2008 GT
Anyone running an oversized throttle body by Granatelli motor sports?
It costs about $400 and its supposed to add 11 peak HP and 22 mid range HP, but I wanted to get some opinions on it. Worth the money? Also, anyone heard of the Plasma Booster, spark amplifier?
![]() Procharged D-1SC W/3.7 Pulley, Comp "Mutha Thumprs", Mac Longtubes, O/R prochamber, Steeda CMCV Deletes, 3.73's, FRPP Stingers |
T/B only give headaches... making the car fall into failsafe... only one I've heard that works on some cars is the BBK...
One Man Wolf Pack
Not worth it man. The Granatelli ones are supposed to be the worst ones.
Get gears instead.
![]() ΜΟΛΩΝ ΛΑΒΕ
07 Mustang GT
best TBs are gt500s
Gears, Cold air intake and tune
2007 Mustang GT - Pretty much stock. Pypes pypebomb a/b, Tri-ax shifter. |
2008 GT
How about the Plasma Booster, spark amplifier? Anything?
2007 GT
are you stock right now?
2007 GT
Plasma Booster's work real well in Torok "The Dinosaur Hunter" but that's about it ... unless you are pumping some serious boost the stock system will be more then adequate.
3.73 or 4.10 gears, save $250 more and get nsr comp cams from 07stanggt, short throw shifter of your choice
07 GT-- Gone But Not Forgotten Military Crew E-5
2008 GT
how much of a benifit are the cams since it will void my warranty?
2007 GT
what are you trying to accomplish if i might ask? you just want some modifiations? You have a tune/cai and ud's now. there is a lot you can do. shifter, gears, exhuast work. Also you could lower the car. all of those things would be noticeable and cheap mods that you would enjoy a lot.
2008 GT
Im aware of the possibilities, I just dont want to do serious mods till the warranty is up. All the mods I have now are easily reversable back to stock. I was just wondering about those products. Thanks for the help though, nice video too!
I'll try to find the dyno #'s, but with the GT500 throttle body (which is light years better than the one you are talking about), N/A applications gained 1-2 HP. NOT worth it!
'06 Whipple'd Mustang GT (Coming Soon) '02 Supercharged Harley-Davidson F-150 (Sold) '05 Mustang GT (Sold) |
2006 mustang GT
9.417 @ 142.96 mph
The stock throttle body is good even in F/I twin screw applications to 12 psi and 500 hp. So for you, just stick with the stock one. I gained alot going with a black diamond throttle body that flows 1600 cfm, but I also run 16psi, and at that point the stock TB was a restriction.
Same with the factory COP's. I know of several cars running over 500rwhp with the stock COP's. Once again, since I will run C16 at the track with 16psi, I went with some GMS coil packs (2nd gen) and they work very well.
2005 Mustang GT Auto - Whipple @ 18 psi - 604 rwhp 543 rwtq
psf - Are you on the stock block? 1.43 60'? Holy crap!
2006 mustang GT
9.417 @ 142.96 mph
No, JE pistons, Scat Rods, Cobra crank, cobra block. Stock heads and cams though.
OK, I assumed you weren't giving it that much boost on a stock block.
2001 Mustang SVT Cobra
If you're worried about the warranty then don't do any mods. If you're going to start modding, then forget about warranty.
Slow, really slow Cobra. Wanna see?![]() MM Cobra Club Member #81 "TAMPA BAY AREA CREW"
2007 GT
#20 | ||||
I agree and we offer those as well
Threads Similar to: Anyone running an oversized throttle body by Granatelli motor sports?
| ford racing suspension and granatelli 62mm throttle body | mustang fanatic | 2005 - 2010 | 10 | July 6th, 2008 04:45 PM |
| oversized passengers... | JASonic | The Clubhouse | 31 | June 23rd, 2008 02:05 PM |
| new throttle body | poof505 | V6 Mustangs | 15 | November 4th, 2007 07:54 PM |
| This man is my idol... PARM of jawanda motor sports | demonicus | Pictures | 4 | July 26th, 2007 07:35 PM |
| Fuel running out of throttle body? | nolife | 5.0 Mustangs | 9 | April 2nd, 2007 09:48 PM |
