trq converter EAT the hp ?
05 mustang GT ( auto ) with :
- cmop stag2 cams. - 3.73 ratio - headers - exust Borlla :lala - K&N GII - program predator ?????????????????????????- roush pulleys - Meizer Electric Water Pump I'm putting down 314hp and 311trq ( I think it's fine ) no spray And then: - 3000 trq stall ( TCI ) - Autolites 1 degree colder for the zex dyno again and I was surprised 275hp and 265trq no sprayafter modifying the parameters with that ( SEGA ) predator flash device it goes up to 280hp is true that the trq converter reduce the hp on dyno ? Any advice of using that flash device ( predator ) ? |
Chassis dynos are far from accurate. Don't get caught up in how much horsepower your car makes or doesn't make on a chassis dyno. There are so many variables that even wheel placement on the rollers can change the horsepower read out. A looser converters will use more horsepower than a tight converter because the extra stall speed is gained thru slippage. Not a big deal. A 3000 stall converter is going to be a minimal loss anyway. Your horsepower loss could be from a number of things, air temp, air density, wheel position on rollers, air pressure in tires, etc.
#3 | |
RIP Justincredible! God Speed
Ive seen this again and again. Loose torque converters play hell on dynos. Remember...the dyno is a tuning tool only.
9.91@ 134mph 1/4 - 6.17@ 109mph 1/8th - 1.33 60' - Stock ECU & Stock Suspension......and getting faster . BIVENS RACE CARS FTMFW!!! |
+2. It might show less hp on the dyno but the real test is the strip. A ET slip doesn't lie.
i agree...and dynos don't win races..
That aside,the car should FEEL alot quiker,does it? Did you dyno before the cams?
..........05 GT... 2 1/2" DROP.......... |
I've yet to see an advertised horsepower gain be anywhere near realistic.
#8 | |
The loose converters eat a ton of displayed power on the dyno, and it is just a tool. |
Yeah I agree too.
SLP Loud mouths SLP x-pipe 4.10 gears K&N intake X-Cal II custom tune |
Threads Similar to: trq converter EAT the hp ?
| converter | HTK241 | 99-04 | 7 | October 21st, 2007 01:27 PM |
| Cataliytic converter | 02NEBstang | 99-04 | 3 | February 23rd, 2007 02:43 PM |
| converter | lagunas375 | General Tech | 0 | January 24th, 2007 03:16 AM |
| cat converter | macnesa23 | General Tech | 7 | July 3rd, 2006 11:18 AM |
| converter | reeds98gt | 96-98 | 9 | June 15th, 2006 04:46 PM |
