nasty exhaust rattle
Old July 16th, 2008, 10:50 PM   #1
beastGT's Avatar
Mustang GT
beastGT is on a distinguished road
I have the borla stinger axle backs. Ive noticed a bad rattle when im downshifting or even accelerating...like when there is a change in tq and the exhaust moves a little....well it sounds like metal on metal and i konw the tips arent hitting the bumber like i first thought. I had meinke look at it and they didnt find anything but have you guys had any issues like this?
Old July 16th, 2008, 11:41 PM   #2
2007 GT
07stanggt has much to be proud of07stanggt has much to be proud of07stanggt has much to be proud of07stanggt has much to be proud of07stanggt has much to be proud of07stanggt has much to be proud of07stanggt has much to be proud of07stanggt has much to be proud of
where did you get the stingers first? someone beat my price, maybe ill let them answer messing with you. check and make sure the rear, shit i cant think im so tired. not the hanger but the metal peice goes in the hanger isnt rubbing against the back of your car thats probably it, if not them it is the tip vibrateing against the plastic. even if it does seem that way.
Old July 16th, 2008, 11:49 PM   #3
beastGT's Avatar
Mustang GT
yeah the tips have a good 1.5" atleast from the top of the bumber and i re adjusted them so they are perfectly center so i dont think thats it...ill check the other piece like you said. Im thinking it might be the actual muffler hitting a piece of the chassis...there only like an inch seperating the two. If so could i just put some rubber lining on the chassis to reduce it?
Old July 17th, 2008, 12:14 AM   #4
2006greyGT's Avatar
2006 Satin Silver GT
11.08@125.22
2006greyGT has a spectacular aura about2006greyGT has a spectacular aura about2006greyGT has a spectacular aura about
Send a message via Yahoo to 2006greyGT
Do you have cats? mine made a noise as you describe and it was my cat fell apart...
[IMG]
2.6l KENNE BELL 298 Stroker, Ported heads
Pro Motion Built 3650/McLeod RST/ MGW Short Throw
Long tube/O/R X /Borla Touring
8 rib/65 lb injectors/GT500 twin fuel
ET Drag Slicks/3.73 gear
Detroit Truetrac /CDC AGR Spoiler
Old July 17th, 2008, 01:09 AM   #5
2007 GT
I know the tips can look like they have plenty of clearance, but under torque they can move. i have had mine on and off so many times and have to mess with that issue always, plus the hanger arm is so long on the stingers it rubs on the back of the car. i have heard of guys saying they cut it to make it shorter becuase it was rubbing.
Old July 17th, 2008, 01:59 AM   #6
stangNV's Avatar
07 Mustang GT
stangNV is on a distinguished road
mine had this noise...it makes the noise if you hit a bump to right? its the hanger front the muffler hitting the metal around the rubber hanger holder....if you understood what i just said haha
Old July 17th, 2008, 01:54 PM   #7
beastGT's Avatar
Mustang GT
hahaha not really...im just gonna look under there agian and try to find a way to stop it...line everythign with rubber and cut the metal rod that goes through the rubber hanger.
Old July 17th, 2008, 01:55 PM   #8
beastGT's Avatar
Mustang GT
oh...and i sure as hell hope my cat isnt messed up, i doubt it though because it does it from time to time...not all the time
Old July 17th, 2008, 02:02 PM   #9
IronStomach's Avatar
2008 Mustang GT
IronStomach has a spectacular aura aboutIronStomach has a spectacular aura aboutIronStomach has a spectacular aura about
There's a metal shield on the transmission that is known to come loose. Mine was rattling something awful on acceleration from 2k-3k rpms. It sounds like sheet metal rattling on metal. I took it in under warranty. The link above has DIY answers.
Experience is what you get when you didn't get what you wanted.
Old July 17th, 2008, 02:16 PM   #10
beastGT's Avatar
Mustang GT
ive got that too but the noise im talking about is coming from the rear of the car...def an exhaust issue. that rattling doesnt bother me, it rarely happens and is only at startup
Old July 17th, 2008, 08:45 PM   #11
beastGT's Avatar
Mustang GT
well looked under the car while it was idle and still heard the rattle...it was def. the hanger arm hitting the bumber. Tommorrow it is coming off and im gonna cut it so that should eliminate the prob. Thanks guys for the help, i woulda never looked for that.
Old July 17th, 2008, 08:48 PM   #12
2008 Mustang GT
Congrats on winning the snipe hunt. Your prize? Nothing. Errr... I mean silence.
Old July 17th, 2008, 08:54 PM   #13
beastGT's Avatar
Mustang GT
yeah ill be glad when its gone...takes away from the nice sound of the borlas
Old July 18th, 2008, 02:02 PM   #14
beastGT's Avatar
Mustang GT
well took it to the shop and had about a half inch cut off that metal rod that goes through the hanger...that thing was rubbin up agianst the bumber to the point you could see where the paint had come off. Now my rattle is gone
Old July 18th, 2008, 02:19 PM   #15
Blood, Sweat and Gears...
garydahl's Avatar
garydahl will become famous soon enough
I had the samething on My 07 Stang. It only did it when the car was warm. We found that when the pipes got hot the exhaust would grow! The rods that hung my axle backs would hit the bumper brace]
Cut the rod and the noise left
Black 2008 Mustang Bullitt, ID#2029
Hot Rod Cams, Hurst shifter, 4.10's & 8.8" AxleGirdle, twin 62mm TB.
Kook's LT/H-Pipe, ATAK/Oem mufflers depending on my mood
Steeda UDP/CMDP/LCA/UCA, 4"DS.
BBR tuned 335 rwhp /330 rwtq SAE corrected
Threads Similar to: nasty exhaust rattle
Exhaust Rattle Need Help...... 88stangGT 99-04 1 July 15th, 2008 04:17 AM
exhaust rattle deedub97GT 96-98 6 May 5th, 2008 04:23 AM
Bassani Exhaust Rattle bigelf32 General Tech 3 December 14th, 2007 10:09 AM
exhaust rattle-need input from the pro's JOHNNY K. Modular Mustangs 2 October 25th, 2007 02:27 PM
Nasty rattle, any ideas? gary70au 5.0 Mustangs 5 February 10th, 2007 11:31 PM
