LinkBack (1) | Thread Tools |
#1
2005 Mustang GT
10.32@137.70
What Transmission to use????
I am looking at swapping in an auto by the end of the year and have found a couple choices.
I know I can get the 4R70W and 5R55S already. But I was looking at a TH 400 or a Power Glide. I know both are Chevy Trans. but they can build these things to handle more than I could ever throw at it and make them more streetable than the 4R70W. I am looking at a TH 400 with Transbrake, Lock up converter, and Overdrive. The only questions is go with the Power Glide which is a 2 speed, Low and High gear or TH 400 with 3 forward gears and overdrive and Lock up.
350 rwhp and 310 rwtq at 6000 rpms through stock exhaust system 326 cubic inches of Twin Turbocharged hell will be running soonTuned by Wes @ TPS ![]() |
MM's Mad Scientist
Slow Fella
![]() ![]() ![]() ![]() ![]() ![]() iTrader: 2 reviews
I am going with a C4 myself..........
2006 Mustang GT
12.76@105
I was just having a similar discussion at the drag strip last week. The discussion was about my friends S10 pickup iwth a 350 that is running 13.20's. He was talking with some veteran racers about a powerglide and they told him unless his truck weighs under 2800lbs to stay away from it. As for your other choices, they are all good I believe. I am interested in your decision and how well it works since I am considering this swap as well.
2005 Mustang GT
10.32@137.70
The C4 is only rated at 700 HP and that is there built up one. The TH400 is rated for 1500 HP. The PG rated for 2500 HP.
2005 Mustang GT
10.32@137.70
haha TH400 rated for 1500 HP with Trans Brake and everything to install except shifter for $3,074. This will be my end of the year project.
Have you ruled out FB Performance? Think mine is rate at around 1100 crank. Happy with their product, but no idea how it compares to others mentioned. Would think you would want something at least as strong as mine.
2006 Mustang GT
12.76@105
I'm curious. What else is required to install an auto into a car that started out as a stick? For example, are there any electronics required?
MM's Mad Scientist
Slow Fella
The C4 is not as parasitic either, and I have seen the C4 go well beyond 700HP.....
#9 | |
It was a 5 speed manual. The OEM electrical wires & connector were retained for electrical functions and the computer from the stick-shift transmission was used. |
2006 Mustang GT
12.76@105
So, there were no harnesses to buy or anything? Pretty much just plug n play?
2005 Mustang GT
10.32@137.70
It coms with a solinoid driver that you connect to the trans and hook up 1 power wire to it.
I am sure they have stronger C4's but that is wht they rate theres at. The TH400 is rated at 1500 HP but can easily be updated with a different sprag and center shaft to make it hold 2500 HP but I don't need that much.
#12 | |
2007 Mustang GT
12.6@110
![]() Professor Crackers
Bet his car ends up with at least 1000 hp. The motor build alone is amazing. I want to see it reach its full potential...mid 9s maybe.
2005 Mustang GT
10.32@137.70
haha, steve I have some new stuff up my sleeve....that is why I am looking for a transmission to handle it. I hope maybe 1000 hp maybe a little more.
2006 Mustang GT
that would be awesome. These are strictly drag transmissions right, not very streetable?
2005 Mustang GT
10.32@137.70
they are for limited street use...but with my car only getting 13.5 mpg on the highway and 7.8 mpg in town with the new tune I don't think it will see much street use anymore.
Golf Pencil Kawk Juggler
hehe.....whats your DD KB?
![]() Procharger D-1SC Kit - Pypes O/R H - FRPP Stingers Team Ricer GT Co-Founder
2005 Mustang GT
10.32@137.70
a 2007 Nissan Titan....my wifes truck, I drop her off at work anyway so I will just drive it around. I may have to drive it 3 days a week Friday,Saturday, and Sunday she doesn't work so 3 days a week for the car won't be to bad.
2007 GT
his daily driver is a 77 volskwagon beetle. 56rwhp and 23rwtq. gets 79.5 miles to the gallon becuase it will coast 5 miles on flat surface.
2005 Mustang GT
10.32@137.70
haha, I want a Prius!!!
LinkBack to this Thread: http://www.moddedmustangs.com/forums/2005-2010/79474-what-transmission-use.html
| What Transmission to use???? | This thread | Refback | July 9th, 2008 02:40 PM | |
Threads Similar to: What Transmission to use????
| Which Transmission? | chaosstangman | 5.0 Mustangs | 2 | April 15th, 2008 12:27 AM |
| Transmission | mystang0673 | 2005 - 2010 | 8 | March 21st, 2008 06:38 PM |
| What Transmission To Get? | 87StangLX | 5.0 Mustangs | 31 | November 15th, 2007 08:01 PM |
| Transmission | flamed 98 gt | 5.0 Mustangs | 9 | September 22nd, 2007 07:12 PM |
| New Transmission | DeathScythe95 | V6 Mustangs | 9 | April 9th, 2007 10:11 PM |
