AEM BF Air Intake Install with PHOTOS!
LinkBack (1) Thread Tools
Old June 26th, 2008, 06:39 PM   1 links from elsewhere to this Post. Click to view. #1
StangsterV8 is on a distinguished road
Hey guys... I recently installed the first mod to my 2007 GT. I got an AEM BRUTE FORCE air intake. I was basically looking for a high-quality system that made power and had a dry filter. The kit I got was dyno'd for a 7hp and 7 ft/lb of torque increase and matched my needs. So far I am very happy with the kit... the car feels great, engine sounds mean, kit added power, and its puts a big 'ol smile on my face when I floor it. I would definitely recommend this kit for someone looking for a good bang for the buck upgrade.
I bought it directly from AEM's site and it arrived within a few days.
LINK TO WHERE I BOUGHT THE INTAKE
Onto the pics... Install went smooth and took less than 45 minutes with the help of a buddy. We both did a little wrenching and a little snapping of pics.
1- Stock engine bay... pretty bland if you ask me!
2- Start by disconnecting the negative battery terminal. Then unplug the PCV hose on the left side of the intake (directly in front of throttlebody). Unplug the throttle control plug on left side of throttlebody and the TPS sensor on the right side of the throttlebody. Unplug the MAF sensor and disconnect the intake pipe and airbox (one bolt by fender).
3- Unlock and disconnect the ABS connector. This is what it looks like for reference. Once you move that out of the way, you'll see that underneath the connector is a bolt, take that out.
4- I removed the engine cover at this point, to gain access to the throttlebody bolts. There are a couple bolts on the side to remove then slide it past the front-facing studs.
5- Unbolt the throttlebody, there are four bolts... one on each corner.
6- Put the supplied o-rings into the throttlebody spacer and sandwich the spacer between the intake manifold and throttlebody. tighten to 10 Nm and reconnect the throttle and TPS sensors.
7- Push the supplied nipple into the coupler and put onto the throttlebody, plug in the PCV hose. (I said hose and nipple in the same sentence =))
8- Remove the MAF sensor from the stock intake and bolt onto the AEM pipe. Be careful with this sensor and make sure the flow arrow is pointing the correct way.
9- Mount the heatshield into place and install the rubber edge trim to protect the pipe. (Just work the heatshield into place around the A/C lines). Plug the ABS connector back in after you're done in this area.
10- Here's a shot of the bottom bracket that really stabilizes the entire unit.
I put this on after I put the heatshield in place then tightened everything at once.
11- Install the soft mount, the intake pipe will mount to this later.
12- Slide in the upper AEM pipe and just barely tighten up the hose clamps.
Leave them loose until the rest of the intake is on.
13- Slide the lower pipe in place, bolt the bracket onto the soft mount and plug in the MAF sensor.
14- Close-up shot of the softmount and how to mount the pipe.
15- Once you slide the filter on and tighten up all the hose clamps, you're all DONE! Sweet new intake under the hood. Let it warm up, check your work, half-ass put your tools away and take 'er for a spin!
Old June 26th, 2008, 06:47 PM   #2
usafimj's Avatar
2007 Ford Mustang GT
12.847 @ 114.12mph
usafimj is a glorious beacon of lightusafimj is a glorious beacon of lightusafimj is a glorious beacon of lightusafimj is a glorious beacon of lightusafimj is a glorious beacon of light
Send a message via Yahoo to usafimj
it looks k. I dunno about the price. $200 more and you could have gotten yourself a tuner. Its gonna heat up quicker than the top b rands
07 GT-- Gone But Not Forgotten
Military Crew
E-5
Old June 26th, 2008, 09:43 PM   #3
psycho bob's Avatar
07 GT
12.86@104
psycho bob is a name known to allpsycho bob is a name known to allpsycho bob is a name known to allpsycho bob is a name known to allpsycho bob is a name known to allpsycho bob is a name known to all
Send a message via Yahoo to psycho bob
yep, metal is not good. heat soak sucks arse. JLT, C&L, and steeda (maybe) are the only one's i would recommend. as long as you're happy though good for you.
