check engine light
the just came on..the car was acting weird like it kept jumping around anyway how do i look for a code with the predator
Just a bottle and some mufflers )))18yrs old S.FL
48.47@ 12.58
plug it in and scroll till you see read cels
2007 GT
cel - check engine light
you know what scroll means. HARDE HAR... jk man |
Go into options and look for trouble codes, select it,if there is any they will come up.
48.47@ 12.58
yea sorry about that. like he said cel= check engine light..
it may say something else such as trouble codes or dct's .. it all means the same thing.
okk i looked at it and it showed
p0340 camshaft position p0600 serial communication p1000 obd system p2105 throttle actuaton
looks all electrical related... this may sound weird but have you charged your battery lately? Your cam sensor(s) could be shot but that would be reallllllly odd... might just need a crank relearn. I would start by pulling the positive side for about 30 minutes to see if they throw again.
I was drving the car went to the store and it went away..what i think happen is i hit the rev limiter and it might of shocked the computer or something because it was the first ive ever done that..
#10 | |
1988 Mustang GT
N/A
P1000 is nothing to worry about. All that code is, is that its telling you, you haven't completed a drive cycle yet. Basically hasn't tested all the sensors. Did you or someone clear codes before? That would be the only reason why that one is showing up. As for the others... P0600, I cant find anything on how to solve that, it just list what it is just like you had put and P2105 is throttle actuation Circuit control system- Forced Engine shutdown. Description for it is Throttle actuator control system is in FMEM (Failure Mode and Effects Management) mode of forced engine shutdown. Possible causes ( Total system failure, PCM damaged, Incorrect Equizzer or Power PC software) OBD-II Trouble Code: P0340 Camshaft Position Sensor Circuit Malfunction
"I know that son-of-a-bitch is cheatin! Cause, I'm cheatin and he beat me"! Last edited by Modified88Dreamer; July 29th, 2008 at 02:53 PM. |
Its not showing anymore and the car is running fine..so as of right now everything is good..
light came back on
i dont kno if i should put it back to stock or go back to my tuner and just get a tune up new spark plugs etc...any input will help thank you
Threads Similar to: check engine light
| i cant get my check light engine off | XPLICITSTANG | 99-04 | 13 | June 22nd, 2008 01:49 PM |
| Check Engine light yet again! | mustangmanic | 99-04 | 14 | April 8th, 2008 08:56 PM |
| Check engine light? | 95stangergt5.o | 5.0 Mustangs | 5 | April 28th, 2007 01:00 PM |
| check engine light | 1995svtcobra | 94-95 | 2 | April 12th, 2007 09:30 PM |
| Check Engine Light | 1990mustanggt | 5.0 Mustangs | 8 | September 19th, 2006 04:17 PM |
