Window Switch?
Old August 13th, 2008, 10:57 AM   #1
06SuperStang's Avatar
2006 Mustang GT
06SuperStang is on a distinguished road
Window Switch?
what wire do yall tie into for the window switch?
2006 Mustang GT (Auto),FRPP Hot Rod Cams,Hooker Longtubes w/ Off Road X-Pipe,Stock Mufflers,TCI 3000 Stall,Delete Plates,C&L Racer CAI,Tuned By The Guys From American Muscle,FRPP 3.73's,Coast Line Full Length DriveShaft
Old August 13th, 2008, 11:07 AM   #2
May 08 ROTM
2008 Audi S6
Emay has much to be proud ofEmay has much to be proud ofEmay has much to be proud ofEmay has much to be proud ofEmay has much to be proud ofEmay has much to be proud ofEmay has much to be proud ofEmay has much to be proud ofEmay has much to be proud ofEmay has much to be proud of
06, what exactly are you trying to do and what window switch are you using? Depending on manufacturer, polarity is done differently and the wires required are therefore opposite.
You need to patch into the WOT wire, and at the minimum on every window switch there is a switched power and a ground. However there are some with RPM lockout in first sequence of RPM range to eliminate 1st gear activation.
Give us some more specifics..
FLICKR Unique Imagery
Old August 13th, 2008, 01:21 PM   #3
2006 Mustang GT
well im in the middle of installing a NX dual nozzle 100 shot on my car. im using a MSD window switch and not sure what wire you tie into to run in the factory rpm tach.
Old August 13th, 2008, 01:37 PM   #4
May 08 ROTM
2008 Audi S6
Is it the msd digital window switch?
Old August 13th, 2008, 02:22 PM   #5
Bhblondguy's Avatar
2005 Mustang GT
12.00@114.82
Bhblondguy will become famous soon enoughBhblondguy will become famous soon enough
I used the zex window switch. I've heard that many people have problems with the msd window switches from my tuner.
Old August 13th, 2008, 02:39 PM   #6
2006 Mustang GT
no its not the digital one
Old August 13th, 2008, 02:49 PM   #7
May 08 ROTM
2008 Audi S6
You will likely need a tach adapter in order for the non digital to pick up the signal from a single COP.
Old August 13th, 2008, 02:53 PM   #8
2006 Mustang GT
where can i get one?
Old August 13th, 2008, 03:06 PM   #9
2006 Mustang GT
MSD Tach Adapter will this work?
Threads Similar to: Window Switch?
Window Switch mystang0673 General Tech 3 November 19th, 2007 05:58 PM
window switch? 00redgt 99-04 6 November 5th, 2007 06:03 PM
rpm window switch. mustangrebuilder Audio/Video 0 September 18th, 2007 08:58 PM
window switch barksdaleammo General Tech 31 May 23rd, 2007 09:33 PM
Wiring window switch Timber 99-04 11 March 22nd, 2007 07:26 PM
