Audi S6
That's bad advice - not only with Tribal's newness to minor mechanical work, but especially with the variances between FRPP's 4.10 gears which had a production run vended for 6 months to Motive and for the most part guarantee they'll whine when installed by even some of the best rear end setters out there, let alone the backyard mechanics without the skills or mic'ing tools.
Old June 16th, 2008, 08:04 PM   #19
06VistaGT's Avatar
2006 Mustang GT
gears are a bastard to do on your own. Had to help my buddy do his....less then good experience.
Old June 16th, 2008, 08:07 PM   #20
MM's resident Juice head
07 STROKER's Avatar
07 Mustang GT
07 STROKER is a splendid one to behold07 STROKER is a splendid one to behold07 STROKER is a splendid one to behold07 STROKER is a splendid one to behold07 STROKER is a splendid one to behold07 STROKER is a splendid one to behold
i tried gears once myself...i think that rear end is still sitting behind my dads shop in ontario.
The MGW short throw shifter
Its not just a shifter...It's a lifestyle!
Threads Similar to: Tomorrows projects
my projects tom2000r Pictures 3 March 16th, 2008 06:45 PM
this years projects riddlee josh V6 Mustangs 21 January 15th, 2008 04:40 PM
Pics of current projects B Mad Pictures 6 December 27th, 2007 02:26 AM
Winter Projects 2000stangGT 99-04 28 December 12th, 2007 11:53 PM
Tomorrows the day.... lwhitetrash88l V6 Mustangs 1 April 10th, 2007 10:19 AM
