Exhaust Rattle
Old July 28th, 2008, 03:24 PM   #1
killermach1 is on a distinguished road
Exhaust Rattle
Ok once I installed my pypes Violators they began to rattle at first when I let off the throttle or down shifted etc. then more. I went to my dealership to get the suspension installed and asked them to check the rattle. They tightened up all the fittings and everything was fine for a while now the rattle is back. Should I take the car in and have my exhaust welded? My only worry about this is if I needed to take off the exhaust then I would have to cut it. I am happy with the sound right now and am not thinking of cahnging it soon but may in the future. I could get it all welded but the axle backs incase I decide to change them later but anyway what do you all think? What would you do?
Old July 28th, 2008, 03:46 PM   #2
IronStomach's Avatar
2008 Mustang GT
IronStomach has a spectacular aura aboutIronStomach has a spectacular aura aboutIronStomach has a spectacular aura about
I'd check ALL the fittings myself before bringing it in to the dealer again. They might not have checked everything due to time constraints.
Metal loosens up with heat and cool cycles and that will loosen bolts that aren't completely secure. A second, thorough tightening to spec should help.
I know every time I overhaul the bottom bracket or crankarms on my bicycle I have to retighten the assembly after a ride or two because the stresses loosened it up.
Experience is what you get when you didn't get what you wanted.
Threads Similar to: Exhaust Rattle
nasty exhaust rattle beastGT 2005 - 2010 14 July 18th, 2008 02:19 PM
Exhaust Rattle Need Help...... 88stangGT 99-04 1 July 15th, 2008 04:17 AM
exhaust rattle deedub97GT 96-98 6 May 5th, 2008 04:23 AM
Bassani Exhaust Rattle bigelf32 General Tech 3 December 14th, 2007 10:09 AM
exhaust rattle-need input from the pro's JOHNNY K. Modular Mustangs 2 October 25th, 2007 02:27 PM
