Go Back   Forums at Modded Mustangs > Mustang Forums > Modular Mustangs > 2005+
Discussing BMR panhard and adj upper in the 2005+ Forum. Went in the car last night, now the rear end sits about a inch higher.......
Old June 27th, 2009, 03:15 PM   #1
MM's resident Juice head
07 STROKER's Avatar
07 Mustang GT
Went in the car last night, now the rear end sits about a inch higher....is this normal?
Also while trying to install the upper mount two of the oem bolts got knarled while taking them out...then i find out i have the recalled gas tank screws which they changed from a 13 mm bolt to a special t50 torx that you have to buy! So I had to reinstall the stock mount because i couldint drop the tank to put the BMR mount in. So i did up the knarled bolts knowing full well they will never come out again without taking all the threads with it.
I love my luck, I guess i could weld the upper mount to the car.
The MGW short throw shifter
Its not just a shifter...It's a lifestyle!
Old June 27th, 2009, 03:46 PM   #2
2007 Mustang GT
I don't think that what you did should effect the ride height. That's strange. Did you bounce the car around a little when you dropped it back on the ground? Sometimes when I drop my car back down it looks higher until I drive it and then it settles back down again.
I didn't think you had to actually drop the tank to replace the mount. I only did the adj UCA with the stock factory mount. I know I had to remove the two rear bolts and loosen the front one so I could swivel the mount around to get the bolt out that connects the arm to the mount. I would think that you could just slap that baby on there but I'm not familiar with the BMR upper mount. If you need the clearance to get that bolt in, try swiveling the mount or attaching the UCA to the mount and then throw it up there, and then attach it to the diff. Don't know if that will work, just trying to be helpful.
Roush CAI-Bama tune-Pacesetter L/T's and H-pipe-Flowmasters-4.10's-PH Driveshaft-Pro Kit-BMR LCA's w/brckts-BMR adj UCA & adj Panhard
Ctr fogs-Generation II Facia-rear blackout w/seq tails-SHR flush mounts-Cervinis side scoops-Steeda Street Wing
Old June 27th, 2009, 04:21 PM   #3
ROUSH STAGE II's Avatar
2005 Turbonetics Baby!!!
If you have too much negetive pinion angle it will definately raise the rear of your car. It will also make your pinion seal leak prematurely and puts alot more stress on your u-joints... I know...I did the same thing, although it only raised mine by about 1/2". Check to make sure you don't have more than...oh say...-3.5*'s and you should be good and the rear will settle back down.
Turbonetics baby!!!
11.68@120 mph
Old June 27th, 2009, 04:37 PM   #4
07 STROKER's Avatar
07 Mustang GT
i matched the upper to the stock upper so i know its the same. i guess ill get a level thingy...what are they called?
Old June 27th, 2009, 04:53 PM   #5
Your Mom's Favorite
Grabber523's Avatar
2007 Mustang GT
12.21@111.74 1.789 60'
It'll settle. It's the upper arm bushings, I'm guessing you had to torque the upper with the suspension unloaded. If you greased them up good so they slide through the dogears it'll just be a matter of a couple miles before they settle down. Definitely get a magnetic protractor and make sure your forward and aft u-joint angles match. Should be around 2.5 degrees each.
www.myspace.com/grabber523
Grammar/Spelling Nazi Club Member
MEMBERS AGAINST MEMBERS AGAINST STUFF CREW FOUNDER
Old June 27th, 2009, 05:34 PM   #6
07 STROKER's Avatar
07 Mustang GT
i just bought one...i cant get under the car on the ground to check it....i need a lift unless i can jack it up but how do i know the car is level, can i take a level off the car somewhere to make sure?
Old June 27th, 2009, 05:35 PM   #7
07 STROKER's Avatar
07 Mustang GT
ya torqueing the upper is a joke...no way my torque wrench fit up there...double arm torque is all i got. man the rear end is so much tighter just with the upper and the bar on.
