2007 Mustang GT
12.6@110
It has begun!!!
Dropped the car off this morning at the shop to have the vortech kit installed and the 3.73 gears installed (upgrade from my 3.31 stock gears). Vortech kit includes:
Vortech T-trim that was recently sent to Vortech for an Upgrade per Vortech. Head unit has Zero miles on it now. Vortech Air Chiller assembly with Vortech Blow Off Valve Assembly Vortech 10-lb lower pulley and Vortech 4-lb upper pulley for 14psi boost. Uses a Gates belt which is included but I would recommend replacing in the future. (this is being replaced to push down to 10-11 psi) Vortech Coolant Tank. Upgraded Vortech Ice Chiller Box that can be mounted in the trunk or in the battery box area. Vortech Bumper Mount Heat Exchanger with Bosch Coolant transfer Pump. K&N Air Filter and Tube Assembly Edge Products 60-lb injectors with Fuel Harness adapters only 3-dyno passes Diablosport Mafia for Mass air and Injectors used for only 3-dyno pulls SCT2200 Mass air meter Used for only 3-dyno pulls Ford Racing GT500 Fuel Pumps Used for only 3-dyno pulls SCT Tuner with 3-custom Dyne Tuned programs, if you use the GT500 pumps you will have to have a tuner change your PCM settings for it to work properly or it will throw codes. Any one care to make estimates on what my dyno should show by the end? And what my track times would be? I haven't run at the track yet with my 20s and nittos, my best time at the track was my first time there and only made 4 runs. I'd like to think I'm capable of pulling a 13.5 with what I had on just through better shifting and better launch.
![]() Professor Crackers
MM's resident Juice head
07 Mustang GT
are you forged?
![]() The MGW short throw shifter Its not just a shifter...It's a lifestyle! |
2007 Mustang GT
12.6@110
no...
07 Mustang GT
just asking...
August 08 ROTM
2006 GT Kenne Bell S/C'd
14lbs of boost and you have no forged internals? How long do you think that motor gonna last?
![]() 2006 GT 2.6L Kenne Bell @ 10lbs boost tuned by Straight Line Performance "That car runs on race fuel? Oh, so you can't smoke in it or it would blow up, right?" |
2007 Mustang GT
12.6@110
No worries, got it under control, hehe.
One Man Wolf Pack
Congrats. Be sure to post pics!
![]() ΜΟΛΩΝ ΛΑΒΕ
2007 Mustang GT
12.6@110
Hehe, oh, I'll be pic/vid whorin it up. The shop actually specializes in classic mustang restorations. They had a GORGEOUS 72 mach they just finished. Completely stripped it to metal, redid the whole paint job. It's got to be the sexiest mach I've ever seen.
One Man Wolf Pack
![]() ΜΟΛΩΝ ΛΑΒΕ
2007 Mustang GT
12.6@110
Yea, yea, yea. Where's the smiley for "This thread is to keep me sane while I'm at work and my baby is at an automotive shop 20 minutes away!!!"?
2007 Mustang GT
12.6@110
Bah, can't edit my post. No estimates though on what HP I can achieve on 10psi with a centri and those added parts to the kit? I'm definitely curious on my 1/4 times, I was guessing on my 20s and nittos that mid to low 12s would be my bracket, probably mid 12s though. With seat time, short throw, suspension, and some drag radials on my stock 17s I was thinking I could see 11s?
#12 | |
May 08 ROTM
2008 Audi S6
It's also very common for the Gates to wear more, in turn causing more under hood dust. Also, it's not a true statement that the GT500 pumps throw codes, I ran the pumps untuned for 2 weeks while waiting on my c500 parts to return from paint and my wheels to arrive from NAD so I could drive the car to the tuner. It ran fine, was codeless, and I couldn't resist but to jump on it a few times to boot. |
#13 | |
2007 Mustang GT
12.6@110
![]() Any idea on what to do to get the car started up without a canned tune from vortech? Will my stock tune start it up good enough to get it dyno tuned? If so, I can save some money on towing it to the dyno shop..
May 08 ROTM
2008 Audi S6
If you stay completely out of boost, the car can and will be able to be limped to the dyno. You could ask vortech to email you a flat line tune, I've done that through Brenspeed several times for 2 procharger and a whipple install.
#15 | |
2007 Mustang GT
12.6@110
Tree Fiddy Z
probably vortech. If it's anyplace that sells the same product, they won't give you anything since you did not give them the business. It's sad they're like that but they want your money
May 08 ROTM
2008 Audi S6
Brents a pretty good guy he may help you out. Who did you buy the SCT from? I'm guessing the same person as the charger came from? If so, there should be a conservative tune in there.
2007 Mustang GT
12.6@110
I'm sure Brenspeed wouldn't do that, I've ordered my exhaust through them and plan on having them look over my tune.
I Poop Entirely Way Too Much
Blown 03 GT
What tuner are you using? My shop gave me a canned tune with the programmer i bought from them for my exact application so i can drive to their shop.
2007 Mustang GT
12.6@110
going through a local performance shop called Supertune, they are who the shop doing the install works with.
Threads Similar to: It has begun!!!
| it's begun | 707Stang | The Clubhouse | 5 | August 12th, 2008 07:48 PM |
| It Has Begun | rk_2000_Z/28 | 4V / SVT | 41 | July 1st, 2008 11:41 PM |
| The Battle has begun :) | LuckyB | 2005 - 2010 | 33 | May 19th, 2008 09:45 PM |
| It has begun... | homebrewed | The Clubhouse | 18 | November 1st, 2007 07:06 PM |
| Destruction has begun!! | ujslost | 2.3 Mustangs | 13 | July 6th, 2007 10:50 AM |
