2007 GT
Long tubes.
if i have a lift. how hard is the kooks long tube install? and i say kooks becuase i have heard they are the easiest of the long tubes to install. and how hard is this job on a 03 termi, any different then a 3 vavle?
can i do it all from the bottom without unbolting the engine or steering column? |
May 08 ROTM
2008 Audi S6
Kooks are the same as ARH and the majority, some have slight difference in tube angle, but for the most part following the same path for install makes the job exactly the same in difficulty.
Since your talkin termi, be prepared to bust up a bunch of knuckles because with the 4 valve heads there is far less room to work on them in a far more crowded engine bay than our S197's. You will definately need to pull the starter, and engine mounts to get the headers up into their positions, they will not slide right up..
2007 GT
Kooks are the same as arh in what way? I can see the arh are longer and bent differently.
all cobras 99 and up are a PITA to install LTs on
![]() Under Construction |
don't you have to remove the tranny crossmember in the 99-04
07 GT-- Gone But Not Forgotten Military Crew E-5
2006 Mustang GT
10.82@125.2
yea that n the k member.. unless theyre the same thing
May 08 ROTM
2008 Audi S6
I said tubes are slightly different. Essentially fit the same, the time to get them in is no different. The length affects nothing..
2007 GT
alright thanks gentleman.
Threads Similar to: Long tubes.
| Long Tubes For A '96 | 6banger96 | V6 Mustangs | 12 | December 7th, 2007 02:52 AM |
| long tubes | shiftyV6 | V6 Mustangs | 19 | October 23rd, 2007 02:35 PM |
| long tubes ? | 331n2o66stang | 96-98 | 0 | September 30th, 2007 02:43 PM |
| for those with long tubes... | the real shocker | 99-04 | 6 | August 11th, 2007 09:38 PM |
| Long tubes... what goes after them? | Slowbra_12 | General Tech | 2 | July 26th, 2007 03:07 PM |
