need help on stock internals?
Old October 6th, 2008, 04:21 PM   #1
kotten148 can only hope to improve
i was wondering how much rwhp stock rods and pistons can with stand saftly. from what i understand the crank can hold 600hp but im not sure as to what the other stuff can handle?
Old October 6th, 2008, 04:33 PM   #2
TheUNZippee!'s Avatar
450 is the general number. Many guys run that to 500, and then it's just luck of the draw, and how hard you are on the engine.
The connecting rods are the weakest link in these 4.6's.
BONER CREW EMPLOYEE - BWAL, CEO
Originally Posted by My Wife
Old October 6th, 2008, 04:55 PM   #3
yah
im dont get on my car that much but i like to sometimes lol. im not trying to go past 550 to the wheels
Old October 6th, 2008, 04:56 PM   #4
yah
so i should be could with around 450 to 500 on stock internals
Old October 6th, 2008, 04:57 PM   #5
Yes. But keep in mind that at that power level there is always a chance you could pop something. Some engines just last longer than others.
The most important thing, particularly if you're going forced induction, as it sounds like you are thinking to achieve that power, is the tune. A bad tune can grenade your engine right on the dyno before it even hits the street.
Old October 6th, 2008, 06:34 PM   #6
so pretty much its would be a good idea to use forged crank , pistons and rods just incase? what is a good set of rod and piston for a 06 gt
Old October 6th, 2008, 06:41 PM   #7
MM's resident Juice head
07 STROKER's Avatar
07 Mustang GT
07 STROKER is a splendid one to behold07 STROKER is a splendid one to behold07 STROKER is a splendid one to behold07 STROKER is a splendid one to behold07 STROKER is a splendid one to behold07 STROKER is a splendid one to behold
livernois, either 298 stroker or just their basic forged rotating assembly
good to 1000 hp..apparently
The MGW short throw shifter
Its not just a shifter...It's a lifestyle!
Old October 6th, 2008, 06:57 PM   #8
Bkbulldog's Avatar
Bkbulldog is on a distinguished road
how much does it coast to get the bottom end forged?
Old October 6th, 2008, 07:13 PM   #9
07 STROKER's Avatar
07 Mustang GT
2000 bucks. for the kit
Old October 6th, 2008, 07:19 PM   #10
All sissies going to Hell!
navyman8903's Avatar
2008 BULLITT #3385
Killing with a smile
navyman8903 is a name known to allnavyman8903 is a name known to allnavyman8903 is a name known to allnavyman8903 is a name known to allnavyman8903 is a name known to allnavyman8903 is a name known to all
jpc racing does a core transfer program where they bolt a stock aluminum block that has been stroked to a 302, complete bottom end for about $4,500.00ish. But they might not be in your area if you are going for a built bottom end and not mear maryland then go livernois. And stock you can go 500rwhp but it will matter how you do it. Not on a twinscrew, but on a centri you can, and I'm not sure on a turbo or nitrous.
BULLITT CREW FOUNDER (The real one)
Bassani Crew Member #5...HARDCORE CREW
MILITARY CREW
E-5
MA2(AW)
Personally, I think being railed in the shitter would make you a meaner more violent fighting machine.
Old October 6th, 2008, 07:22 PM   #11
New - Livernois Motorsports - 4.6L 3-Valve Standad Rotating Assembly
Threads Similar to: need help on stock internals?
rpm limit on stock internals TheBusher 99-04 24 March 6th, 2008 11:10 PM
Super Charged W/ Stock Internals. Dawgfude03GT Modular Mustangs 16 August 13th, 2007 09:36 PM
Stock 3V 4.6l internals manOwar 2005 - 2010 0 February 6th, 2007 01:49 PM
GSR stock internals @ 20psi? 03 R Code 99-04 17 December 11th, 2006 10:59 AM
01 GT Internals MnrlGry01gt 99-04 12 November 13th, 2006 12:59 AM
