CHE LCA's - TQ spec?
LinkBack (1) Thread Tools
Old August 12th, 2008, 10:50 AM   1 links from elsewhere to this Post. Click to view. #1
BudgetPlan1 is on a distinguished road
CHE install instructions say torque to 80-90 ft/lbs, factory specs are 129 ft/lbs, a pretty large difference. Design differences or install instructions incorrect?
Whatcha think?
2008 GT - 13.780@103.83
2004 Corvette - 12.82@109.33
Old August 12th, 2008, 11:00 AM   #2
ROUSH STAGE II's Avatar
2005 Turbonetics Baby!!!
ROUSH STAGE II is just really niceROUSH STAGE II is just really niceROUSH STAGE II is just really niceROUSH STAGE II is just really nice
129 ft/lbs.
Turbonetics baby!!!
11.23@122 mph...
Old August 12th, 2008, 02:20 PM   #3
MM's resident Juice head
07 STROKER's Avatar
07 Mustang GT
07 STROKER is a splendid one to behold07 STROKER is a splendid one to behold07 STROKER is a splendid one to behold07 STROKER is a splendid one to behold07 STROKER is a splendid one to behold07 STROKER is a splendid one to behold
^ +1
The MGW short throw shifter
Its not just a shifter...It's a lifestyle!
Old August 12th, 2008, 03:13 PM   #4
5.0 Junkie's Avatar
5.0 Junkie is on a distinguished road
Good luck. I had mine on ramps again due to a clunk noise after putting my Metcos on. I torqued mine today to 130#. I'm a relatively stout guy and about herniated myself trying to get the wrench to click. Noise is still there, but sounds like the driveshaft to me.
2006 Black GT
Tri-ax shifter with alum. handle and black ball, Borla axleback, K&N intake, more to come.
Old August 13th, 2008, 06:08 AM   #5
bkid's Avatar
2006 Mustang GT
14.024
bkid is on a distinguished road
I torqued mine to 129 and no issues. 129 is not that hard to torque to either.
Old August 13th, 2008, 09:09 AM   #6
Updated info from CHE re: TQ
Got this from CHE in response to my inquiry (of course, by this time I had TQ'd to 129 ft/lbs)
The lower torque value is sufficient because of the bushing design. The stock bushings are actually "glued" to the center steel sleeve and do not rotate around the center steel sleeve, rather they are stretched and twisted and under a great deal of torsion when the control arm moves up and down. The incredibly high stock torque setting is in place to prevent the center steel crush sleeve from rotating with the bushing.
With our bushings, the control arm rotates freely around the steel center crush sleeve and there are no torsional loads placed upon it that may cause it to rotate. Additionally, the factory setting of 129 lb-ft is high enough that it could actually deform the steel center sleeve, not to mention that you would practically need a gorilla in your garage to pull on the torque wrench hard enough to reach that spec.
Please let me know if you have any further questions,
Chuck Dworek
CHE Performance Products
814-774-4319 bus
814-774-4613 fax
Carriage House Engineering CHE Performance Products
Old August 13th, 2008, 09:25 AM   #7
IronStomach's Avatar
2008 Mustang GT
IronStomach has a spectacular aura aboutIronStomach has a spectacular aura aboutIronStomach has a spectacular aura about
Guess I'm a gorilla then.
Awesome, thanks for posting that, I'll loosen up the control arms and retorque this week as well.
Experience is what you get when you didn't get what you wanted.
Old August 13th, 2008, 03:28 PM   #8
mustang fanatic's Avatar
Dont Tread On Me
mustang fanatic will become famous soon enoughmustang fanatic will become famous soon enough
Send a message via AIM to mustang fanatic Send a message via Yahoo to mustang fanatic
130 ft lbs is not hard to torque. I dont see what the problem is. Try 160.... if you have a problem torquing then maybe the torque wrench is too short. Go to home depot and get some steel tubing, about 3 feet worth. That will give you the extra leverage.
2007 Mustang GT - Pretty much stock. Pypes pypebomb a/b, Tri-ax shifter.
Old August 13th, 2008, 04:02 PM   #9
2008 Mustang GT
Heh, when you weigh 225 lbs and do lots of pushups, torque specs are easy to hit. Maybe the guy from CHE is a runt?
Old August 13th, 2008, 10:27 PM   #10
Dont Tread On Me
Well I am 6'2 and 200 lbs and work out. I guess it would make it easier
Old August 13th, 2008, 11:35 PM   #11
qwik48r's Avatar
alotta shit
no fat girls fast
qwik48r is a jewel in the roughqwik48r is a jewel in the roughqwik48r is a jewel in the rough
Send a message via AIM to qwik48r
try installing a new crank bolt on an LSx motor... 240 ftlbs... and only 200* degrees to get there... HAHAHA... it aint a cake walk.
mind your business what i drive... i'm on a fucking mustang forum.
qwik's build
LinkBack to this Thread: http://www.moddedmustangs.com/forums/2005-2010/84207-che-lcas-tq-spec.html
CHE LCA's - TQ spec? This thread Refback September 10th, 2008 06:41 PM
Threads Similar to: CHE LCA's - TQ spec?
LCA's - Billet, boxed or tubular... BudgetPlan1 2005 - 2010 21 July 31st, 2008 10:55 AM
CHE parts, who wants in?? mustang fanatic 2005 - 2010 48 July 20th, 2008 01:51 PM
LCA's and Off road X pipe installed ia07gt 2005 - 2010 15 July 11th, 2008 02:10 PM
4.10's, LCA's, Hurst Billet Shifter, oh TheUNZippee! 2005 - 2010 103 May 18th, 2008 11:36 PM
Question about lowering springs and need for adj. LCA's ponyup 2005 - 2010 4 March 7th, 2007 09:54 AM
