Go Back   Forums at Modded Mustangs > Mustang Forums > Modular Mustangs > 2005+
Discussing Installing Kooks LT tomorrow in the 2005+ Forum. I used a 1/4 ratchet to tighter up the top starter bolt. Had no ...
Old May 2nd, 2009, 10:59 PM   #21
usafimj's Avatar
2007 Ford Mustang GT
13.253 @ 106.96mph
I used a 1/4 ratchet to tighter up the top starter bolt. Had no problems
Mods in garage
Hurst Crew Member #13
Military Crew
E-5
Old May 2nd, 2009, 11:51 PM   #22
May 08 ROTM
Emay's Avatar
2007 Mustang GT
I leave the starter in and raise the motor high enough to slip them in.
They were kidding about denting the kooks, they're fitment is great.
Old November 6th, 2009, 11:55 PM   #23
Mr.Stang08's Avatar
2008 Mustang GT Premium
418rwhp/378rwtq
Hey guys I know I'm rising this thread from the dead but how the hell you rise the freaking motor to install the kooks LT's?
Paxton/Vortech Crew Founder #1
Roush Cat Back, Corsa X pype, Paxton NOVI 2200 H.O., Diablosport Tuner.
Buy my Roush Intake and tuner. See classifieds.
Old November 7th, 2009, 01:03 AM   #24
2007 Mustang GT
With a jack. Piece of wood or something between the jack and the oil pan.
Roush CAI-Bama tune-Pacesetter L/T's and H-pipe-Flowmasters-4.10's-PH Driveshaft-Pro Kit-BMR LCA's w/brckts-BMR adj UCA & adj Panhard
Ctr fogs-Generation II Facia-rear blackout w/seq tails-SHR flush mounts-Cervinis side scoops-Steeda Street Wing
Old November 7th, 2009, 03:57 PM   #25
Mr.Stang08's Avatar
418rwhp/378rwtq
Just like that? Wouldn't that bend the oil pan? Don't I have to loose some bolts before that?
Old November 7th, 2009, 07:45 PM   #26
MM's resident Juice head
07 STROKER's Avatar
07 Mustang GT
just take off the two motor mounts. the engine and trann ywill move up together.....there is play there, watch you dont put your tranny into the bellhousing, I broke off my breather tube doing that
The MGW short throw shifter
Its not just a shifter...It's a lifestyle!
Old November 7th, 2009, 07:49 PM   #27
May 08 ROTM
Emay's Avatar
2007 Mustang GT
That's supposed to be common sense..
There's plenty of threads outlining how folks have done theirs. Have a look around.
Old November 7th, 2009, 11:06 PM   #28
Mr.Stang08's Avatar
418rwhp/378rwtq
I tried that there are too many. That's how I ended up bringing this thread back
Old November 9th, 2009, 06:06 AM   #29
scramblr's Avatar
2006 Mustang GT
11.72 w/ 1.71 60'
You can raise it by the oil pan, but if on your back under the car, the jack will be in the way. You can leave the jack in the front, out of the way by raising the motor either at the balancer or right on the front edge of the oil pan. Get a piece of wood that just fits on that edge and raise the motor.
11.72 w/ 1.71 60'
298ci, Saleen S/C, BGG 8 Rib, Kooks, Stingers, 4.10, Spec 3+, Pro 5.0, GT500 FPs, GT500 T/B, CJ Springs, DSpecs, BMR - K-Mbr, Adj. Panhard Bar, LCAs, LCA Relo Brackets, Adj. UCA, Rear Sway, Sway Delete/Rad Support
My Gallery
Threads Similar to: Installing Kooks LT tomorrow
Installing suspension tomorrow. questions PowerShiftz02GT 99-04 18 April 24th, 2009 10:38 PM
Final Thoughts on Installing Kooks LT's & Cat'd X-Pipe SKRAPR 2005+ 8 January 26th, 2009 01:42 AM
Installing nitrous tomorrow 1BADSTANG 5.0 Mustangs 30 July 21st, 2008 12:05 AM
installing this tomorrow,hope it fits tom2000r 99-04 16 May 28th, 2008 03:22 PM
Installing tomorrow! and my gas mileage! Top Gear V6 Mustangs 27 September 30th, 2007 11:23 AM
