New blower
LinkBack (1) Thread Tools
Old October 9th, 2008, 02:54 PM   1 links from elsewhere to this Post. Click to view. #1
I Poop Entirely Way Too Much
Blown 03 GT
03_StangGuy is just really nice03_StangGuy is just really nice03_StangGuy is just really nice03_StangGuy is just really nice
New blower
Those responsible for supercharging the Saleen S7, Saleen S281 Mustangs and Saleen/Parnelli Jones Limited Edition Mustang have been reassembled into TECHO, a company that is now producing twin screw superchargers for S197 Mustangs. While no numbers are provided we do have the specs of the supercharger. They are as follows:
* Reverse-Revolution Twin Screw Compressor with Asymmetric Multi-Lobe Screws
* 3.0L / 180 cu. in. Displacement
* Front Induction with Integrated Bypass
* 10 Inch Long Intake Runners
* Dual Stage Intercooler System with Single-Pass Coolant Flow through the A-Frame (2) Intercoolers, Large Capacity Heat Exchanger, High Volume Intercooler Pump and Recovery Tank
* Open Element Cold Air Kit with High-Flow Air Filter, CNC Venturi and High Flow Inlet Tube
* Extruded Aluminum Fuel Rails with upgraded fuel injectors where applicable
* Separate 8-Rib FEAD (Front End Accessory Drive) with Dampener
* Ultra-Light Weight Aluminum Construction
* Flash Programmer
* Instruction Manual
Press Release
TECHCO has reassembled the former Team that Designed, Developed, Tested and Certified the Saleen S7, Saleen S281 Mustangs, Saleen/Parnelli Jones Limited Edition Mustang, and Saleen S331 Sport Trucks. As collaborators and former employees of the famed automotive company, Saleen, Inc., TECHCO’s Staff has the talent and vision to bring decades of experience into the automotive aftermarket industry by the design, development and manufacturing of ultra-high performance automotive parts and accessories. “We’ve assembled a great team from the world of specialty vehicle performance, design and manufacturing. With our skills and resources, there’s no limit to what we can provide to our customers.” stated Jimmy Moore, Director of Operations for TECHCO.
TECHCO’s vision is to supply to our customer ultra-high performance automotive parts and accessories and offer complete Engineering, Manufacturing, and full Vehicle Assembly services. TECHCO has heavily invested in engineering and manufacturing equipment to provide unmatched in-house capabilities to develop and produce truly innovative and high quality products for the Aftermarket, while maintaining low costs and reduced lead times. The expansive 150,000 sq.ft. facility combines state-of-the-art engineering and manufacturing capabilities and resources with our hands on assembly experience. In-house resources include Engine and Chassis Dynamometers, CNC Machine Shop, CMM Lab, Fabrication Shop, SLS Prototyping, CAD/CAE workstations, R&D Lab, Component Subassembly Shop, Vehicle Workshop, Customer Install Shop, and Race Team with Workshop. These extensive in-house resources ensure TECHCO’s technical excellence and market competitiveness in the Automotive Industry. “Our spacious facility allows us room to house all our engineering and manufacturing equipment in one place, resulting in fast-time to-market and the highest quality products that still deliver exceptional value to our customers.” stated Jimmy Moore, Director of Operations for TECHCO.
The TECHCO Reverse-Revolution Twin Screw Supercharger™ is TECHCO’s flagship new product, will completely revolutionize supercharger design. “Our Design of the (TECHCO) Twin Screw Supercharger, is not merely further innovation in supercharging, but is truly a revolutionary advancement on Supercharger Design and application. We’ve taken all of our expertise in supercharger design and created a new product that provides superior power and performance on all levels.” Says John Spruill, Vice President of Engineering for TECHCO. “We designed innovation into every aspect of the new (TECHCO) Supercharger, from the Patent Pending new A-Frame (Dual) Intercooler configuration with Extruded Aluminum 6061-T6 Housing, to the all new 3.0L Reverse Rotation Screws with 6061-T6 Rotor Housing with fully integrated Bypass System, and Long, High Flow Runners. It’s like nothing else on the market today.” Says Billy Tally, Chief Technical Officer for TECHCO.
