Supercharger Cooling? - Page 2
LinkBack (1) Thread Tools
Old August 12th, 2008, 02:29 PM   1 links from elsewhere to this Post. Click to view. #21
07torchgt is on a distinguished road
Originally Posted by Trick Tuners View Post
Water/meth on a IC'd KB is a tricky situation. The only way it will work at all is if you port the bottom of the blower manifold under the IC. Spraying meth thru the IC has been proven not to work because the IC will cause the meth to coalesce on the fins, instead of remain in the vapor form. There is a reason you don't see any IC'd PD blower guys with meth.
its not really that its that tricky, it just takes a little work... Tuning is better with the maf rather than boost with a PD blower... it still works and works well
"Walk tall, talk small, leave everyone to question, and carry a big f***ing stick!""As I walk through the valley of the shadow of rice, I shall fear no 4banger for torque art with me! Thy V8 and thy Mammoth, they comfort me!"
Old August 12th, 2008, 02:38 PM   #22
2005 Saleen
SUHLeen is on a distinguished road
Would water wetter help any at all? What's the "maintenance" with water wetter? I.E. how many times do I have to add it, etc...
Old August 12th, 2008, 02:58 PM   #23
water wetter is an additive... thats all, you won't to keep adding it... it increases the cooling effiency of the water that its added to... I use it in my bikes for track use... Glycol based coolants aren't allowed on the race track so water wetter is a great option
Old August 12th, 2008, 03:19 PM   #24
Trick Tuners's Avatar
KB'd GT
Got any proof? I'm been looking for proof on this for years, and have yet to come across any real data, only saw one guy that did it, but he never shared any data. I'm talking about meth on PD blower with an intercooler.
Old August 12th, 2008, 03:27 PM   #25
onederful100's Avatar
2007 GT 2000 GT
onederful100 has a spectacular aura aboutonederful100 has a spectacular aura aboutonederful100 has a spectacular aura about
what about a better fan, like flex fan.
http://i243.photobucket.com/albums/ff26/onederful100/avatars/sig-52.gif
2007 GT 5spd
2000 GT 5spd
whipple crew member
2-Stang Crew
My Car
Old August 12th, 2008, 11:23 PM   #26
2005 Saleen
Not sure, but I need any ideas as possible! By a better fan, you mean radiator fan?
Old August 13th, 2008, 09:54 AM   #27
racevert's Avatar
racevert is on a distinguished road
I have the same Kenne Bell blower and I upgraded the heat exchanger, the coolant reservoir and the intercooler pump. Here are some pics of what I did. I went with the AFCO GT500 double-pass heat exchanger, a custom fabbed aluminum icebox/tank and a Ford Lightning Bosch pump.
You dont want a really high capacity pump as it will push the coolant through the HE so fast it wont have a chance to cool properly. The AFCO HE is a direct fit and it comes with nice brackets and rubber bushings to mount up the HE. Before this upgrade I could not touch the top of the blower after a run without burning my hand. Now I can place my hand on there and there is little if no heat.
Old August 13th, 2008, 09:55 AM   #28
racevert's Avatar
Here are some images of the mods I did to my KB setup.
Old August 13th, 2008, 10:15 AM   #29
05mustang_TT_charged's Avatar
2005 Mustang GT
10.32@137.70
05mustang_TT_charged is a jewel in the rough05mustang_TT_charged is a jewel in the rough05mustang_TT_charged is a jewel in the rough05mustang_TT_charged is a jewel in the rough
did you get the intercooler reservoir from ST Motorsports? What heat exchanger is that? Gords?
350 rwhp and 310 rwtq at 6000 rpms through stock exhaust system
326 cubic inches of Twin Turbocharged hell will be running soon
Tuned by Wes @ TPS
Old August 13th, 2008, 10:24 AM   #30
with it injected after the cooler coil under the blower how does it have time to condense... it has been used for years... what kid of real data do you want... look at the GT500 the put the Snow kit on in MM&FF... you can see the difference in intake temps... I'm not trusting their dyno numbers cause the can alter the tune a bit and they did... They gave it more timing to go along with lower temps and the higher octane from using the meth... and the used it before the throttle body...
do you have any proof it doesn't work?
Old August 13th, 2008, 11:11 AM   #31
2005 Saleen
I read about your setup on another forum and you're the one that inspired me on the intercooler and what not. How much did this whole setup run you? I'm not sure if I have anywhere to fit a bigger coolant tank. If I did just the lightning pump and the new I/C, would that be enough?
Old August 13th, 2008, 03:19 PM   #32
racevert's Avatar
The AFCO Heat exchanger I picked up at Lethal from Jared -399.95
(I like the AFCO double-pass better than Gords, I compared both. The Gords is to stubby because Gord designed it for the Termis. AFCO has more capacity and puts the coolant through twice.)
The lightning pump I picked up from Blue Oval Industries for 79.95 (on Ebay)
The tank was fabbed by Adam at ST for $320.00
Some extra heater hoses and clamps ran about $25.00
Total 825.00 and about 4 hours to do the job in my garage.
I ran water wetter and a bag of ice at the track to lower IAT.
The difference in the temperature of the KB aftwerwards is amazing.
The HE will help a lot for daily driving, not as much at the track because it only has 11 seconds to cool the fluid. The intercooler tank and icebox help the most at the track. I had to remove my windshield washer reservoir to put the tank in but this car never has seen rain anyways.
2006 Mustang GT vert
Six-point chrome moly rollbar
Kenne Bell 2.4 Twin-screw
AFCO GT500 double-pass HE
Ford Lightning intercooler pump
Level 10 Stage III 5R55S
Level 10 PTS billett converter
Powerhouse driveshaft
11.42 @ 118.92 MPH 1.63
Old August 13th, 2008, 09:41 PM   #33
2005 Saleen
Maybe I will do just the intercooler and see how my heat soak issue is. Thanks for all the info, your set up is amazing!
LinkBack to this Thread: http://www.moddedmustangs.com/forums/2005-2010/84229-supercharger-cooling.html
Supercharger Cooling? - Page 2 This thread Refback August 13th, 2008 10:00 PM
Threads Similar to: Supercharger Cooling?
Cooling usafimj 2005 - 2010 4 June 25th, 2008 11:19 PM
cooling problems RyanGT 99-04 30 August 16th, 2007 07:42 PM
Cooling Question JBIGBOOTSY 5.0 Mustangs 2 May 20th, 2007 12:22 AM
Cooling Fan Stangzilla 5.0 Mustangs 23 March 25th, 2007 10:15 AM
cooling zhunter V6 Mustangs 2 January 25th, 2006 06:18 PM