Old June 27th, 2009, 05:42 PM   #8
No need for the car to be perfectly level, just note the difference between the two measurements.
Turbonetics baby!!!
11.68@120 mph
Old June 27th, 2009, 05:44 PM   #9
07 STROKER's Avatar
07 Mustang GT
ahh i get it...it still subtracts out to the same number.
Old June 27th, 2009, 05:45 PM   #10
07 STROKER's Avatar
07 Mustang GT
somthing else happened to me last night, i had the bottle open , nitrous tune in, pressure at 1000 psi, im all alone and ready to hit this thing...then a cold sweat came over me....Im afraid to hit this thing!!!! WTF is wrong with me?
Old June 27th, 2009, 05:52 PM   #11
I am Female!
Serioulsy???? You choked????
I am disappointed in you!
Old June 27th, 2009, 05:54 PM   #12
Canadians...sheesh...
Turbonetics baby!!!
11.68@120 mph
Old June 27th, 2009, 06:09 PM   #13
07 STROKER's Avatar
07 Mustang GT
I totally choked...never happened before...it just all sunk in how much ive spent on this build....plus i was under the car till midnight fighting with the BMR stuff cuz someone kept me from working so i was tired by the time i hit the street, but i dont know what it is...maybee i feel the engine needs more than 500 miles before spraying....and I know Rich is in AC so he cant call me a pussy right now. hes on a 30+ hour poker session.
Old June 27th, 2009, 06:17 PM   #14
I know Rich thinks a little backwards sometimes, but on his behalf I must say...
lol!!!yssup
Turbonetics baby!!!
11.68@120 mph
Old June 27th, 2009, 06:23 PM   #15
2007 Mustang GT
Where is AC? Nobody told me we were having a card game.
Old June 27th, 2009, 06:27 PM   #16
07 STROKER's Avatar
07 Mustang GT
Atlantic City, the Borgata
Old June 27th, 2009, 06:48 PM   #17
2007 Mustang GT
Never played in "AC". I would love to give it a shot. We still have the World Series going on here. There was mad money here in town a couple of weeks ago but it is drying up. I made over $6K in 3 quick sessions, I'm talking a total of about 12-15 hours. I wish I had more time to play, I could have made a real killing if I could have invested some time.
Old June 27th, 2009, 07:19 PM   #18
bigpappy33's Avatar
2006 Mustang GT
12.775@107.37
^ i need to move to vegas hahaha
2006 Mustang GT
20" MRR GT-1s - Avic D3 - Black Corners - GT500 Spoiler - GT500 Splitter
Borla Stingers - Pypes O/R H-pipe - C&L Intake (Brenspeed) - MGW - 4.10's
Eibach Pro-Kit - BMR Panhard Bar - BMR LCAs - CHE K-Member Brace - GT500 Brembos
Old June 27th, 2009, 07:20 PM   #19
I am Female!
They all always say "this has never happend to me before"
Well tell those freaky stalker girls to leave you alone!! Good girls are in bed before midnight like I was last night.
Have you even sprayed a car before or with this be your first time???
30+ hour poker session.....he is insane. But everyone else can still call you a pussy lol
Old June 27th, 2009, 07:23 PM   #20
07 STROKER's Avatar
07 Mustang GT
i sprayed all last year....not on this stroker yet. bed by midnight. wtf
Threads Similar to: BMR panhard and adj upper
BMR LCA's and Adj. Panhard bar on!!! tbi0904 2005+ 10 February 24th, 2009 09:31 PM
BMR Fabrication A-Arms Non-Adj. - $385.00 mustang fanatic S197 Performance 0 January 6th, 2009 08:27 PM
What did you use to grease your LCA's/Adj. Panhard Bar??? stanglifemike 2005+ 2 December 29th, 2008 08:01 PM
greasing the adj. panhard bar? Jucostud 2005+ 4 June 3rd, 2008 09:24 AM
BMR Adj. UCA Install Question PiggySmallz 2005+ 2 January 27th, 2008 07:14 PM
