Need help Asap!!!
This morning car was running fine then at around 3 went to go to practice car started but was misfireing turned it off tried again same thing...i unplugged my battery for 10mins tried again same result...Now it wont even turnover...anyone have any idea????
Just a bottle and some mufflers )))18yrs old S.FL
BWAL Is My Hero
2003 F150 S-Crew 5.4 FX4
Pop the hood and check all your electrical connections. Then check your oil just to make sure. I'd bet something came unplugged. If not anything else, try uploading the stock tune and see if it runs. If that works you know what the problem is.
I'd bet though, that something is disconnect. I.E. MAF sensor or your CAI. When you say it won't turn over, do you mean the motor won't spin at all? Or it just want start? If the motor will not spin at all then check your battery. If its not your battery (or even if it is) I'd be checking fuses and relays. Thats all I can think of off the top of my head. Just remember. What does your car need? Fuel, Air and Spark.... Start with the basics and you'll more than likely come up with the problem. |
It dosent start, but at first it would abd just misfire like it sounded as if i had some soerious cams...and for fuses and relays what should i be looking for..
I fixed i reset the fuel pump and now its running good
BWAL Is My Hero
Cool. I'm glad it was an easy fix. Did ya pop the fuel cutoff?
near the hatch to pop the hood there is a fuel pump reset button and when i would turn the key i didnt hear the pump like i always do so i tried it...luckly it turned out good
2006 GT
13.69
is that a stock pump//??
BORLA STINGERS,FORD RACING GEARS 3:73/,AIRAID CAI ,vast int. & ext. JEWELRY ![]()
Yea its the stock pump...
Threads Similar to: Need help Asap!!!
| Need help ASAP | weems | The Clubhouse | 5 | May 9th, 2008 12:58 AM |
| need help asap | 91cobra5.0 | 5.0 Mustangs | 8 | April 16th, 2008 07:20 PM |
| help asap please | WeCircleTheProblem | V6 Mustangs | 14 | August 16th, 2007 06:21 PM |
| NEED HELP ASAP!! | 92stang0802 | 2.3 Mustangs | 53 | July 5th, 2007 12:03 PM |
| NEED HELP ASAP!! | VetteC5RFrEak | 5.0 Mustangs | 0 | August 3rd, 2006 02:01 AM |
