GT500 fuel pump duty cycle
Old November 20th, 2008, 08:17 PM   #1
2005 Mustang GT
11.88 @ 118
TimboStang is on a distinguished road
Ok, I've got some tough tech questions. The rundown...
2006 mustang gt
60mm turbo
60lb/hr injectors
gt500 twin fuel pumps
single fpdm
stock blow through maf
I think this is enough to get started on.
I was data logging to see what was going on since my fuel system is not up to par. Around 4500rpm under wot while its at full boost the fuel pump duty cycle goes to 50% and stays there. At the same time the fuel pressure drops to 8psi. Is the duty cycle staying at 50% because of the single fpdm and having two pumps, or is there something wrong in the tune thats not letting the pumps spool up. I'm new to these returnless fuel systems so I'm still learning. Highest maf count I saw was 455. I'm probably going to get a wideband tomorrow to see what the af ratio is doing.
Gurus please chime in here.
Turbonetics single 60mm
Threads Similar to: GT500 fuel pump duty cycle
Fuel pump question. Stock GT pump to GT (supercar) pump. Nate's4.6 99-04 15 May 14th, 2008 02:25 PM
fuel pump duty cycle ? stroker408 4V / SVT 0 March 29th, 2008 02:16 PM
Suggestions on Fuel Cell's & Fuel Pump bstang 2.3 Mustangs 5 January 21st, 2008 09:04 AM
GT500 Fuel Pump and Convertible Gunny 2005 - 2010 7 September 10th, 2007 05:04 PM
Shelby GT500 fuel pump into a '07 GT? BlownMod 2005 - 2010 2 July 27th, 2007 01:26 AM
