UCA, LCA and relocation brackets.
Old November 30th, 2008, 08:58 PM   #1
gragra73's Avatar
2006
gragra73 will become famous soon enoughgragra73 will become famous soon enough
I have steeda tubular LCA and I just ordered a non adjustable BMR UCA/3rd link. Paid only $65 on another forum for the BMR UCA. Now looking at my LCA, I see they are slightly lower in the front. Question is, can I still use relocation brackets even if I don't have adjustable LCA or UCA? My car is not lowered, but maybe because I only have 25.8" tires it played a role in the pinion angle.
RIP 06 Mustang GT
New Ride 04 GTO
K&N intake, Dynatech Long Tube Headers, Magnaflow catted X, Flow 40s, MS3 Cam and dynotuned by Texas Speed.
Old November 30th, 2008, 08:59 PM   #2
06HellFireGT's Avatar
2006 Mustang GT
MM's Flamer
06HellFireGT will become famous soon enough
ill add to this. is an adjustable uca/3rd link required when you lower the car ?
http://www.cardomain.com/ride/3297225
Originally Posted by silverstang View Post
HAHAHAHA stupid ricers, wings are for planes.
Originally Posted by interfac9 View Post
You've never heard someone say "yep, that was a CAMARO that just went by..."
Ratchet Shifter Crew Founder
Old November 30th, 2008, 09:12 PM   #3
kenneth's Avatar
2006 Mustang GT
11.45@123.61
kenneth has a spectacular aura aboutkenneth has a spectacular aura about
The LCA's should angle down towards the back of the car for better traction.
Don't know how much more the UCA will throw off your pinion angle.
06 hellfire, You should get the adjustable UCA if you plan on lowering your car.
It's purpose is to readjust your pinion angle.
Stock for now.
Old November 30th, 2008, 10:46 PM   #4
gragra73's Avatar
2006
The LCAs have a very slight negative pitch, maybe less than 2 degrees.
RIP 06 Mustang GT
New Ride 04 GTO
Old November 30th, 2008, 11:24 PM   #5
gragra73's Avatar
2006
I believe the Steeda LCA did help reduce wheel hop, but I still have some. My 60's times use to be in the 2.2 to 2.4 range with a best of 1.9. With the Steeda my 60 times are in the 2.0 to 2.2 times with a best of 1.88
RIP 06 Mustang GT
New Ride 04 GTO
Old December 1st, 2008, 12:27 AM   #6
2007 GT
07stanggt has much to be proud of07stanggt has much to be proud of07stanggt has much to be proud of07stanggt has much to be proud of07stanggt has much to be proud of07stanggt has much to be proud of07stanggt has much to be proud of07stanggt has much to be proud of
yes you use relocations brackets. Having adjustable LCA has nothing to do with that. adjustable lCA's are more for older stangs. The relocation brackets are as if not more important then the arms themselves. You want them.
Threads Similar to: UCA, LCA and relocation brackets.
Mmr Uca + Lca njstang 99-04 41 December 4th, 2008 02:19 PM
J&m Uca + Lca? njstang 99-04 1 November 19th, 2008 11:22 PM
Uca and lca njstang 99-04 6 November 7th, 2008 10:38 AM
are lca relocation brackets really needed? texas_mustang 2005 - 2010 15 June 26th, 2008 07:04 AM
Driveshaft/LCA/brackets/UCA 07stanggt 2005 - 2010 10 June 19th, 2008 08:18 PM
