2006 Mustang GT
Spark Plugs?
just finished the nitrous install now im about start to change the plugs. just wondering if i have to gap the plugs? is there any other tips i should know about?
2006 Mustang GT (Auto),FRPP Hot Rod Cams,Hooker Longtubes w/ Off Road X-Pipe,Stock Mufflers,TCI 3000 Stall,Delete Plates,C&L Racer CAI,Tuned By The Guys From American Muscle,FRPP 3.73's,Coast Line Full Length DriveShaft
2005 Turbonetics Baby!!!
Be very careful removing the old plugs!!! They break/shear very easily. If you break the insulator it can fall into the engine. I sheared one of mine off, then I sprayed penetrating fluid on the rest and let them soak...then sprayed some more. The rest came out with no problems and I used a 1/4" easy out to remove the sheared one. Yes you do have to gap the plugs with one of these...
Spark Plug Gapper 3V Mustang (05-08) You can find them for less though...I'd try Derek at D'Agostino racing. I think they have the best price on them. Also, make sure they are the HT0's so you won't burn the ground strap off. Read this first... http://www.moddedmustangs.com/forums...g-problem.html
![]() Turbonetics baby!!! 11.23@122 mph... Last edited by ROUSH STAGE II; September 5th, 2008 at 11:11 PM. Reason: added info |
2006 Mustang GT
i seen the pic, now how exactly to you gap them? and what do you gap them to?
.032 should be fine.
![]() Turbonetics baby!!! 11.23@122 mph... |
2006 Mustang GT
for nitrous? so im guessing they dont carry this tool at any local parts store?
Nope...sorry. Not anywhere that I've found.
Yes the tool is hard to come by, however if you know what you are doing you can use large channel lock pliers. You just have to be very careful but it works the same way. Also to gap them you need a feeler gauge.
Threads Similar to: Spark Plugs?
| spark plugs | gooberhead320 | V6 Mustangs | 46 | June 2nd, 2008 02:18 PM |
| help with spark plugs | cassimus | 99-04 | 12 | May 27th, 2008 11:21 PM |
| Spark Plugs. | Ugmul | 99-04 | 8 | March 19th, 2008 09:37 PM |
| Spark Plugs | soccerboy08 | V6 Mustangs | 14 | February 4th, 2008 07:14 PM |
| spark plugs | Grimmy | Classic Mustangs | 10 | February 14th, 2007 10:20 AM |
