Go Back   Forums at Modded Mustangs > Mustang Forums > Modular Mustangs > 2005+
Discussing Diagnos in the 2005+ Forum. Originally Posted by 07stanggt By the time your 16 your going to be building race ...
Old June 23rd, 2009, 11:56 PM   #61
mustangfan123's Avatar
Blank
By the time your 16 your going to be building race cars boy.
Here you go MF ill tell you this.
I know of a n/a 3 vavle
the 5.0 4 cammer block
stock stroke
stock heads
127300 cams
13.1 compressoin
420 at the wheels.
Do the math on that.
Bring the compression down to a streetable 11.1 running pump gas add some ported heads and bigger cams and tweak some other things on the set up. Tell me you arent looking at 450 to 460. And thats on 302 ci, not even a 322 stroker. Stock stroke, high revver hey.
Thats the most power n/a 3v i know of.
Wow that's A LOT of power with stock heads. Those 127300 cams aren't even 500 max lift on the intake OR exhaust side, so yep a pretty mild cam. I agree 450 to 460 would be doable if you added high flow heads and bigger cams. You gained 38rwhp from bigger heads/cams, so I'm sure that car would gain even more.
Originally Posted by GTsetGO View Post
my lord you are some leghumpin mf'ers.
it's like you guys have never seen a girl before. A female comes here and her intro thread is 18 pages long. a guy comes here and he may get 18 replies.
Old June 23rd, 2009, 11:59 PM   #62
2007 Mustang GT
Congrats on getting your motor running strong again. Broken valve spring, pretty minor. I would bet that if you had a vacuum guage hooked up to the motor, the needle would be bouncing like crazy with a broken valve spring. Also, good machine shops have a device that can measure the pressure of your valve springs to see if they are still good.
Saleen rear fascia with center exhaust, MAC longtubes with o/r Prochamber, Steeda CAI w/carbon fiber elbow, SCT X3, Steeda UDPs, Hurst shifter, modified delete plates, Comp Cams and 4.10s.
Old June 24th, 2009, 12:02 AM   #63
2007 GT
Thanks. Yes its all going to get looked at for sure. Right now im just glad its running and running well. i think the little tune up there with new injectors, plugs and coil packs woke it up a little. Or maybe im just happy its running.
Old June 24th, 2009, 12:23 AM   #64
2008 Mustang GT
12.13@111.63
oh actually tomorrow give me a call GS. i got something you will get a kick out of. LOL.
sounds good my man i will
N/A Automatic 3V GT-Nuff said
Can we please have George W. Bush back?
Old June 24th, 2009, 11:03 AM   #65
MM's resident Juice head
07 STROKER's Avatar
07 Mustang GT
fuckin stock springs FTL... MANLEY FTW
The MGW short throw shifter
Its not just a shifter...It's a lifestyle!