Originally Posted by RZNCAIN View Post
I didn't check for spelling so fuck off with your grammar police.
Old June 26th, 2008, 09:52 PM   #4
texas_mustang has a spectacular aura abouttexas_mustang has a spectacular aura about
BBKs metal and ive heard good things about them
Old June 26th, 2008, 09:57 PM   #5
psycho bob's Avatar
07 GT
12.86@104
all i know is the majority buy certain brands for a reason.
Old June 26th, 2008, 11:55 PM   #6
mustang fanatic's Avatar
Dont Tread On Me
mustang fanatic will become famous soon enoughmustang fanatic will become famous soon enough
Send a message via AIM to mustang fanatic Send a message via Yahoo to mustang fanatic
Nice write up.
2007 Mustang GT - Pretty much stock. Pypes pypebomb a/b, Tri-ax shifter.
Old June 27th, 2008, 12:12 AM   #7
One Man Wolf Pack
06RedfireGT's Avatar
2006 Mustang GT
13ish....maybe
Great write up. Not sure if I agree on the intake choice. Looks like a quality piece though.
ΜΟΛΩΝ ΛΑΒΕ
Old June 27th, 2008, 12:49 PM   #8
Thanks all
Thanks for the constructive comments everyone. I do know that there are a number of intakes on the market and that is why I did a ton of research. And with all due respect, I am not going to believe anything that comes from anyone who isn't A) a mechanical engineer B) aerospace engineer C) or someone that is well versed in thermodynamics. In any case, I am happy with my choice.
And from what I know, heat soak is an issue if you're sitting in traffic. Then I can see the effect that heat can have on an intake tube of any material. But who needs their engine to make power in traffic?
Under wide open throttle, how long do you think the air charge is in your intake tube? 1/20th or 1/10th of a second? Do you really think that a 1/10th of a second is enough time to transfer heat from the intake tubing to the airstream? I don't think so, under full throttle the air is moving so fast, it doesn't car what type of tube its in... its haulin' ass
LINK TO ARTICLE EXPLAINING THIS
Old June 27th, 2008, 01:24 PM   #9
One Man Wolf Pack
2006 Mustang GT
13ish....maybe
Well I trust dyno numbers that prove the C&L and JLT are the best. The AEM looks like a quality piece but sure as hell doesn't make as much power as the aforementioned units.
ΜΟΛΩΝ ΛΑΒΕ
Old June 27th, 2008, 01:25 PM   #10
MM's resident Juice head
07 STROKER's Avatar
07 Mustang GT
07 STROKER is a splendid one to behold07 STROKER is a splendid one to behold07 STROKER is a splendid one to behold07 STROKER is a splendid one to behold07 STROKER is a splendid one to behold07 STROKER is a splendid one to behold
I would like to see some before after dyno numbers with that set up
The MGW short throw shifter
Its not just a shifter...It's a lifestyle!
Old June 27th, 2008, 01:43 PM   #11
usafimj's Avatar
12.847 @ 114.12mph
^+1
Military Crew
E-5
Old June 27th, 2008, 03:03 PM   #12
GTron's Avatar
Alloy 2007 Mustang GT
13.39@103.49
GTron is on a distinguished road
From my experience with engineers, I'll believe anyone who isn't one.
Being an engineer doesn't they are intelligent. TRUST ME
Alloy 07 GT
Hurst Shifter
C&L Racer Intake w/Breenspeed Tune
Eibach Pro Kit
Pypes Mid-Muffler System
4.10s (Waiting to be installed)
Current Best Time: 13.39 @ 103.49 (With Intake, tune, and shifter only at the time)
Hurst crew member #8
Old June 27th, 2008, 03:33 PM   #13
onederful100's Avatar
2007 GT 2000 GT
onederful100 has a spectacular aura aboutonederful100 has a spectacular aura aboutonederful100 has a spectacular aura about
you dont have to be an engineer to see that 7hp and 7tq aren't that great.
http://i243.photobucket.com/albums/ff26/onederful100/avatars/sig-52.gif
2007 GT 5spd
2000 GT 5spd
whipple crew member
2-Stang Crew
My Car
Old June 27th, 2008, 05:03 PM   #14
ia07gt's Avatar
2007 Mustang GT
12.69@111 MPH
ia07gt has a spectacular aura aboutia07gt has a spectacular aura about
Send a message via MSN to ia07gt Send a message via Skype™ to ia07gt
thats without the tune though guys. in all theory any aftermarket parts with stock tune dont add up right maybe he just needs to get the thing tuned.
