Upper Control Arm
Old September 30th, 2008, 09:00 PM   #1
usafimj's Avatar
2007 Ford Mustang GT
12.847 @ 114.12mph
usafimj is a glorious beacon of lightusafimj is a glorious beacon of lightusafimj is a glorious beacon of lightusafimj is a glorious beacon of lightusafimj is a glorious beacon of light
Send a message via Yahoo to usafimj
Upper Control Arm
Going to try and get a few people to install all the suspension pieces in my garage and was wondering if its necessary to install the bmr uca or until another time.
07 GT-- Gone But Not Forgotten
Military Crew
E-5
Old September 30th, 2008, 09:07 PM   #2
qwik48r's Avatar
alotta shit
no fat girls fast
qwik48r is a jewel in the roughqwik48r is a jewel in the roughqwik48r is a jewel in the rough
Send a message via AIM to qwik48r
why not do it?
mind your business what i drive... i'm on a fucking mustang forum.
qwik's build
Old September 30th, 2008, 09:12 PM   #3
usafimj's Avatar
12.847 @ 114.12mph
don't you have to lower the gas tank
Military Crew
E-5
Old September 30th, 2008, 09:14 PM   #4
qwik48r's Avatar
alotta shit
no fat girls fast
HUH?!!!
doesnt look like I would have (just looked at my car)
but hey, shit always looks different once you start ripping into it...
but I say no.
qwik's build
Old September 30th, 2008, 09:53 PM   #5
usafimj's Avatar
12.847 @ 114.12mph
Below is what I have right now. Do I need adj. camber bolts Camber Adjustment Bolt Kit for 05-08 Mustangs
- BMR Lowering Springs
- BMR Adj Panhard Bar
- BMR Control Arm Relocation Brackets
- BMR Upper Control Arm
- BMR Lower Control Arm
- Tokico HP shocks/struts
Military Crew
E-5
Old September 30th, 2008, 09:53 PM   #6
qwik48r's Avatar
alotta shit
no fat girls fast
yes.
qwik's build
Old September 30th, 2008, 09:57 PM   #7
usafimj's Avatar
12.847 @ 114.12mph
How hard is it to adjust the camber on your own or do I need to take it to a shop to do it
Military Crew
E-5
Old September 30th, 2008, 10:01 PM   #8
qwik48r's Avatar
alotta shit
no fat girls fast
shop has alignment tools. they make gauges to do it yourself... call an alignment shop and get the tolerences for a shelby gt. I look it up for you.
qwik's build
Old September 30th, 2008, 10:04 PM   #9
usafimj's Avatar
12.847 @ 114.12mph
Do I need to put the bolts in or do they do that. Doesn't Firestone have lifetime alignment deals
Military Crew
E-5
Old September 30th, 2008, 10:16 PM   #10
2007 GT
07stanggt has much to be proud of07stanggt has much to be proud of07stanggt has much to be proud of07stanggt has much to be proud of07stanggt has much to be proud of07stanggt has much to be proud of07stanggt has much to be proud of07stanggt has much to be proud of
You dont have to install the UCA. Your pinion is off, you lowered the car, so if you want it right then you need to. With a two piece drivshaft youll probably never know the difference except in your short times.
The camber bolts are what you use to adjust the camber. If you can get the specs for a shelby gt that would work. firestone does not have specs for the shelby gt, they have specs for the gt 500, and gt. neither is what you need, the gt 500 is not lowered.
You can buy a camber gauge for 50 bucks. or try to find and specialty shop.
I called firestone and they dont have them. I tried to have good year do my aligment for 75, they said they had specs on a shelby gt, when i looked at the sheet after the alignment it said gt 500, which i speciffically told them wouldnt work. So i finally found a shop to do it for me right, a performance suspension shop.
Old September 30th, 2008, 10:19 PM   #11
usafimj's Avatar
12.847 @ 114.12mph
So the specs for a shelby gt are the same for my gt, correct.
Military Crew
E-5
Old September 30th, 2008, 10:22 PM   #12
2007 GT
I forgot what springs you have. but the shelby gt is lowered with FRPP springs. 1.3 in the front 1.4 in the back. anything close to that your good, eibach pro kit, BMR springs.
Old September 30th, 2008, 10:25 PM   #13
usafimj's Avatar
12.847 @ 114.12mph
The suspension pieces I have are on post #5
Military Crew
E-5
Old September 30th, 2008, 10:26 PM   #14
2007 GT
here is a thought. In theory, your camber will be off -1.5. if you drop it with any of those springs. the bmr bolts are 2 degree bolts. even if you adjust them to the max, it would be damn close to haveing your camber correct. certianly within spec. But the ultimate thing would be to find a shop that truly can do it right for you.
Old September 30th, 2008, 10:27 PM   #15
2007 GT
yes the bmr springs are close enough. 1.25 in front and 1.5 in back.
Old September 30th, 2008, 10:28 PM   #16
usafimj's Avatar
12.847 @ 114.12mph
So do I need the camber bolts
Military Crew
E-5
Old September 30th, 2008, 10:29 PM   #17
qwik48r's Avatar
alotta shit
no fat girls fast
nahhh... rich brought the actuall specs in... I doubt you will..I thought bmr dropped further than that.
qwik's build
Old September 30th, 2008, 10:32 PM   #18
2007 GT
if you want your camber right you need something. i drove around with my camber off for over 30,000 miles. tires show it a little bit but not enough even now that i need tires. Its your choice.
Ford sells shelby gt's that haveing nothing done to correct the camber or aligment with a warranty. They take a gt, put those springs on and the other junk, they dont align that car that i know of. i have watched the process. And if that has changed call shelby automotive or ford racing and try to get the corrected specs. They wont know
Old September 30th, 2008, 10:35 PM   #19
usafimj's Avatar
12.847 @ 114.12mph
Cool. Thanks for answering my questions as always rich. You to qwik48r
Military Crew
E-5
Old September 30th, 2008, 10:36 PM   #20
2007 GT
Dont get me wrong it will be off, just like your rear is off and your pinion angle is off. Your choice what is important to you.
The funny thing is if you look at joeice's post about his suspension problem its kinda like me. I rolled with those springs and nothing else done for a long time. as i started to add all the other suspension stuff, like panhard bar, sway bars, control arms, then all the sudden my car felt outta wack until i got it aligned. maybe the car didnt know it was fucked up until then. i dont know.
Threads Similar to: Upper Control Arm
Upper Control Arm Install ThreeHonks302 5.0 Mustangs 10 August 11th, 2008 11:35 PM
Install Upper control arm.. 2006greyGT 2005 - 2010 7 March 23rd, 2008 09:28 PM
Should I Replace My Upper Control Arm Faulconer 2005 - 2010 6 June 14th, 2007 12:59 AM
Upper & Lower Control Arm stang94 5.0 Mustangs 5 March 14th, 2007 07:21 PM
Upper and Lower control ARM? stang94 5.0 Mustangs 9 December 6th, 2006 11:39 AM
