gear ratios in an 07 stang
Hey...does anybody know the individual ratios of the 5 gears in a 5 speed manual tranny. I downloaded a calculator that allows you to look at top speed and rpms per gear based on whatever rear end gears you plug into the calculator. But I can't find the gear by gear ratios. Thanks
1999 Ford Mustang V6
your mustang came with the TR3650 manual transmission with a new 5th gear ratio for improved fuel economy which adds an extra 2mpg on the highways, but equally important in picking the appropriate rear gear ratio.
2005+ Mustang (Tremec 3650) 1- 3.34:1 2- 2.00:1 3- 1.32:1 4- 1.00:1 5- 0.68:1 reverse- 3.38:1 2005+ Mustang (5R55S) auto 1- 3.25:1 2- 2.44:1 3- 1.55:1 4- 1.00:1 5- 0.75:1 reverse- 3.07:1 if i'm not mistaken the 5th gear was .62 for the tr3650 in previous mustangs?
...even fire and single cammin 1986 Ford F-150 5.0L 2WD 1994 Toyota Pickup 2.4L 4WD 1999 Ford Mustang 3.8L V6 2002 Jeep Grand Cherokee 4.0L 2WD 2008 GMC Sierra Denali 6.2L AWD |
99 stang,
Thanks. That is exactly what I needed. I plugged them into the calculator and Bingo!...all the info I needed. I was surprised that the rpm's at 60 won't change that much with 4.10's. I am using 3.55's as the stock gears...that is correct, right?
Mustang Calculators: (Gears are for S197 stangs, adding other years soon) ever wonder what size tire would fit on a 18x9 rim or what a set of 4.10 gears would do to your top speed? well, I did, so I created a spreadsheet that calculates these for you. Give it a try..... http://home.comcast.net/~swieduwilt0...lculations.xls I would like to hear your comments.. you can get an excel viewer that plugs into your browser here: http://www.microsoft.com/downloads/d...displaylang=EN
___ ![]() 12.29 @ 110 All Motor (Auto w/TCI 3500 Converter & Bolt-Ons) |
Great spreadsheet tool for ding the calculations. Well done!!!
when you change the gear ratio they all shouldnt be the same right? I was reading somewhere on here that the gear ratio should be 3.73. Sorry if i sound stupid im just trying to understand all this.
#8 | |
3.34 2.00 1.32 1.00 0.68 1st thru 5th ratios.
can u change them and if so how would you?
#10 | |
Change one gear...your rear end.
#11 | |
#12 | |
Stock rear gear was 2.73, 3.08, 3.27, for fox body stangs, I dont know if ford changed those ratios for the mod motors. Alot of people say put a 3.73 gear in a stick and 4.10 for auto but its all up to you. I had an LTD with a 4.30 and it was crazy fun. Do you want crazy torque and high rpms? Then go with a 3.73 or more. Or just mild torque and slower revving? Then maybe a 3.27 or less is more what you want. |
I'm kind of pushing towards the 3.73, but what was it like with the 4.30 in there? If I put either of these in here would i feel any difference.
thanks much |
#14 | ||
I try and help you and you drop this shot back? FOAD
Don't make it sound like a insult when you're saying it then I'm sorry i took it the wrong way though. it sound sorta like something my dumb ass friends would say to me and I'm use to that.
so sorry again man |
#16 | |
1st 3.38 2nd 2.0 3rd 1.32 4th 1.0 5th .62, .68, or .74!
/impetus |
Threads Similar to: gear ratios in an 07 stang
| 3.73 4.10 gear ratios | SilverGT04 | 99-04 | 2 | November 30th, 2010 07:39 PM |
| ? (T-Lock And Gear Ratios) | uniqueblackstang12005 | V6 Mustangs | 15 | June 16th, 2010 07:49 PM |
| What are the Stock gear ratios are in a T-5 in an 88 Mustang | NYHigH | 5.0 Mustangs | 11 | October 25th, 2007 12:17 AM |
| Gear Ratios | dStoltenberg | 5.0 Mustangs | 15 | April 19th, 2007 09:36 PM |
| Gear Ratios | 00RoushV6 | V6 Mustangs | 16 | February 20th, 2007 10:32 PM |
