performance
WILL 20'S AFFECT MY PERFORMANCE VS 18's
yes...you will loose alittle hp with the 20's
SLP Loud mouths SLP x-pipe 4.10 gears K&N intake X-Cal II custom tune |
wrong. it will just make your car a little more slugish. how would 20s rob horsepower colin? horsepower is the displacement of your engine, rims cant make your engine create less power.
it adds weight. alotta people say different things. i dont know for sure. like really every1 says somethin different. i really want 20's but i hear it makes the acc. a little slower. and i hear u will loose a tiny bit of hp and torque
On Probation
you don't lose any power... NONE AT ALL.... You just add weight and rotating mass... you'll more than likely just spin the hell out of the tires.
OK fellas,Lets all look at this for a second alright?If putting light weight rims on your car add HP(By reducing the rotating mass)then why would'nt heavier rims rob HP????Just thought I would point that out to ya.I mean everything real high performance guys deal with is HP to weight ratio!Especially when the weight being dealt with is rotating weight!Hence the use of U/D pullies,aluminum drive shafts,light weight bogart wheels & aluminum flywheels & so on.Doing all this ADDS HP.To add weight to the rotating mass will REDUCE HP......Hope this helps.
thats cool. now i jus wanna figure out how big of a difference there is.
It's not that putting a lighter or smaller rim increases HP on your car. You have less mass which lets you use or feel more of the HP you already have, it doesn't add anything. Same goes for larger/heavier rims. It "robs" HP by having a larger mass, but doesn't actually take HP away, just feels that way.
2009 427R Vert 3.73's, Roush Big Brake Kit
#9 | |
it creates RWHP. thats way different then hp. it just means that since the rims lighter, it doenst take as much power to move it. so your freeing up rwhp, not making it, just freeing it up.
less weight = more rwhp |
its not a big difference and if u get nice tires it will make up for it.... some really sticky tires
#12 | |
Yeah Bro,thats what I just said in the last post.....
1 pound of rotating mass is = to about 8 pounds if weight in the inside of the car. yes a bigger wheel weighs more therefor causing more rotational mass. also making a bigger wheel and tire height will tkae away from the gearing of the car. if you add 2 inchs of tires to a 4.10 gear ratio, it can make it like a 3.73
basically thats sayin if ur goin to go pro and do this for living and shit get 18 or lower. but if this is just a car ur gonna race sometime and wannna have fun and cool looks with it then get some 20's
Resident Bubblehead
ever wonder why drag racers run small wheels ( like 15's)? it's not cause they can't afford them, it's for two reasons. 1- smaller wheel= more sidewall on the tire which means that the tires will grip better on launch. 2- smaller wheel= less rotational mass which means that you will lose more hp to the rear wheels with a larger diameter wheel. smaller wheels won't "make" more hp, but will allow more hp to get to the ground. same idea behind lightweight driveshafts and flywheels.
i say jus get the 20's
Threads Similar to: performance
| JLT Performance | JRuckas | Parts | 25 | February 2nd, 2010 08:30 PM |
| Eng performance | acehogg69 | General Tech | 0 | August 6th, 2007 07:32 AM |
| i should of gone with performance but | mustang1072 | V6 Mustangs | 52 | April 24th, 2007 12:59 AM |
| C&C Performance | 00SoSlow | Vendors | 5 | March 9th, 2007 07:55 AM |
| staight line performance or track performance??? | andoutcomethewolves | V6 Mustangs | 12 | February 19th, 2007 11:34 AM |
