2007 Mustang GT
Front Rotors
ok here is what i am looking for.........a stock replacement rotor, drilled/and or slotted............i just want a good high performance rotor that i can use my stock calipers, AND i want to stay factory size incase i get the 15" skinnies.....what have you guys had good luck with? I need a rotor that will hold up to HEAVY braking from speeds over 100 mph, which the stock rotors cannot handle. thanks
Bassani Crew Member #3 |
07 GT-- Gone But Not Forgotten Military Crew E-5
2007 Mustang GT
well i need some opinions if i go with a setup like that..........what are your guys preferences, drilled or slotted?..........i drag race, so it is just go fast, then slam on the brakes, no corner carving for me, but they still need to be able to last on the street.
2007 GT
didnt click on the kit, i assume its the stoptech stage II kit? i have that kit on my car, i can also sell it to you.
What do i think of the kit. its good for what it is. i road raced my car on the stock setup and found no problem with the stoping ability on it, and thats from 130mph, the problem was heat, after the first couple laps they were so hot and the fluid would boil, pedal would just fade. thats is not an issue at the strip, your doing 110 maybe, they will hold fine, not even getting that hot. But either way its a good kit, the braided lines will make your brake pedal feel a lot more solid even on the street. as for drilled or slotted, i got drilled cuase i like the looks, neither one is better then the other for your use. |
2007 Mustang GT
the problem i have is the rotors becoming too hot, glazing the pads, and the rotors becoming warped, badly..........i also do a little street racing, and we usually have to get on the brakes VERY hard afterwards (rarely do i street race, but sometimes it just happens)...........i am wanting a setup that can stand the heat, not warp (no i do not slam on the brakes before i hit water lol), and still be factory size for maybe a future 15" front wheel.
#6 | |
2007 GT
then get the stop tech kit. its is good. drilled or slotted depending on what you like. if thats to much let me know, its a good kit, i can get you some off on that bren price and i can piece it together for you. that isnt a real kit from stoptech anyway they peiced it together. |
07 Mustang GT
i heard the rotorpros on ebay are pretty good
07 Mustang GT
2006 Mustang GT
11.67 - 1.64 60' @ 119mph Livernois 298ci Stroker, Saleen S/C, GT500 FPs, SD 60# inj, GT500 T/B, Thump Tensioner, BGG 8 Rib, Kooks, Gords HE, 4.10, TrueTrac, Spec 3+, Pro 5.0
I found mine on eBay... just an option... stock size and zink coated=no rust where the pads don't run
![]() 2.6l KENNE BELL 298 Stroker, Ported heads Pro Motion Built 3650/McLeod RST/ MGW Short Throw Long tube/O/R X /Borla Touring 8 rib/65 lb injectors/GT500 twin fuel ET Drag Slicks/3.73 gear Detroit Truetrac /CDC AGR Spoiler |
2006 GT
11.99@114
I have the Stoptech stage II kit, great for dd and the 1/4 mile.
![]() 2006 GT (Fastest) 2004 COBRA (Faster) 1990 LX 5.0 (Fast) |
I have the DecelaRotors and am happy
2006 Mustang GT
Bunch of questions: How long have you had them? Driven in rain? Rust? What pads? How's the noise? Thx...
IBEATU
06 GT, 98 GT, & 93 Notch
![]() 98 GT: some stuff 06 GT: more stuff 93 Notch: 4 cyl at birth, now 5.0 drivetrain and stock exterior and interior= True Sleeper Paxton/Vortech Crew Member #3 FRPP's #1 Dealer Injected Engineering BMR Suspension |
I got double-drilled rotorpro's on eBay.
'06 Whipple'd Mustang GT (Coming Soon) '02 Supercharged Harley-Davidson F-150 (Sold) '05 Mustang GT (Sold) |
go on ebay and get a set of front & rear drill/ slotted rotors with brakes pads all around for about +/- $200-$300. Then get some front & rear StopTech Stainless Steel Brake Lines for $180
Get the powerslot roters, some stainless braided lines, and hawk performance pads that should give you noticably better braking and not bust the bank.
2006 Mustang GT
11.74 @ 119
I use Rotorpros drilled and slotted front and rear; along with Centric Posi-Quiet pads. Night and day difference over stock? No. Noticeable increase in stopping and holding power? Yes. I'd recommend these to anyone that is not heavily road racing.
tom281 2006 Mustang GT 11.74@119 w/ 3880lb race weight Tuned by Brent at Brenspeed www.brenspeed.com |
+1 on the Rotorpros they have a screamin deal on rotors with Hawk pads and I've found the owner there to be very responsive and decent to deal with.
Threads Similar to: Front Rotors
| rotors and such | joejoe8455 | 99-04 | 7 | April 10th, 2008 08:13 AM |
| whats is the size of the stock 2001 gt Front/Rear Rotors | RanGer498 | 99-04 | 1 | February 27th, 2008 06:32 PM |
| Removing Front Brake Rotors | OcOnnor220 | 99-04 | 3 | August 4th, 2007 05:51 PM |
