How to: Swap axle shafts
LinkBack (4) Thread Tools
Old November 7th, 2008, 01:41 AM   4 links from elsewhere to this Post. Click to view. #1
AZAlloy is on a distinguished road
After much research prior to starting this project, I did not find any detailed write-ups with pictures. It is a very simple process, but I am a visual person and thought this might help others like me.
This project was done on a 2007 Mustang GT rear axle.
Step 1: Remove wheel. As you can already tell, I had to swap my left (driver's) side axle shaft.
Step2: Remove brake caliper, caliper mounting bracket, and brake disk. There are two 13mm bolts holding on the caliper, and two 15mm bolts holding on the caliper bracket. The disk should slide right off the lugs. I also took the liberty of removing the ABS sensor (one blot) so it would not get damaged.
Step 3: Remove axle differential cover (ten 13mm bolts). Before doing this, you will have to lower the panhard rod to get clearance to remove the diff cover.
Step 4: Rotate the rear axles until you are able to see the pinion shaft lock bolt. Remove this small bolt, and rotate the axles until the pinion shaft slides out.
Step 5: Now that the pinion shaft is out, you can actually push the axle you are going to replace towards the center of the vehicle. This allows you to view and remove the axle retaining clip, which just slides out.
Step 6: Now carefully remove the axle by sliding it out. Inspect the axle bearing and replace if needed. Insert new axle shaft slowly, rotating if needed to properly seat it. Replace retaining clip and pull axle back towards the outside of the vehicle. Replace the pinion shaft and lock it into place with the pinion shaft lock bolt. Be sure to line up the paint mark on the shaft.
Step 7: Clean the surfaces where the differential cover sits, and apply RTV silicone in a 1/8" bead, and around the bolt holes. Replace differential cover. I took the extra step, and grinded my cover down, sanded it, and re-painted it black. Turned out decent I think.
Step 8: Re-fill the differential with 75w-140. I used redline (synthetic is a must) and this application takes 2 liters. Consult your owner's manual for different applications. The picture shows the fill plug on the front driver's side of the diff. I used my ratchet driver to remove the bolt.
Step 9: Replace the brake hardware. Replace the wheel.
Done! Nice work.
Old April 17th, 2009, 01:43 PM   #2
Look Ma! My First Post!
2007 Mustang GT
Jupes is on a distinguished road
Thanks
I came across your thread and photos while doing research for a brake upgrade that will require removing the axle shafts for my 2007 GT, and just wanted to thank you for the clear thread and great photos. I have the manual and yes, this is a simple things to do, but like you, I am visual and the photos help a ton.
Great job,
Jupes
Old April 17th, 2009, 02:30 PM   #3
All sissies going to Hell!
navyman8903's Avatar
2008 BULLITT #3385
Killing with a smile
navyman8903 is a name known to allnavyman8903 is a name known to allnavyman8903 is a name known to allnavyman8903 is a name known to allnavyman8903 is a name known to allnavyman8903 is a name known to all
clean install, nice write up. So moderators..... STICKEY?
BULLITT CREW FOUNDER (The real one)
Bassani Crew Member #5...HARDCORE CREW
MILITARY CREW
E-5
MA2(AW)
Personally, I think being railed in the shitter would make you a meaner more violent fighting machine.
Old April 17th, 2009, 07:10 PM   #4
Moderator
PiggySmallz's Avatar
2007 Mustang GT
PiggySmallz is a splendid one to beholdPiggySmallz is a splendid one to beholdPiggySmallz is a splendid one to beholdPiggySmallz is a splendid one to beholdPiggySmallz is a splendid one to beholdPiggySmallz is a splendid one to behold
wow this is an old thread never seen it before though....great write up
Originally Posted by MamaStang View Post
Fuck, I'm not paying someone to tickle me! I want to feel that burn! Hurt me! That's how I know it's working! Whip me, beat me, teach me fitness!
Old April 17th, 2009, 08:49 PM   #5
rakkassan34's Avatar
2005 GT
13.5 best to date
rakkassan34 is on a distinguished road
I have to ask why all the threads lately about replacing axles? Getting me worried.
Off road pro chamber, JLT II, tune by Bamachips, 4.10's, thumper cams, sunburst orange stripes
LinkBack to this Thread: http://www.moddedmustangs.com/forums/2005-2010/96505-how-swap-axle-shafts.html
Removing a Kia Axle Shafts - Images This thread Refback October 3rd, 2010 01:43 PM
left axle shaft - 240Atlanta.com This thread Refback December 31st, 2009 08:43 PM
left axle shaft - 240Atlanta.com This thread Refback December 31st, 2009 05:10 PM
» How to: Swap axle shafts This thread Pingback November 7th, 2008 02:38 AM
Threads Similar to: How to: Swap axle shafts
Solid axle swap handling issues Diabeetus 4V / SVT 11 September 4th, 2008 02:15 PM
SLP LM1 axle back swap from 05 GT to 08 GT/CS mikevm78 2005 - 2010 11 April 26th, 2008 05:20 AM
drive shafts 40thmustanggt American Muscle 2 August 8th, 2007 04:19 PM
drive shafts hopper 5.0 Mustangs 7 July 3rd, 2007 01:15 PM
8.8 Rear Axle Swap Bies08 V6 Mustangs 3 May 21st, 2007 11:14 PM
