Discussing Suspension Help! in the 2005+ Forum. Do you really need all these things to lower the car? Lowering springs - BMR lowering ... Modded Mustangs is the premier Ford Mustang Forum on the internet. We discuss all aspects of the Ford Mustang on the forum. Registered Users do not see the above ads. Please Register - It's Free! |
Suspension Help!Lowering springs - BMR lowering springs are cold wound from high tensile strength chrome-silicon-vanadium to provide the longest lasting, most consistent rate possible. Specifically engineered around OE specs to maintain OE ride quality. Adjustable Panhard Rod - Since the S197 Mustang is equipped with a panhard rod to locate the rear end in the chassis, altering ride height can shift the rearend to the drivers' side up to 3/8". This not only effects alignment but can create tire clearance issues as well. To properly re-center the rearend, an adjustable panhard rod is necessary. Available with grease fluted polyurethane bushings or heavy duty Teflon-lined QA1 rod ends. Control Arm Relocation Brackets - Lowering a Mustang changes the rear control arm angles, altering the vehicles "instant center" location. This instant center is the virtual lift point of the suspension and is responsible for initiating weight transfer upon acceleration. Relocating the control arm mounts on the rearend re-gains and improves upon the original geometry. Front Camber bolts - The OE strut has no provisions for camber adjustment yet lowering the car even 1" creates too much negative camber for daily driving. The result is accelerated tire wear. BMR's camber bolts provide up to 2 degrees of camber correction. Upper Strut Mounts - Unlike most strut-equipped vehicles, your S197 Mustang comes with throw-away plastic upper strut mounts that are only good for one-time assembly. Fords service manuals specify replacing this part anytime the strut/spring assembly is disassembled. Re-use of original strut mounts often result in a "popping" sound heard while turning. This is the result of lost bearings due to the strut mounts weak plastic carrier.
I hated Mustangs till I bought one!!! 2006 Mustang GT 300bhp 320 torque 2001 Audi TT 327bhp 321 torgue |
i dont know man but what kind of race is your mustang and audi??
My friends used to wonder Why i joined the air force. Now they wonder why they didn't. |
#3 | |
what do you mean...
Threads Similar to: Suspension Help!
| best suspension set-up for a 2.3 | MSO | Suspension | 7 | July 6th, 2007 07:38 PM |
| new suspension | dadesolja | Suspension | 3 | June 12th, 2007 01:45 AM |
| SUSPENSION | Pony_with_an_attitude | 5.0 Mustangs | 15 | March 27th, 2007 11:51 AM |
| Suspension | dr.gonzo | 5.0 Mustangs | 0 | January 24th, 2007 12:58 PM |
| suspension | 9stang1 | 5.0 Mustangs | 2 | January 3rd, 2007 09:20 PM |
