Hellion turbo is here
Old September 25th, 2008, 01:04 PM   #1
2008 Mustang GT
kryologik is on a distinguished road
Just got my Hellion kit in on Tuesday. I ordered the T-76mmbb kit with the ugpraded heat shield and bov.. I didn't know that would delete the injectors, so I had to drop down some more money yesterday for 60lb injectors and my gauges (nexus wideband, boostvac, sos dual pillar).
I should be getting it installed by the local shop here close to me (MAK Performance in Hialeah) within the next couple of weeks. I'll keep you all updated on it -- will also post a vid of 0-60/100 before and after.
Hellion Power Systems 76mmbb kit
BMR (Bumpsteer, HD Swaybar kit, Strut brace, Tubular LCA's, Tubular Panhard Bar, Tokico D-Spec)
Eibach Sportline Kit
Magnaflow Exhaust
BAER Big Brake Kit (Front/Rear)
484whp / 491lb-ft tq @ 9psi
Old September 25th, 2008, 01:13 PM   #2
forensicsteve will become famous soon enough
Awesome. The 76s are good for an efficient 25+ lbs of boost. And if that's not enough, just do what I did.....add nitrous...lol. Your next challenge will likely be traction.
Old September 25th, 2008, 01:13 PM   #3
RStrick0352's Avatar
2007 Mustang GT
11.40 @ 121 mph
RStrick0352 will become famous soon enough
Send a message via AIM to RStrick0352 Send a message via Yahoo to RStrick0352
Sounds sick man. You running that 76mm on a stock motor, if so use caution that is a huge turbo!!!!
GT 6sp Grabber Orange
For mods check my garage.
349 rwhp, 331 rwtrq Naturally Aspirated
445 rwhp, 495 rwtrq 100 Shot
60ft: 1.74
1/4: 12.15 @ 112.43 N/A
60ft: 1.71
11.40 @ 121.18 100 shot Nitrous
Old September 25th, 2008, 01:21 PM   #4
Should be fine as long as he doesn't get greedy with the boost. I upgraded to a 76 from a 67. Noticed a slight lag with the change up.
Old September 25th, 2008, 01:25 PM   #5
2007 Mustang GT
11.40 @ 121 mph
I'm so jealous of you turbo guys. I want it so bad!!!! I'm kinda stuck to the point where I need to do a engine build when I do it. I also intend on doing an STS setup so I can keep my longtubes. Maybe after this deployment I'll do the single turbo, do a small shot of nitrous to assist in spooling and just upgrade to the twins as the funds come. I love my nitrous, it just breaks my heart because its not always there
60ft: 1.74
60ft: 1.71
Old September 25th, 2008, 01:31 PM   #6
2008 Mustang GT
I'm going to stick with 10psi until I upgrade the motor.. how bad of a lag should I be expecting with the 76 @ 10psi? The next thing I'm investing in is my tires and rims, after that I'm not really sure if I should throw down for a stroker kit or for some suspension mods =/
Magnaflow Exhaust
Old September 25th, 2008, 01:37 PM   #7
2007 Mustang GT
11.40 @ 121 mph
Suspension. Why bother with all that power if you cant get it to the ground.
60ft: 1.74
60ft: 1.71
Old September 25th, 2008, 01:46 PM   #8
lilmarc1988's Avatar
2001 mustang gt
lilmarc1988 will become famous soon enough
Send a message via AIM to lilmarc1988 Send a message via Yahoo to lilmarc1988
i want turbo!!!
Old September 25th, 2008, 01:48 PM   #9
10 lbs of boost is 10 lbs of boost regardless of turbo size. The 76 is just more efficient at the higher boost levels and also offers more lbs of boost. The larger the turbo unit, the more mass there is to spool. Lag is irrelevant for my car because it does not street race and it's set up for dragracing that eliminates any lag. But there a noticeable hesitation when you accelerate hard from a roll... but when it kicks in, you had better be going in a straight line on a dry surface.
Old September 25th, 2008, 02:20 PM   #10
psycho bob's Avatar
07 GT
12.86@104
psycho bob is a name known to allpsycho bob is a name known to allpsycho bob is a name known to allpsycho bob is a name known to allpsycho bob is a name known to allpsycho bob is a name known to all
Send a message via Yahoo to psycho bob
i agree and disagree about suspension. i agree that it's more important than getting more power available. i think though if you have the funds readily available to do one or the other then i'd go with the engine. it's much much easier to piece together your suspension. you can't piece together an engine.....well i guess you kinda can, but you'd have parts just sitting there waiting till you get all of them.
Originally Posted by RZNCAIN View Post
I didn't check for spelling so fuck off with your grammar police.
http://www.moddedmustangs.com/forums...build-bob.html
Old September 25th, 2008, 03:34 PM   #11
2007 Mustang GT
11.40 @ 121 mph
Touche'
60ft: 1.74
60ft: 1.71
Threads Similar to: Hellion turbo is here
Hellion Turbo kit 05roush0090 2005 - 2010 14 September 7th, 2008 08:52 PM
Hellion Turbo Questions killermach1 2005 - 2010 38 January 2nd, 2008 08:12 PM
Hellion Turbo Value wadman 2005 - 2010 8 December 12th, 2007 12:27 AM
Hellion Turbo Lazyracer 2005 - 2010 14 October 19th, 2007 11:13 AM
Hellion Turbo FLA Dreadhead 2005 - 2010 5 February 22nd, 2007 04:20 PM