AEM makes good intakes they are expensive as hell though.
have the guy get his car tuned with it to see actual gains.
Current mods-Jba axlebacks, pacesetter Longtubes and ofr h, bmr tubular lowers, 10 psi procharger and 3 core intercooler, ram hd powergrip clutch.
NiCe.
In that second vid you both launched like you were chloroformed by a potential rapist.
Old June 27th, 2008, 07:35 PM   #15
hellbred07 is on a distinguished road
Dude i had a BBK fenderwell intake on my 2000 gt, they are metal and it didn't hurt performance although i wouldn't lie it sure as shit got hot as hell on the outside.To be honest anything under the hood will get hot after a while of driving even plastic and i am sure the air is traveling fast enough that its not heated that much.Besure to get a tune for that thing just to make sure you are getting the most out of your investment.Nice looking intake.NO regrets, keep modding.Get a tune or get it checked.
Old June 27th, 2008, 09:33 PM   #16
ia07gt's Avatar
2007 Mustang GT
12.69@111 MPH
as a reminder the C&L along with the BBK are also shiny metal. I used to be biased on my intakes but i learned a little on this thread, if neone has a dyno shop handy we could conduct a true dynotest on intakes.
NiCe.
Old April 17th, 2010, 11:36 AM   #17
onehotpny is on a distinguished road
Where are the pics!
Old April 18th, 2010, 12:03 AM   #18
101fng's Avatar
2009 Mustang GT
101fng has much to be proud of101fng has much to be proud of101fng has much to be proud of101fng has much to be proud of101fng has much to be proud of101fng has much to be proud of101fng has much to be proud of101fng has much to be proud of
this thread is like a million years old and he probably took the pics of PB.
installing intakes is easy though. take off the old one, put on the new one.
Old April 18th, 2010, 12:33 PM   #19
May 08 ROTM
2008 Audi S6
Emay has much to be proud ofEmay has much to be proud ofEmay has much to be proud ofEmay has much to be proud ofEmay has much to be proud ofEmay has much to be proud ofEmay has much to be proud ofEmay has much to be proud ofEmay has much to be proud ofEmay has much to be proud of
who trolls for old as threads? One hot Pony does!!!!
Old April 18th, 2010, 08:42 PM   #20
Doctor of Jurisprudence
Nameless's Avatar
2005 Mustang GT
Nameless is a splendid one to beholdNameless is a splendid one to beholdNameless is a splendid one to beholdNameless is a splendid one to beholdNameless is a splendid one to beholdNameless is a splendid one to beholdNameless is a splendid one to behold
Ahhh!!! Zombie Thread! Kill it with fire!
Me -----><----- You
Nameless's s197 Write-Ups
he kept taking pics of me saying "OMG look at that!!!"
LinkBack to this Thread: http://www.moddedmustangs.com/forums/2005-2010/77679-aem-bf-air-intake-install-photos.html
AEM BF Air Intake Install with PHOTOS! This thread Refback June 26th, 2008 10:03 PM
Threads Similar to: AEM BF Air Intake Install with PHOTOS!
short ram intake or cold air intake????? j/w Stangbro8994 V6 Mustangs 32 September 18th, 2008 08:20 PM
Air Fuel Gauge install help... 97Cobra Audio/Video 1 October 15th, 2007 09:42 PM
AnyOne Try the AEM Brute Force?? Timm10221 99-04 48 August 1st, 2007 03:18 PM
07 Photos + Some Mach Photos + My Girl's 06 machfelon Pictures 5 April 4th, 2007 11:01 PM
Ram Air Shaker System vs. Cold Air Intake scxc15 V6 Mustangs 9 January 28th, 2007 01:22 PM
