DTC code
Old June 27th, 2008, 07:54 PM   #1
mustangrebuilder will become famous soon enough
DTC code
p0153 i know its a o2 code.
but where is the sticky that had all the DTC list.
Old June 27th, 2008, 07:57 PM   #2
Modified88Dreamer's Avatar
1988 Mustang GT
N/A
Modified88Dreamer will become famous soon enough
This one??
Trouble Codes
"I know that son-of-a-bitch is cheatin! Cause, I'm cheatin and he beat me"!
Old June 27th, 2008, 07:58 PM   #3
yes thank you, i couldnt fine it.
P0153- Upstream Heated Oxygen Sensor circuit Slow Response - Bank No. 2. this is waht i got, is the o2 sensor bad????
Old June 27th, 2008, 08:07 PM   #4
kenneth's Avatar
2006 Mustang GT
11.45@123.61
kenneth has a spectacular aura aboutkenneth has a spectacular aura about
that's what it sounds like.
Stock for now.
Old June 27th, 2008, 08:08 PM   #5
1988 Mustang GT
N/A
More than likely, its the culprit
OBD-II Trouble Code: P0153 Oxygen Sensor Circuit Slow Response (Bank2, Sensor1)
Old June 27th, 2008, 08:27 PM   #6
shit i thought i had an exhaust leak. i think that is what it is from. i am going to have to fix that. jsut put full exhaust on and i am sure soemthing is not lining up.
thanks guys
Old June 27th, 2008, 08:40 PM   #7
1988 Mustang GT
N/A
If you do infact have an exhaust leak, fix it, clear the code and if it comes back then..... well you know where to go from there.
Old June 28th, 2008, 12:45 AM   #8
yeah, if i clear it and it comes back i know it is most likely a bad o2.
Old November 5th, 2008, 01:33 AM   #9
Jon_Purdy is on a distinguished road
I too kept getting that same trouble code. Back in late August, I went ahead and had the oxygen sensors replaced. All was well until today when that same code appeared. What I don't understand is if it was a bad sensor, wouldn't it come on each time I started the car? Perhaps it is an exhaust leak. Not sure what to do about it.
Jon
Old November 5th, 2008, 02:25 PM   #10
kotten148 can only hope to improve
how do you clear the code if a code does in fact come up
Threads Similar to: DTC code
dtc code P1260 vortech4.6l 96-98 24 June 23rd, 2008 09:44 PM
new DTC HELP! kevin86freeman 99-04 7 June 7th, 2008 01:22 PM
dtc code: D262 Missing SCP message???? scrapdaddy jr. V6 Mustangs 0 April 2nd, 2007 05:44 PM
help with dtc code p061b ricco333 V6 Mustangs 1 September 7th, 2006 02:33 PM
P1410 DTC Code.... mustangmaddness 99-04 1 April 8th, 2006 06:30 PM