Nuts and Bolts of The TECHCO Reverse-Revolution Twin Screw Supercharger
What makes the TECHCO Reverse-Revolution Twin Screw Supercharger so revolutionary is the unique design (Patent Pending), which optimizes airflow efficiency throughout. Incoming air is fed into the front of the supercharger, not the back like conventional designs. This ensures that the incoming air has minimal turns, eliminating restrictions, before entering into the supercharger housing. Additionally, without the need for a complex inlet tube, the largest possible orifice size is maintained, maximizing air flow efficiencies. The air then flows into the lobes of the Reverse-Revolution asymmetric multi-lobe compressor screws, where it is compressed, not merely moved, as in other forms of supercharging. The compressed air then flows into the intercooler housing which houses (2) intercoolers mounted in an A-Frame configuration to ensure the airflow is evenly distributed to each runner bank. The Patent Pending Twin Intercooler design results in higher cooling capacity and greater thermal efficiencies as the cooling water only has to pass through the intercoolers once, keeping the charge air cool. A further benefit of the front Inlet Design is the additional package space above the supercharger that is used for long high flow Intake Runners, which increases low end torque.
The resulting design of The TECHCO Reverse-Revolution Twin Screw Supercharger allows air to move through the supercharger quickly and efficiently, without significant heat buildup, and at the highest resulting airflow volume at low boost output. The performance result is maximized horsepower and torque output.
Key Features of The TECHCO Reverse-Revolution Twin Screw Supercharger
* Flash Programmer
Applications
Dodge/Chrysler: All 5.7L/6.1L Challenger/Charger/Magnum/300C
Ford: 4.6L 3V Mustang
GM: C5/C6 Corvette
Much-o information-o here:
http://www.modularfords.com/forums/show ... p?t=118762
Old October 9th, 2008, 03:18 PM   #2
chad05gt's Avatar
2005 Mustang GT
12.0 @ 117+
chad05gt has a spectacular aura aboutchad05gt has a spectacular aura aboutchad05gt has a spectacular aura about
yes, as soon as one available...
built 302 on its way...and 67mm turbo,
No N20, No boost, ALL N/Asty!
12.0 @ 117+
FRPP intake, (thanx Joe)...
Fucking chad in my kitchen drinking my damn Kool-Aid. Fucker.
Old October 9th, 2008, 03:49 PM   #3
mustang fanatic's Avatar
Dont Tread On Me
mustang fanatic will become famous soon enoughmustang fanatic will become famous soon enough
Send a message via AIM to mustang fanatic Send a message via Yahoo to mustang fanatic
The Parnelli Jones isn't supercharged
2007 Mustang GT - Pretty much stock. Pypes pypebomb a/b, Tri-ax shifter.
Old October 9th, 2008, 04:54 PM   #4
One Man Wolf Pack
06RedfireGT's Avatar
2006 Mustang GT
13ish....maybe
Link doesn't work.
ΜΟΛΩΝ ΛΑΒΕ
Old October 9th, 2008, 04:58 PM   #5
usafimj's Avatar
2007 Ford Mustang GT
12.847 @ 114.12mph
usafimj is a glorious beacon of lightusafimj is a glorious beacon of lightusafimj is a glorious beacon of lightusafimj is a glorious beacon of lightusafimj is a glorious beacon of light
Send a message via Yahoo to usafimj
Hmm......wonder what it looks like
07 GT-- Gone But Not Forgotten
Military Crew
E-5
Old October 9th, 2008, 05:08 PM   #6
2003 GT
13.81@99
TruBluScreamer is on a distinguished road
Send a message via MSN to TruBluScreamer Send a message via Yahoo to TruBluScreamer
Ive heard about these things..... My dad wants one for his SRT 300c this is a pic of the Dodge version.... Looks pretty sick and i would imagine the ford one wont differ too terribly much!! IF you go to TECHCO International - Mustang Performance Parts there is some more info on there price is a little on the eek side!!!
A couple of pics and mod list in my garage.....http://www.moddedmustangs.com/forums...-member-18904/
Old October 9th, 2008, 05:52 PM   #7
05roush0090's Avatar
2005 Mustang GT Roush
05roush0090 will become famous soon enough
I just heard of this the other day. conincedence.
2005 BLACK Mustang GT Roush #05-0090
DOB manifold, m122 SC, gt500 TB, 52lbers, KB BAP, AFCO HE,Brisk plugs, Mac Lt's, Off road x, Roush TVS CAI, Detroit rocker sc grind cams, Brenspeed 93 tune,
10 psi (2.875" pulley) 470rwhp-419ftlbs sae
Old October 9th, 2008, 05:56 PM   #8
tribaltek's Avatar
tribaltek has a spectacular aura abouttribaltek has a spectacular aura about
It's pretty... but not $7k pretty.
'06 Whipple'd Mustang GT (Coming Soon)
'02 Supercharged Harley-Davidson F-150 (Sold)
'05 Mustang GT (Sold)
Old October 9th, 2008, 06:05 PM   #9
2003 GT
13.81@99
I second that!!!!
