Pinging
Old June 17th, 2008, 12:36 PM   #1
2009 Corvette
Odin is on a distinguished road
Pinging
I'm running a Brenspeed 93 octane tune. I fill up at different gas stations all the time, so maybe it's low quality gas, but on at least 2 occasions I have heard pinging when I'm running hard at WOT (like accelerating onto the highway or playing around on an open stretch of road from a stop.
Is this bad gas or is the tune to aggressive?
2009 C6
Old June 17th, 2008, 12:47 PM   #2
MM's resident Juice head
07 STROKER's Avatar
07 Mustang GT
07 STROKER is a splendid one to behold07 STROKER is a splendid one to behold07 STROKER is a splendid one to behold07 STROKER is a splendid one to behold07 STROKER is a splendid one to behold07 STROKER is a splendid one to behold
your knock sensors shuld pick up pinging and retard your timing accordingly...shouldint they?
The MGW short throw shifter
Its not just a shifter...It's a lifestyle!
Old June 17th, 2008, 12:58 PM   #3
2009 Corvette
I don't know, the minute I hear it I get out of the throttle, but it worries me.
2009 C6
Old June 17th, 2008, 01:40 PM   #4
Mickey's Avatar
Mickey is a splendid one to beholdMickey is a splendid one to beholdMickey is a splendid one to beholdMickey is a splendid one to beholdMickey is a splendid one to beholdMickey is a splendid one to behold
Call Brent and speak to him about it. He will be able to give you a solution.
Under Construction
Old July 10th, 2008, 12:10 AM   #5
2009 Corvette
Pinging with Brenspeed 93 tune and 93 octane gas
I tried loading the 91 tune with 93 gas and the pinging was not as bad, but still there. I then loaded the 87 tune with 93 gas and the pinging was gone.
I called Brenspeed and talked to someone (not brent) and he said either they would pull some timing out of my tunes for me or I could run the 87 tune. he said to keep running 93 gas with the 87 tune, and that the 87 tune would compensate for the 93 gas.
Is there any advantage to running 93 gas with the 87 Brenspeed tune versus just running 87 gas?
Tonight, I installed the 93 tune again (fresh tank of 93 gas) and pulled 1 degree of timing out of the tune (globally, across all RPM ranges). I ran the car up to 6K rmp about 10 times in 1st and 2nd gear and there was no pinging most runs, although on 1 or 2 runs I thought I might have heard a tiny bit of pinging just above 4K rpm.
Should I try pulling another 1 degree of timing above 4K rpm?
I have no idea how much timing the brenspeed 93 tune adds over the 87 tune or over the stock tune. By pulling 1-2 degrees of timing am I screwing up the tune?
The 93 tune didn't seem to ping at all from April until recently, although 2 things have changed since then. First, it's 100 degrees every day, and second I added JBA axle back mufflers a while back. Could the axle backs be causing the pinging?
The car runs noticable faster on the 93 tune, so I'd like to use it if at all possible.
2009 C6
Old July 10th, 2008, 09:25 AM   #6
May 08 ROTM
2008 Audi S6
Emay has much to be proud ofEmay has much to be proud ofEmay has much to be proud ofEmay has much to be proud ofEmay has much to be proud ofEmay has much to be proud ofEmay has much to be proud ofEmay has much to be proud ofEmay has much to be proud ofEmay has much to be proud of
I would rather leave the timing and add some fuel, I guess your tweaking with an xcal so I would datalog the car and see what is happening. How did the car feel during the pulls with the degree removed?
FLICKR Unique Imagery
Old July 10th, 2008, 09:29 AM   #7
07 STROKER's Avatar
07 Mustang GT
i run with 4 degrees removed so i can run nitrous...i just compinsated by adding cams ...but seriously ...before the cams my but dyno did notice some loss but not bad overall.
Old July 10th, 2008, 09:32 AM   #8
2009 Corvette
The car pulled strong with 1 degree pulled out. That's -1 degree from the Brenspeed 93 tune, which I'm sure is advanced from stock. But I think I may have still heard a little ping on one or two runs, so I might try pulling 1 more degree out.
I could make the fuel a little richer but I don't know what I'm doing so I'm hesitant to fool with the AF mixture in the X3.
2009 C6
Old July 10th, 2008, 10:32 AM   #9
05mustang_TT_charged's Avatar
2005 Mustang GT
10.32@137.70
05mustang_TT_charged is a jewel in the rough05mustang_TT_charged is a jewel in the rough05mustang_TT_charged is a jewel in the rough05mustang_TT_charged is a jewel in the rough
I would datalog the mass air count, load, rpm, speed, knock, coolant temp, and stft bank 1 and 2...then post the file up and we can take a look at it...and you might want to email it to Brenspeed for him to check or he might want you to datalog more parameters to see what is happening.
