Go Back   Forums at Modded Mustangs > Mustang Forums > Modular Mustangs > 2005+
Discussing Me + BMW M5 @ 150mph = bye bye engine! in the 2005+ Forum. Well it finally happened. I blew the engine after a shift from 4th at 6500rpm ...
Old December 27th, 2006, 10:16 PM   #1
Well it finally happened. I blew the engine after a shift from 4th at 6500rpm into 5th. I hit 5th for a bit let out of it and noticed a nice bright red oil pressure indicator. Red = 0 pressure. I pulled over and notice the engine was running but rough, I turned it off. This was Christmas night at about 10pm 40 miles inbetween each little city (Barstow and Baker, CA).
New game plan:
ST Motorsports is going to build me a iron block, forged rotating assembly, short block. I think I'll get cams while I'm apart. I told Adam to build me a motor that will be happy at 550rwhp or so and have no problems with extended time at 6,000+ rpm. He seems to have something for me.
I am a little bit different than most here, I am less into drags and more into high speed, high rpm runs.
On a positive note I put the whoopstick on a BMW M3 in the twisties in the back hills of San Diego before the whole blow up thing..hahahah!
'06 5 spd. 2.4 Kenne Bell tuned by www.spankintime.com, BAP, 60lb injectors, BMR springs, Hurst shifter, Flo Pro axle back, Pypes X-pipe, Axis GTRs 20x9 20x10.5.
Old December 27th, 2006, 11:57 PM   #2
thaztrain35's Avatar
sucks... but lookin foward 2 ur new engine... lol and nice kill
http://i34.photobucket.com/albums/d1...aboy81/sig.jpg
2008 Vista Blue GT 5spd
nothing done 2 it yet =/
Old December 28th, 2006, 02:56 PM   #3
there's this one company I'll try and find the name again but basically what they do is you send them your newly forged engine block and they like deep freeze it, causing all of the metal molecules to realign perfectly. Long story short they make your engine block or any steel product like 10x stronger and it will last ALOT longer.
SLP Loud mouths
SLP x-pipe
4.10 gears
K&N intake
X-Cal II custom tune
Old December 31st, 2006, 02:45 PM   #4
Ya the term is Cryo (sp). We use it on our race cars.
Old December 31st, 2006, 02:53 PM   #5
2001 Mustang GT
11.36@121
iron block will hold in way too much heat especially if you're going to be reving that motor to high RPM
www.MySpace.com/Zeilinga
Old December 31st, 2006, 05:10 PM   #6
drgnracin72's Avatar
2000 mustang GT
11.79@125
thats where you killed the motor. you took it way to much rpms. they run out of fuel at 6200 once they are boosted, thats what kills them is over revving them and thats to much on the boosted stock motor
if i had a cobra R, i'd take out the vents and put little miniature fish tanks in their places and fill them with sea monkeys
Old January 1st, 2007, 04:24 PM   #7
I have enough fuel at 6500rpm on the last 40 dyno runs but hey maybe something changes on the street.
Old January 2nd, 2007, 12:23 AM   #8
The Cable Guy...
ChrisJ's Avatar
SLOW
How much power were you making out of it?
My Junk
www.myspace.com/cjobe
Old January 2nd, 2007, 12:05 PM   #9
2000 mustang GT
11.79@125
and what kind of dyno where you on. becasue under a load things change and if you werent dynod on a mustang dyno you were not tested under load and if thats the case, thats your problem. the factory fuelk stuff on a stock motor with blower will start leaning out around 6200.
Old January 5th, 2007, 11:40 AM   #10
i'm crying but happy for you at the same time, the freezing thing get back to us on that
LOOKIN' FOR MY "MUSTANG SALLY!" . . .
. . . ARE YOU OUT THERE?
Threads Similar to: Me + BMW M5 @ 150mph = bye bye engine!
Engine Build Up or Engine Replacement... OcOnnor220 99-04 8 July 27th, 2008 03:54 PM
Build up or buy crate engine?? Where to go for crate engine cgb6810 5.0 Mustangs 17 October 27th, 2007 10:33 PM
1990 GT NO Engine Will 96 4.6 licolin town car engine FIT?? zygo4406 5.0 Mustangs 10 June 4th, 2007 05:53 AM
Swapping '99 v6 engine with '02 v6 engine elmills V6 Mustangs 63 May 25th, 2007 02:13 PM
Will a 2002 Gt Engine Directly Replace a 2000GT engine? Bigb2000GT 99-04 7 April 22nd, 2007 05:09 PM
