driveshaft safety loop
Old August 20th, 2008, 01:07 AM   #1
Draztic1 is on a distinguished road
hey stangers...i have a 07 stang with the spydershaft one piece alum. d.s. and i need a safety loop that fits...can anyone help me out...thanks
Old August 20th, 2008, 05:48 AM   #2
2007 GT
07stanggt has much to be proud of07stanggt has much to be proud of07stanggt has much to be proud of07stanggt has much to be proud of07stanggt has much to be proud of07stanggt has much to be proud of07stanggt has much to be proud of07stanggt has much to be proud of
I sent you a pm but here you go.
BMR Rear Tunnel brace with loop 05+
BMR Front Driveshaft Safety Loop 05+
Old August 20th, 2008, 07:14 AM   #3
MaverickMLFD371's Avatar
2005
MaverickMLFD371 will become famous soon enough
Send a message via AIM to MaverickMLFD371 Send a message via Yahoo to MaverickMLFD371
all you need is the front one, in the event of a shaft failure it doesn't catapult your car like a pole vault.
BMR is the one to get
Old August 20th, 2008, 12:02 PM   #4
06BeastGT is on a distinguished road
I will be getting a DS by Spydershafts as well, do i need these also?>???
Old August 20th, 2008, 01:43 PM   #5
leebunnyz's Avatar
leebunnyz has a spectacular aura aboutleebunnyz has a spectacular aura about
yes...well...you dont "Need" one but its a lot safer and better if you do.
Jesus Christ is #1
"The Founder Of Crews"
Old August 20th, 2008, 11:35 PM   #6
bkid's Avatar
2006 Mustang GT
14.024
bkid is on a distinguished road
Check out the CHE safety loop it is a nice piece and easy install.
Old August 21st, 2008, 12:04 AM   #7
thanks guys...i definately need one .....i just want to know how are you sure its gunna fit the spydershaft cause its alooot wider than the stock one
Old August 21st, 2008, 12:18 AM   #8
scramblr's Avatar
2006 Mustang GT
scramblr is on a distinguished road
The BMR fits, I have it. The Spyder is tapered on the tranny side, so there's plenty of room. However, I don't think the BMR rear loop will work with it and if it does it would be pretty close.
11.67 - 1.64 60' @ 119mph
Livernois 298ci Stroker, Saleen S/C, GT500 FPs, SD 60# inj, GT500 T/B, Thump Tensioner, BGG 8 Rib, Kooks, Gords HE, 4.10, TrueTrac, Spec 3+, Pro 5.0
Threads Similar to: driveshaft safety loop
Installed my new Power House D/S & Safety loop bkid 2005 - 2010 7 June 22nd, 2008 02:21 PM
Driveshaft safety loop shurb125 5.0 Mustangs 17 March 21st, 2008 08:48 PM
Drive shaft safety loop location nolife 5.0 Mustangs 8 October 13th, 2007 09:17 PM
Hurst Short Throw and BMR Front Drive Shaft Safety Loop Gunny 2005 - 2010 2 August 20th, 2007 11:26 AM
Driveshaft Loop Plans Twist 2 Go General Tech 4 August 24th, 2005 08:46 AM
