2005 Mustang GT
Painting valve cover questions
I just painted my valve covers and fuel rails last Sunday. As I mentioned in another thread, when I removed them I had 4 stripped holes in my cylinder head. I helicoiled them and got the covers back on ok. Finished getting everything back together today and just took the car out.
First was a short ride to a store. Once there I lifted the hood. I could smell the paint - like hot paint. Is that normal? Will that go away over time? Then when I got back in and started it, I noticed the check engine light. So I shut if off and pulled out the manual. It said something about if the battery has been serviced (well i removed and reinstalled it) then the car is some kind of "not ready for testing mode". It said to drive 10 minutes on the highway and 20 city stop and go, then let it sit for 8 hours before starting again. Has anyone ever had this before? Will the light turn off eventually or do I have a problem? Thanks |
MMs Ford Racing Nut Swinger
2007 MUSTANG GT
![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: 3 reviews
The hot paint smell will go away once the paint is fully cured.. You did use high temp paint right??
2005 Mustang GT
Yes, High temp rated 500 degrees.
2007 MUSTANG GT
Your fine then.. I baked mine in the oven at 175 degrees for a couple hours to speed the curing process along..
2005 Mustang GT
Thanks 1FUNFRD.
Does anyone know about my other question - the engine light. Is it on only because I disconnected the battery? Will it shut off? Or do I potentially have some other problem? |
Threads Similar to: Painting valve cover questions
| Valve cover ? | 88mysticgt | 5.0 Mustangs | 3 | April 5th, 2008 10:00 AM |
| Valve Cover | mustang1072 | V6 Mustangs | 15 | March 23rd, 2008 09:30 PM |
| valve cover painting | KenDogg | 2005 - 2010 | 20 | March 10th, 2008 09:46 AM |
| Painting My Valve Covers (56K not allowed) | Nameless | 2005 - 2010 | 23 | January 31st, 2008 04:36 PM |
| Painting a Gt bumper cover myself | tjames | Visual | 7 | October 9th, 2007 07:10 PM |