350 rwhp and 310 rwtq at 6000 rpms through stock exhaust system
326 cubic inches of Twin Turbocharged hell will be running soon
Tuned by Wes @ TPS
Old July 10th, 2008, 11:21 AM   #10
2009 Corvette
Unfortunately I have a SCT X3. SCT customer service/tech support is a joke (a forum that nobody from the company answers is their idea of tech support) and their user manual and website don't explain how to get data from the X3 to my computer (I don't have a laptop).
I downloaded the Live Link software from SCT's website but Live Link doesn't even recognize the X3 (it only has an option for the XCal2 and some other devices). I can't get the data from the car to the computer or I'd post it.
2009 C6
Old July 10th, 2008, 12:15 PM   #11
GT33's Avatar
2006
GT33 is on a distinguished road
I have heard from people that the gas quality now is shit..like 93 is 88 and stuff like that and what ur saying it makes sense
Just a bottle and some mufflers)))
18yrs old S.FL
Old July 10th, 2008, 12:31 PM   #12
menace07's Avatar
2007 Mustang GT
13.7 @ 105
menace07 is on a distinguished road
+1...i live in ohio and there was just a big stink in the papers about how ohio didnt re-up the octane certifications, so basically theres no way for me to know if the 93 im buying is actually 93, or is 87.
black 07 GT, jlt2 cai, sct2 brenspeed 93 octane tune, UDP's, spydershaft, triax, magnaflow catted x, steeda axleback, bad ass steeda suspension
Stealth GT Twin Turbo System On The Way!!!!!!!
STEEDA SUSPENSION CREW FOUNDER
Old July 10th, 2008, 02:20 PM   #13
wveil3v's Avatar
98 Mustang GT
wveil3v is on a distinguished road
I have the X3 and the "Livewire Updater" program installed on my PC and it works fine, although I've only used it to download new tunefiles to my X3. I see a "Transfer File" function on the Livewire updater program which is what I've been told transfers datalog files from X3 to computer but never used it.
98gt, pi intake, jlt cai, flowmasters, black bullits, hurst comp-plus, custom hpipe, eibach sportlines, 373gears
Old July 10th, 2008, 02:30 PM   #14
2009 Corvette
Livewire Updater, Live Link, etc... nothing will recognize my X3 I just get connection errors with the device. And I don't know if SCT supports Vista.
2009 C6
Old July 10th, 2008, 03:33 PM   #15
dtom is on a distinguished road
get a bottle of octane booster and see if that helps.then at least you'll know if its the shitty gas.
Old July 10th, 2008, 03:58 PM   #16
2009 Corvette
I have been told by numerous people NOT to use octane boost in new Mustangs because it can cause serious problems with the spark plugs.
2009 C6
Old July 10th, 2008, 07:18 PM   #17
wveil3v's Avatar
98 Mustang GT
Not sure about Vista but have you gone here yet?
SCT Automotive Performance Products
You can at least get LIVE online techsupport to ask if they support VISTA
Old July 10th, 2008, 11:02 PM   #18
2009 Corvette
So I pulled out 2 degrees of timing globally tonight and ran the car, no pinging. Still pulls hard. I'll call brenspeed tomorrow and ask them if this sounds like a good compromise.
2009 C6
Old July 11th, 2008, 03:53 PM   #19
IronStomach's Avatar
2008 Mustang GT
IronStomach has a spectacular aura aboutIronStomach has a spectacular aura aboutIronStomach has a spectacular aura about
SCT doesnt' work with Vista 64bit.
But they give instructions on getting Vista to run non-Vista specific programs through compatibility settings.
SCT's got a pretty thin knowledgebase... but they have a knowledgebase. A lot of the performance car part companies (and vendors!) would do well to implement knowledgebases or extensive FAQs -- they reduce the company's overhead on support related inquiries if they allow their customers to do their own research....
Experience is what you get when you didn't get what you wanted.
Old July 13th, 2008, 08:07 PM   #20
Lenny 2008GT's Avatar
2008 Mustang GT
Lenny 2008GT is on a distinguished road
Having the same problem. Started when temps got into the 80s. Loaded the 91 Brenspeed tune and the pinging stopped completely. I tried the SCT 93 tune and that didn't ping but much less performance. I emailed Brenspeed on Saturday - I'n sure they'll send me a modified tune but looks like you found the answer. Please keep us informed.
2008 GT / Vista Blue / MGW Shifter / Spoiler Delete /
3.55 / FRPP Bullitt CAI / Tuned by Realspeed
Threads Similar to: Pinging
I think my car may be pinging.. need4steed 2005 - 2010 4 February 21st, 2008 01:03 PM
Pinging question? JAY'SRED02 2005 - 2010 4 December 23rd, 2007 12:38 PM
PINGING dammit jbsnake Modular Mustangs 9 October 25th, 2007 10:24 PM
pinging when under a load cobraetti 5.0 Mustangs 4 April 28th, 2007 10:42 AM
Jerking and Pinging pinkthing 5.0 Mustangs 10 September 4th, 2006 02:23 AM
