Cam install
K. I'm going to be installing the Stage II NSR Comp Cams next weekend. Can't this weekend cuz I'll be at Ozzfest 2008 in DFW....
![]() ![]() ![]() I have the Cams on hand, cam phaser bolts are on the way, the valve spring compressor & timing chain wedge should be on the way also. What else should I get before I tackle this beast. I'll also be buying a fresh quart of oil to lubricate everything before installation. Thanks Brain Fart: On the cam boxes one has LH & the other has RH. Is the LH the passenger side if your staring at the motor from the front or is the LH the driver side when sitting in the car. vice versa for the RH
07 GT-- Gone But Not Forgotten Military Crew E-5
2008 Mustang GT
How much did the tools run ya and where'd you source them from? (valve spring compressor & chain wedge)
Experience is what you get when you didn't get what you wanted.
#4 | |
2008 Mustang GT
2006 Mustang GT
10.82@125.2
Good luck bro!!!
2005 Mustang GT
10.32@137.70
Get beer!!! and Good Luck
350 rwhp and 310 rwtq at 6000 rpms through stock exhaust system 326 cubic inches of Twin Turbocharged hell will be running soonTuned by Wes @ TPS ![]() |
#7 | |
2005 Mustang GT
10.32@137.70
Answer
the left side is the driver side in the US Answer the left side is on the left when sitting in the car faceing forwards! the right and left sides of an automobile or the engine are determined faceing forward from rear of object as in cross mounted engine stand in back of engine and face towards the front of engine the left bank will be on the front bumper side while the right bank will be on the cowl side of auto
MM's resident Juice head
07 Mustang GT
left is drivers side.
![]() The MGW short throw shifter Its not just a shifter...It's a lifestyle! |
Do you have the part #'s on the tools needed, because im thinking about getting cams and doing the install with a buddy or two.
![]() Vortech V2 Non-Intercooled*60lb Injectors*Gt500 Fuel System*Fore Fuel Rails*SCT*CMDP*L/T Headers*O/R X-Pipe*Dynomax Bullets*BBR Tune*Comp Thumpr Stage II*Phaser Limiters*4.33 Gears*BMR suspension*450RWHP380RWTQ*12.20 @ 118 |
#11 | |
2005 Mustang GT
10.32@137.70
Valve Spring Compressor - 303-1039 Timing Chain Locking Tool - 303-1175
I'll rent out the tools to anyone who needs them. You can just send me what I paid in shipping to send them to you. That is all. Much cheaper than $238
Rev Limit
with the new cams going in next weekend hopefully. Should I leave the rev limit alone or have doug @ bamachips raise it. If so, what should I ask him to raise it to.
2006 Mustang GT
14.024
No but I got the JLT/tuner combo from him so the tunes are free anyways
2008 Mustang Bullitt
If the cams didn't come with new cover gaskets make sure you get those as well.
Why so serious? |
the stock cam cover gaskets are rubber and are reusable. Only thing I have to watch out for is taking them off slowly making sure I don't tear it. Other than that I'm good
2007 GT
I think Doug might have to modify the cam timing for the phasers.
2005 Mustang GT
dyno
hey Doug from Bamachips just emailed me what HP i should expect with the cam tune he said he dynoed one last week and gained 25-32 rwhp across the entire RPM range thats pretty good. i already have to tune just have to get the nsr cams and install them. i read a thread about the engine that blew up and ask Doug if he had heard anything about that . He said he didn't and that he doesn't mess with the cam timing so his tune is safe and the people are satisfied with the tune with no problems.
http://videos.streetfire.net/video/0...ust_143888.htm My mods: Comp NSR II's, JBA shorties, Pypes o/r H-pipe, Steeda axlebacks, Steeda UD, BBK TB, Steeda CAI, FRPP4.10, BMR panhard/LCA/Relo, Eibach springs, D-specs,Bama 91race, CMDP
Threads Similar to: Cam install
| Cam and Intake Install | ModMustang97GT | 96-98 | 2 | July 11th, 2008 10:19 PM |
| Cam install ?'s | pfcbrook | 99-04 | 12 | February 29th, 2008 08:11 PM |
| cam install | 95blueGT | 94-95 | 4 | October 12th, 2007 01:56 AM |
| 99 3.8 cam w/spring install | mmvi | V6 Mustangs | 5 | April 24th, 2007 04:04 PM |
| V6 Cam install question | 02ponypackage | V6 Mustangs | 6 | February 14th, 2007 01:20 PM |
