LinkBack (2) | Thread Tools |
#1
2006 Mustang GT
12.01@ 115.58
any one having shift problems with the 5R55S
is any one having shift problems with the 5R55S, I have noticed a few problems like no RPM drop from 1rst to 2end gear under low throttle driving and today under 75% throttle 2end gear hit the rev limiter for a few seconds before shifting to 3rd. I like to down shift to help with braking in rush hour or in coming off of a heavy speed run. Am I not supposed to Manually downshift my car? under 100% throttle the trany shifts perfect with RPM drop and punch in every gear. any input would help thanks
2005 Mustang GT
13.76@101
do you have an aftermarket tune on the car?
![]() 343RWHP
2005 Mustang GT
13.76@101
because if you do i would get in contact with whoever supplied your tune. my brenspeed tune changes how my transmission shifts, however i havnt had any problems like that with it
![]() 343RWHP
2006 Mustang GT
12.01@ 115.58
nope, stock tune, I do have single chamber flowmasters and a cold air intake installed.
I have an auto with bama tune. It has never hit the rev limiter. Also don't down shift manually to much. Just use your brakes they are cheaper. If I manually shift then this is what I go by when downshifting manually. From 5th to 4th 50mph. From 4th to 3rd 40mph. From 3rd to 2nd 20mph and from 2nd to 1st nothing faster than 15mph.
1994 Cobra - Bassanni Shorties, Borla Catback, JLT CAI, MSD Cap & Rotor, FRPP Spark Plug Wires Coming soon: FRPP Aluminum Driveshaft, Aluminum Flywheel, and X-pipe |
2006 Mustang GT
12.01@ 115.58
any one know the power train warranty on the mustang? is it 36k?
its just that I don't aspect any shifting problems on a car with 20k on the OD. |
2006 Mustang GT
12.01@ 115.58
*BUMP* is any one else having these problems>?
I dont know the 5r55... but if it is designed the same as most auto's, it could either be low line pressure (which could be anything from the front pump being damaged by the verter, or round out or blow by) or a failing (as in heat scored, worn down) second gear band and drum.. manually downshifting gets all sorts of yay/ney... but in my experience, down shifting an auto isn't great because your using the friction materials to match the revs, i.e one part is speeding up the other by means of friction... NOT great for lengevity unless the trans was designed to do so (racing trans with heavy duty frictions/high line pressure)
does it sound like its banging the rev limiter then catching the gear so to speak? dont mean to worry you but, sounds like a slipping 2nd gear.
2006 Mustang GT
12.01@ 115.58
yes , today it hit the rev lim for a few ticks then banged 3rd
ouch... do you have any mods? as in cai/tune? or gears?
Yea that doesnt sound good. Take it to the dealer and see what they say.
2006 Mustang GT
12.01@ 115.58
no everything is stock sept for flow masters and cold air intake
2006 Mustang GT
12.01@ 115.58
but it doesent do this all the time, its intermittent
like when the tranny gets nice and warm?
Got this off of modularfords.com
Some of you have probably read my previous thread describing a 3rd gear failure in my 5R55S automatic transmission with only 9,500 miles. After doing considerable research using my Ford Service Manual DVD and pestering several transmission builders here is what I have determined. The root cause of the 3rd gear failures is the seal on the intermediate servo piston. By not continuing to drive the vehicle with this failure, the band is most likely not damaged. I spoke with a couple of transmission techs at 2 different Ford dealers and both said they replace 2 to 3 of these intermediate servo pistons a month for this exact reason.
hmmm... thats not comforting at all.
sounds like an after market servo would be a good idea to give some more clamping force. |
2006 Mustang GT
12.01@ 115.58
transmission dont slip when cold...
change your fluid/check level and post a pic of the color. |
2006 Mustang GT
12.01@ 115.58
can't theres no trany dip stick
uhhh... really? thats awful fucked up of Ford....
LinkBack to this Thread: http://www.moddedmustangs.com/forums/2005-2010/90977-any-one-having-shift-problems-5r55s.html
| Info.com - 5r55s harsh 1 2 shift - www.Info.com | This thread | Refback | January 11th, 2011 12:54 PM | |
| any one having shift problems with the 5R55S | Free Online Car and Truck Repair Help Tips and Guides, Replace Your Car and Truck Parts | This thread | Refback | April 15th, 2010 05:14 PM | |
Threads Similar to: any one having shift problems with the 5R55S
| 1,2,3, Shift | 6ER THEN I 8ER! | V6 Mustangs | 20 | March 27th, 2008 05:09 PM |
| Hope for the 5R55S?? | tlt05gt | 2005 - 2010 | 27 | March 21st, 2008 05:57 PM |
| Tuner..Shift Points and Shift Pressure..??! | Cesar2cool | 99-04 | 6 | February 19th, 2008 01:44 PM |
| 5r55s ????? | mow | 2005 - 2010 | 4 | June 30th, 2007 10:19 AM |
| Shift problems | JSmith9136 | V6 Mustangs | 10 | January 14th, 2007 09:48 PM |
