2007 Mustang GT
12.6@110
possible problems?
My original tune appeared to be having issues on cold starts, almost sounded like the car was dying when I would get into gear and try to move. Thankfully that issue has not occurred the past week or so since I took it in again to be looked at. But I had an issue the last time I was at the track with not getting any acceleration/power in the upper RPM ranges, like slower than stock. I'm trying to diagnose what the issue is, whether it is some kind of mechanical problem or a leak in the intake, or if it is a tuning issue. The car runs fine as normal, but it seems like above 3k rpm I'm not seeing any kind of power. Hopefully I'll find time this weekend to pop apart my intake arm and check all of the sleeves for any leaks, I'm also gonna put back on my old air filter and see if that makes any difference. Any other ideas out there? I have had issues of exhaust leaks before with my pypes o/r h pipe, but would that cause this kind of power loss?
![]() Professor Crackers
2006 GT
11.99@114
Check your plugs.
![]() 2006 GT (Fastest) 2004 COBRA (Faster) 1990 LX 5.0 (Fast) |
2008 GT
Have you done any datalogging? Do you have an Xcalibrator?
Fuel Altereds Rule The Earth
2007 Mustang GT
12.6@110
yes I just did a log but haven't loaded it up yet, was trying to capture data on the bogging going on, but might try it again for a higher RPM to see what's going on.
I'll have to take a look at the plugs tonight when I get home, never done it before so what should I be looking for? just a fouling of the plug?
May 08 ROTM
2008 Audi S6
First you'll be looking to make sure none broke or weird corrosion or soote is developing, second you'll be looking for a nice golden brown color too them, no white, and no black.
2007 Mustang GT
12.6@110
Thanks for the help, the guy that works at the shop where I had my install done is gonna help me out tonight checking them, so I'll keep my fingers crossed and hope that's the solution to this. I'd like to go get some reliable numbers down before the weather fully changes over.
Reps were given out, thanks again
2007 Mustang GT
12.6@110
Alrighty, so took it to the shop, checked out the plugs and they all seemed fine, no black/brown on them, a pretty good off-white color since the car hadn't been on for more than 15 minutes to drive over there. Checked out if there was any kind of an issue with my MAFia sensor, but it was functioning properly. Went for a quick test run and showed him just how poorly it ran above 3k RPM. He's thinking it's an issue with the tune and is gonna call the place up to see what might be wrong and about a dyno session again.
Any other input on what it might be if it isn't the tune?
2007 Mustang GT
12.6@110
everyone else out of ideas too?
Threads Similar to: possible problems?
| 5.0 problems | 5.0Madness | 5.0 Mustangs | 1 | March 11th, 2008 07:39 PM |
| T-5 Problems | 351stang | 5.0 Mustangs | 6 | November 22nd, 2007 04:12 PM |
| More problems | GreenFaleen | V6 Mustangs | 17 | April 8th, 2007 12:22 PM |
| Help! Several Problems With '99 GT | menedu | Modular Mustangs | 20 | November 17th, 2006 10:57 AM |
| 88 GT With A Few Problems | Iceman1989 | General Tech | 3 | November 14th, 2006 12:58 AM |