Old October 9th, 2008, 06:05 PM   #10
usafimj's Avatar
12.847 @ 114.12mph
For $7K i'd rather get the Saleen Supershaker or Whipple HO for $6K
Military Crew
E-5
Old October 9th, 2008, 06:36 PM   #11
chad05gt's Avatar
2005 Mustang GT
12.0 @ 117+
It'll make other twin screws second rate IF it delivers; anyone can write up and post a pretty picture... jury will be out on this for a while.
No matter what... good news.
12.0 @ 117+
Old October 9th, 2008, 07:36 PM   #12
2006greyGT's Avatar
2006 Satin Silver GT
11.08@125.22
2006greyGT has a spectacular aura about2006greyGT has a spectacular aura about2006greyGT has a spectacular aura about
Send a message via Yahoo to 2006greyGT
I'll stick to a proven winner...
[IMG]
2.6l KENNE BELL 298 Stroker, Ported heads
Pro Motion Built 3650/McLeod RST/ MGW Short Throw
Long tube/O/R X /Borla Touring
8 rib/65 lb injectors/GT500 twin fuel
ET Drag Slicks/3.73 gear
Detroit Truetrac /CDC AGR Spoiler
Old October 9th, 2008, 08:55 PM   #13
2005 Saleen
SUHLeen is on a distinguished road
Saleen makes great blowers that are great quality.
It sounds like an awesome set up. We will have to wait and see what it does
- Phil
05 Saleen Mustang - Broken son!
01 BMW 330ci - modded daily driver
Originally Posted by Lil Wayne
now weezy why you drive so fast? because I’m chasin’ the dream
Old October 12th, 2008, 01:01 AM   #14
UrbanRedneck's Avatar
2008 Mustang GT
13.124@105.52
UrbanRedneck is just really niceUrbanRedneck is just really niceUrbanRedneck is just really niceUrbanRedneck is just really niceUrbanRedneck is just really nice
isn't the S7 turbocharged?
Hurst Crew Member #20
2008 GT - ARH, C&L, Hurst, BORLA, BMR, Bilstein, FRPP, Axle Exchange. Awesome.
Old October 12th, 2008, 01:49 PM   #15
psycho bob's Avatar
07 GT
12.86@104
psycho bob is a name known to allpsycho bob is a name known to allpsycho bob is a name known to allpsycho bob is a name known to allpsycho bob is a name known to allpsycho bob is a name known to all
Send a message via Yahoo to psycho bob
it's not a saleen blower. it's from those that designed the fi for cars such as the s7, s281, and the parnelli jones car. (and yes the pj car isn't blown)
i also would rather have a tried and true blower. such as the kb. for 7g's i'll take kb's new one or whipples 3.4L. just cuz whipple doesn't make a kit for the 3V doesn't mean you can't use it.
Originally Posted by RZNCAIN View Post
I didn't check for spelling so fuck off with your grammar police.
http://www.moddedmustangs.com/forums...build-bob.html
Old October 13th, 2008, 12:59 AM   #16
2005 Saleen
I guess what I'm trying to say is it shouldn't be junk. Steve Saleen took a lot with him when he left and I'm willing to bet R&D and engineering type stuff...
- Phil
Old October 13th, 2008, 05:49 AM   #17
302svt's Avatar
302svt is on a distinguished road
Sounds good but too much money.
Old October 13th, 2008, 06:11 AM   #18
psycho bob's Avatar
07 GT
12.86@104
i would say you're right, but i still wouldn't buy the first generation that comes out. they always have issues no matter who makes or designs them. no matter what the product.
Old October 13th, 2008, 07:40 AM   #19
chad05gt's Avatar
2005 Mustang GT
12.0 @ 117+
Any FI done RIGHT will be 10K... the cooling system upgrade and EVERYTHING is there in the Techco kit. Thus, very competitively priced.
IF, IF it all makes it to mass production...
12.0 @ 117+
Old October 13th, 2008, 01:29 PM   #20
Blown 03 GT
The KB was the new kid on the block once too...
LinkBack to this Thread: http://www.moddedmustangs.com/forums/2005-2010/92307-new-blower.html
New blower This thread Refback October 9th, 2008 03:12 PM
Threads Similar to: New blower
which blower FastBack71 5.0 Mustangs 25 September 8th, 2008 08:37 PM
Blower or 4.6 focus0frenzy1 V6 Mustangs 100 April 8th, 2008 10:25 PM
Blower HELP!! truedeath V6 Mustangs 7 February 20th, 2008 03:51 PM
Which Blower? slightly stoopid 96-98 7 November 24th, 2007 09:03 AM
Blower justinsstang General Tech 11 March 1st, 2007 10:19 PM
