So easy and what a difference - Page 2
LinkBack (1) Thread Tools
Old July 14th, 2008, 02:49 AM   #21
Bhblondguy's Avatar
2005 Mustang GT
12.00@114.82
Bhblondguy will become famous soon enoughBhblondguy will become famous soon enough
nope, after you make the switch from conventional to synthetic, you are not supposed to switch back to conventional. Hello expensive oil...forever
Old July 14th, 2008, 06:28 PM   #22
rakkassan34's Avatar
2005 GT
13.5 best to date
rakkassan34 is on a distinguished road
Then why do they sell a blend of synthetic and regular? That's what I use in mine.
Off road pro chamber, JLT II, tune by Bamachips, 4.10's, thumper cams, sunburst orange stripes
Old July 14th, 2008, 08:16 PM   #23
Bhblondguy's Avatar
2005 Mustang GT
12.00@114.82
To tell you the truth, I have no idea. except that maybe the oil has a tendency not to wear out as fast as conventional, keeping your engine safer longer. Why not go straight synthetic then? Thats the whole point. Get more performance out of the engine.
Old July 14th, 2008, 08:44 PM   #24
07 Grabber GT's Avatar
2007 GT
07 Grabber GT is on a distinguished road
You can switch between the two ... that's just a myth.
Yes the good ole oil debate is back again ... the book says 5k using the Ford Blend. I've done it all with oil ... all types of cars, engine conditions, types of oil ... for the $$$ catch Mobil 1 extended wear and the matching filter on sale ($29.99 5qts plus filter and then add an extra quart). I've also started with a new car, and did all my changes well beyond the 3k mark ... not a single ounce of oil burned to date, no blow-by ... etc.
I switched to that in my high mileage car -- 200K plus -- what a difference ... and I run it for 15k before changing again ... just like Mobil 1 advertises for that particular oil/filter.
The Stang switched to the same oil/filter but I don't go 15K before changing the oil -- about 1/2 like Juco, until the power train warranty is over (or I get around to buying the KB) ... the days of the 3k miles rule are long over ... its merely recreational mx if you still do that ... especially in a newer car.
Old July 15th, 2008, 01:15 AM   #25
Redrocket06's Avatar
2006 GT Coupe
12.0@118
Redrocket06 is on a distinguished road
Check this link out, they use Mobil1 synthetic and Amsoil in a LS1, and leave each oil in for a full year doing an oil analyst at every 1000 miles.
Mobil 1 Test Results
Amsoil Test Results
06 GT, 3.55, V3/Methanol inj, 3.6" pulley, OBX LT O/R H, Delete Plates, Exedy 500 with flywheel, 494rwhp 443rwtq
12.56 @ 108 NA
12.0 @ 118 left off idle, fried stock clutch
Checkout Reds stuff:
http://s301.photobucket.com/albums/nn44/Redrocket06/
LinkBack to this Thread: http://www.moddedmustangs.com/forums/2005-2010/80042-so-easy-what-difference.html
So easy and what a difference This thread Refback July 13th, 2008 11:22 PM
Threads Similar to: So easy and what a difference
easy hp gain dowork 99-04 14 June 26th, 2008 04:44 PM
ok this should be an easy 1 natedawgishot 99-04 14 February 3rd, 2008 03:42 PM
Not So Easy After all OnePass2Many 99-04 15 January 20th, 2008 07:39 PM
easy question kuskye25 5.0 Mustangs 9 December 26th, 2007 09:50 PM
Is There An Easy Way 90Stang 5.0 Mustangs 6 November 19th, 2006 07:31 PM
