are lca relocation brackets really needed?
Old June 25th, 2008, 02:58 PM   #1
texas_mustang has a spectacular aura abouttexas_mustang has a spectacular aura about
im lowering my car about an inch, to and inch and a half. now im getting an adjustable panhard bar
but do i really need the lca relocation brackets?
Old June 25th, 2008, 03:05 PM   #2
usafimj's Avatar
2007 Ford Mustang GT
12.847 @ 114.12mph
usafimj is a glorious beacon of lightusafimj is a glorious beacon of lightusafimj is a glorious beacon of lightusafimj is a glorious beacon of lightusafimj is a glorious beacon of light
Send a message via Yahoo to usafimj
i don't think you need them if you don't have LCA's
07 GT-- Gone But Not Forgotten
Military Crew
E-5
Old June 25th, 2008, 03:06 PM   #3
algx's Avatar
2007 REDFIRE VERT GT/CS
algx is on a distinguished road
I think they are needed if you drag race and experience wheel hop.
Look at this thread from Orangemonster "LCA Relocation Bracket", usefull info there...
FRPP Whipple HO, FRPP 4.10, Magnapacks, SSC springs, BMR adj. panhard bar, Hurst Billet STS, 285-40-18 / 255-45-18 BFG T/A
Originally Posted by Violent Acres
...Fat chicks don't suck dick, it makes them hungry...
Old June 25th, 2008, 03:06 PM   #4
i ordered some che lcas
Old June 25th, 2008, 03:14 PM   #5
usafimj's Avatar
12.847 @ 114.12mph
Since your getting CHE LCA's then you should get them. 07stanggt can hook you up
Military Crew
E-5
Old June 25th, 2008, 03:15 PM   #6
k. also, how will i notice my new lcas? like what should i be looking for while driving?
Old June 25th, 2008, 03:20 PM   #7
usafimj's Avatar
12.847 @ 114.12mph
It should help you plant the tires better during launching.
Military Crew
E-5
Old June 25th, 2008, 03:27 PM   #8
k. and if im dropping the car over an inch should i use the second hole?
Old June 25th, 2008, 03:28 PM   #9
usafimj's Avatar
12.847 @ 114.12mph
All these links work together if you decide to do it all at once
BMR Lower Control Arm (LCA) and Relocation Bracket Installation (w/pics) - The Mustang Source Forums
Adjustable Panhard Bar and Lateral Stiffener Bar installation (w/pics) - The Mustang Source Forums
Steeda Billet LCA install (w/pics) - The Mustang Source Forums
Military Crew
E-5
Old June 25th, 2008, 04:01 PM   #10
well i also got camber adjusters from steeda. what will these do?
Old June 25th, 2008, 04:07 PM   #11
2007 GT
07stanggt has much to be proud of07stanggt has much to be proud of07stanggt has much to be proud of07stanggt has much to be proud of07stanggt has much to be proud of07stanggt has much to be proud of07stanggt has much to be proud of07stanggt has much to be proud of
LOL trust mean you wont have to look. you will notice them right away. even my son got in my car and said what did you do to the suspension.
Old June 25th, 2008, 08:17 PM   #12
Kobie's Avatar
2007 GT
Kobie is on a distinguished road
What type of driving do you plan to do? Drag race? Road race/Autocross?
Old June 25th, 2008, 08:40 PM   #13
im doing road race type racing
im getting FRPP shocks and struts, FRPP lowering springs, eibach front and rear swaybars, che lower control arms, and steeda camber adjusters
im also about to buy an adjustable panhard bar and BMR lca relocation brackets
Old June 25th, 2008, 09:53 PM   #14
Kobie's Avatar
2007 GT
Ok. My suggestions are...
Steeda LCA brackets. They have more adjustment holes. You will need them to get the arms where you want them. Level to pointing up slightly at the rear of the car.
UMI lower control arms with poly ( car end ) spherical rod ( axle end ) This will net a quieter ride with a more free axle movement. Critical!
UMI panhard rod with dual spherical rod ends. Ok, a little more rear end noise, but FAR more effective axle location. Big difference between this and poly/poly bar.
Dont forget the panhard bar upper brace!
Old June 25th, 2008, 09:58 PM   #15
Kobie's Avatar
2007 GT
Forgot to mention... Steeda competition upper control arm with mount. Absolutely the best upper mount available.
If you need part numbers for all of the above I will dig them up!
Old June 26th, 2008, 07:04 AM   #16
MaverickMLFD371's Avatar
2005
MaverickMLFD371 will become famous soon enough
Send a message via AIM to MaverickMLFD371 Send a message via Yahoo to MaverickMLFD371
get a panhard bar brace when you purchase the panhard bar for the added support & strength.
Threads Similar to: are lca relocation brackets really needed?
Driveshaft/LCA/brackets/UCA 07stanggt 2005 - 2010 10 June 19th, 2008 08:18 PM
Bent BMR LCA Relocation Bracket 05mustang_TT_charged 2005 - 2010 13 June 7th, 2008 04:55 PM
got my LCA,s ? Bluehorse 2005 - 2010 15 May 19th, 2008 07:28 PM
steeda uca and lca njstang 99-04 2 May 8th, 2008 12:19 PM
LCA Relocation Bracket orangemonster 2005 - 2010 14 April 8th, 2008 11:54 AM
